4bbl conversion - JeepForum.com
post #1 of 4 Old 06-17-2004, 11:00 AM Thread Starter
joe johnson
4bbl conversion
right now i have a holley 390cfm 4 barrel on an offy intake; is there a way to keep the offy intake but put on a two barrel carb?
joe johnson is offline
post #2 of 4 Old 06-17-2004, 02:06 PM
Jeepbeeper
In the past i too wanted to do the same thing,,keep my intake that the 4bb was mounted on.
I visited my local auto store, and they said there was a plate i could purchase . But that was on a chevy...not a jeep.
One call to a few auto stores or even the jeep dealer parts department will give you that fast correct answer you are looking for.
Good luck.
Keep on Jeep'n
Jeepbeeper is offline
post #3 of 4 Old 06-17-2004, 05:20 PM
plain76cj5
Aftermarket Holleys all mount the same regardless of what vehicle they are on. The 390 you have would be a Holley square bore. Summit has an adapter plate part# SUM-G1406 for $52.00 and Jegs has a Moroso brand part#710-64966 for $55.99. Keep in mind that these are for adapting the Holley 2 Barrel 2300 series carbs. The stock Motorcraft 2 barrel used on AMC V8's will also fit these adapters.
Jeep #1 = 76 CJ5, 304, T18, Twinstick Dana 20, Lock-Right in front, Yukon HD front axles, One piece axles - Detroit Locker in rear, 2.5" Rancho Springs, 1" lift shackles, 32x11.5 Super Swamper TSL/SX, Warn XD9000i, York OBA.
Jeep #2 = 80 CJ7, 401, T18, D300, 3" Black Diamond Lift, TrXus M/T 33x12.5, Yukon 1 piece axles, Auburn posi in rear, Detroit TrueTrac in front, Ramsey 8000.
plain76cj5 is offline
post #4 of 4 Old 06-17-2004, 06:37 PM
amc232
amc232's Avatar
I have the offenhouser with the holley 390 as well. But, having nothing but good experiences with this setup, I question your reason for going to the 2bbl setup. Is it fuel econ.? Note: that the holley is very tunable. Changing the charactoristics of the accelorator pump, the main jets, and the nozzels, one can tune the holley to perform well in various situations. I just recently found the right combination for my setup. The results are great. I would need more info before i would agree on the change.
amc232 is offline
At my wits end with a holley 4bbl ACAD_Cowboy Jeep CJ Forum 16 10-09-2009 07:50 AM
360 4bbl intake is it broken?? lascelet Jeep CJ Forum 4 09-12-2008 12:05 AM
Need carb help please! Holley 4bbl- 79 CJ7 CrazyHorse6 Jeep CJ Forum 20 03-12-2008 08:18 PM
Carb choices 4bbl on a 304 arkiemurph Jeep CJ Forum 4 10-30-2006 06:45 PM
4bbl Qjet on a 225? Brandon Miller Jeep CJ Forum 1 03-14-2003 09:25 PM
