46 CJ2A engine swap - JeepForum.com
post #1 of 7 Old 04-11-2008, 10:13 PM Thread Starter
therichone
1946 CJ2A
46 CJ2A engine swap
I have a 46 CJ2A with the original engine. Problem is, it has a crack in the block. I also have a 93 mercury engine, it is the 3.8 ltr V6. I would like to put it in my Jeep. I would get rid of the fuel injectors and all electrical and put on a coil and regular distributor and also a carb.
Can this be done? Are there parts that will allow this engine to connect to the original bell housing?
Thanks
therichone is offline
post #2 of 7 Old 04-12-2008, 05:19 AM
SuB8HaVeN
I'm not sure that you're going to be able to find an adapter for that Ford V6. Novak-adapt.com has adapters for the Ford I4 OHC motors and the Ford Windsor V8s. You have the T90, which is a great transmission and will hold up under even V8 power. If you asked me, I would try and find a GM Iron Duke or a Vortec 4.3L V6 and swap that in with the GM adapter for the T90.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #3 of 7 Old 04-12-2008, 06:15 AM
high51977
the ford 3.8 shares its bell patern with the ford small V-8 (windsor) engines so adapting shouldn't be a problem. question is can you get intake and carb to fit it? also you want to be sure the 3.8 was out of a rear wheel drive car if not, the mounts will present a problem and the fwd 3.8 was JUNK (IMO of course but I have had both)
Play by the rules you're gonna miss all the fun
high51977 is offline
post #4 of 7 Old 04-12-2008, 10:14 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Are you saying Mercury as in the car (junk), or Mercury as in OMC/Mercruiser? The OMC swap would be GM, not Furd.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #5 of 7 Old 04-12-2008, 04:15 PM
high51977
I was saying the ford 3.8 in the taurus/sable platform was a weak engine. in cougar/t-bird/ltd platforms they were better/ more dependable and much less prone to head failure.
edit: oops read your post wrong Jayhawk ... and that is a good question when I read it I automatically assumed car.
post #6 of 7 Old 04-12-2008, 11:04 PM
slacker92104
slacker92104's Avatar
I would keep that fuel injection if at all possible. It makes for a much more enjoyable jeep.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #7 of 7 Old 04-13-2008, 08:58 AM
Grt_Ape
I agree. Keep the FI if possible.
Chris
2006 LJ Rubicon
Grt_Ape is offline
what engine to put in my cj2a P0NG Jeep CJ Forum 13 10-23-2009 09:57 PM
CJ2A Engine Color... Brizio Jeep CJ Forum 2 03-09-2009 11:47 PM
Engine Choice For Cj2a canuck2a Jeep CJ Forum 6 03-09-2009 10:20 PM
Steering wheel swap, CJ5 to CJ2A? gunpilot Jeep CJ Forum 2 02-22-2009 10:30 PM
CJ2A engine? cannonfodder Jeep CJ Forum 3 09-30-2008 10:08 AM
