40s on AMC20 and D30??? - JeepForum.com
post #1 of 27 Old 11-15-2011, 03:43 PM Thread Starter
broach70
Ok I have seen, and heard of it. Not sure if its far fetched or real. Is there any way to run a 38" to 40" tire with those axles. I am a very experienced welder and now where I can get both those axles already lincoln locked with one pieces in the 20. The rig they go under will be making lots of hp. What could I do to run these on a true rock rig?? If it TOTALLY cant be done give me reasons why??
Thanks!!!
broach70 is offline
post #2 of 27 Old 11-15-2011, 03:44 PM
ytowntj
I hope youre kidding. People routinely brake those axles on 33s and tired 258s putting less than 120 hp to the ground.
For 40's and high horsepower I would say a minimum of 35 spline shafts in the rear, preferably in the front too.
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #3 of 27 Old 11-15-2011, 03:49 PM
FLynes
1976 CJ5
My Dana 30 R&P broke on 33's, and I just found that my AMC 20 has one-piece axle shafts, so I ASSume that the PO broke the two-piece too.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #4 of 27 Old 11-15-2011, 04:22 PM
AFRd_CJ5
1976 CJ5
I don't know how much HP you're talking, but my 20 held up to quite a bit in the sand. We've ran stock 30's in the sand with a lot of HP as well. But, this is in the sand. Probably nowhere near the abuse rocks will put them through.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #5 of 27 Old 11-15-2011, 04:34 PM
foggybottombob
The answer is no.
foggybottombob is offline
post #6 of 27 Old 11-15-2011, 04:35 PM
lucdog
lucdog's Avatar
1980 CJ5
I you saw the size of a ring and pinion in a Dana 30, you could answer your own question. A 4.56 pinion head is smaller than a orange. More like a plumb.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 27 Old 11-15-2011, 06:39 PM
John N
1981 CJ8
You could do it, probably for a few seconds, but you could do it.... Understand that it would be a waste of time, effort and parts.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #8 of 27 Old 11-15-2011, 06:54 PM
skizriz
1978 CJ7
Especially locked up. Open diffs are one thing, putting 100% of the torque to a single axle is another.
skizriz is offline
post #9 of 27 Old 11-15-2011, 07:27 PM
Dmonkey
1976 CJ5
rock rigs on 40s break D60s. Not even close to a good idea.
Dmonkey is offline
post #10 of 27 Old 11-15-2011, 07:50 PM
Area.3.Fiftyone
Ummmm, yeah no..........
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #11 of 27 Old 11-15-2011, 07:54 PM
BriansCJ
1994 XJ Cherokee
No effin way man.
Im swapping/building axles for 35s on a mid HP CJ5.
To run 40s with big power you are gonna need a HP60 w/ RCVs IMO, if you dont want to experience breakage.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #12 of 27 Old 11-15-2011, 08:05 PM
ButcherJones
ButcherJones's Avatar
1977 CJ5
You can totally do it, and it would look sweet!
I sure as hell woudnt try to actually drive it though, just sitting in your front yard it would look great.
ButcherJones is offline
post #13 of 27 Old 11-15-2011, 08:57 PM Thread Starter
broach70
A guy had 360 punched out to 434ci launching it at 4500rpm and running nitrous to a AMC 20 rear for mud and sand drags (my guess was paddle tires) so no im not kidding that was my reason for asking.
broach70 is offline
post #14 of 27 Old 11-15-2011, 09:01 PM Thread Starter
broach70
Wheel that same setup right now on my 85, never had any trouble and go places that locked TJs with 35s go
broach70 is offline
post #15 of 27 Old 11-15-2011, 09:02 PM
mopar346
I think Jeephammer lauches and totes on a 20 so I would like to here his thoughts, I believe the ring gear is like 9.75. The axles, case and tubes I hear are the weak links in a 20. The 30 however is like a GM 10 bolt used in the S-10s.
Careful your character's showing
mopar346 is offline
D44 vs. AMC20 Sfisher Jeep CJ Forum 14 11-16-2011 02:36 PM
3.54 to 4.88 AMC20 Transorange Jeep CJ Forum 9 10-02-2011 11:30 AM
Difference between Regular AMC20 axle and Quadratrac amc20 axle? Dudman5703 Jeep CJ Forum 4 10-21-2010 02:35 PM
AMC20 Help. nightstalker5.0 Jeep CJ Forum 7 03-08-2007 08:09 PM
amc20 jepthng1 Jeep CJ Forum 3 04-02-2002 10:41 AM
