401 TFI upgrade with MSD stuff wiring help - JeepForum.com
post #1 of 10 Old 08-17-2011, 08:54 PM Thread Starter
aallison28
I have a bare motor and I'm building the wireing harness using a hotrod harness. So here is my problem......
I have a Motorcraft Distributor and am doing the Ford TFI system. I have the wiring diagram for the V8's that show how to incorporate the dizzy, MSD module, ford ecore coil and how to wire the battery.
I got the wiring diagram from here:
http://www.jeepforum.com/forum/f8/ca...-v-8-a-581179/
Now my question is I need to incorporate the Adjustble Timing Control module into the wiring MSD part 8680. The MSD site is not real clear on the wiring.
I also have a tach adapter, MSD 8920 that I can't figure out how to wire into the ignition.
With Luck, there is a modified wiring diagram here.
Is this correct as drawn and how do I put in the Tach Adapter?
Thanks........
aallison28 is offline
post #2 of 10 Old 08-20-2011, 11:24 AM Thread Starter
aallison28
any thoughts?
post #3 of 10 Old 08-26-2011, 09:18 PM Thread Starter
aallison28
knock-knock.........
post #4 of 10 Old 08-28-2011, 07:46 PM
Magical_Merlin
1976 CJ5
I wired my jeep exactly the same. I used the '79 CJ7 Distributor(Ford). It looks to me that the wiring for the spark control is correct. I am adding this to mine also. I also have the Howell TBI and I have a 401. If you have any more questions let me know.
Magical_Merlin is offline
post #5 of 10 Old 08-28-2011, 08:14 PM
JeepHammer
Running On Empty...
1973 CJ5
That's interesting, I wouldn't think it would work since the 'Small Red' wire needs to be hooked to a positive source (Ignition Swtich) for the Module to operate...
Unless I missed something (Very Possible), there is no positive source to swtich the CDI module 'ON' for use.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #6 of 10 Old 08-28-2011, 08:41 PM
Magical_Merlin
1976 CJ5
The instructions say to splice the red wire of the timing controller to the little red wire of the CDI which is wired to accessory on, as shown in the OP schematic. It should work.
post #7 of 10 Old 08-28-2011, 09:22 PM Thread Starter
aallison28
OK, so the diagram I put up shows the "SMALL RED WIRE" attached to the Red Wire of the "TIMING CONTROL UNIT". It appears, after looking at a different diagram in the MSD book, that does show the "SMALL RED WIRE" attached to the "RED WIRE" and a third connection to the IGNITION KEY.
I updated the diagram. Does this look right?
post #8 of 10 Old 08-28-2011, 09:29 PM
Magical_Merlin
1976 CJ5
That looks great!
post #9 of 10 Old 08-29-2011, 07:46 AM
JeepHammer
Running On Empty...
1973 CJ5
I didn't want to be a pain, but you didn't show the spice, so I wasn't sure you were splicing or just connecting directly.
I use the timing control on ANYTHING I use for towing since with a heavy load and older vehicles, there isn't any knock sensor or way to turn back the timing.
Also allows me to jack the timing up when I'm running premium fuel and take advantage of that better fuel.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #10 of 10 Old 08-29-2011, 09:14 PM Thread Starter
aallison28
No, not a pain at all!! I appreciate all the help!!
I showed a connection next to the "red Wire" box. ON another page of the MSD book, is shows a white wire leaving the Timing Control Unit and going to the "From points or electronic ignition amplifier (original coil wire)" wire.
The MSD book shows the Red wire of the timing control attaching to the red wire as indicated. However, it lists the wire from the ignition coil as the wire that used to go to the original coil + wire.
Like this, revision #3
Need to upgrade the wiring in my 77 CJ7 lars0909 Jeep CJ Forum 7 06-09-2011 06:49 AM
MSD Ignition upgrade wiring help boomvader Jeep CJ Forum 12 09-06-2010 11:43 AM
Wiring up Blower motor upgrade?? jp360cj Jeep CJ Forum 5 12-28-2007 05:23 PM
DJ5 distributor wiring/upgrade leadfootv6 Jeep CJ Forum 2 07-21-2006 10:56 AM
Wiring Harnesses and Rubber Stuff mvpco Jeep CJ Forum 4 10-09-2003 09:53 AM
