4" YJ lift= 4" CJ, and questions. - JeepForum.com
post #1 of 19 Old 05-10-2013, 11:07 AM Thread Starter
spottedfrog
1979 CJ5
So I have 2 ways I'm thinking of going with lift.
I'm thinking BDS 3.5" YJ springs
Crab tree CJ/YJ shackle hangers
Crab tree HD 1/2" lift YJ shackles
and M..O.R.E. HD steering box mount, moves the box forward to work with YJ springs.
Ford F250 shock mounts
Shocks are undecided
Run with 33x12.5-15
I could run the above with the stock axles and spacers until I can upgrade to D44s
I think that this combination would offer very good flex for a 4" SUA, I have tried to chose the flattest spring I could and the right compensates to allow them to work to their potential.
But even though it is 4" of YJ lift I'm not positive it will = the lift I need on a CJ.
Also I spec'd 1/2" lift YJ shackles. YJ shackles are longer than CJ ones any way and I'm concerned they may be too long on a CJ, or look like rabbit teeth.
Any one have pictures of a CJ on a similar set up?
Comments on my proposed suspension.
The other option is more expensive and is dependent on my finding the axles first, I'd have to make it a LONG term project.
SOA 33/35s custom Alcan springs (flat like stock yj but reverse rolled eye like Rubicon express, HD sreering boy mount that relocates the box forward, high steer, and some kinda D44 that is around 58-60" I know doing it right is key.
spottedfrog is offline
post #2 of 19 Old 05-10-2013, 12:42 PM
CJ7KAHUNA
I asked this recently an no one had the answer. Good luck!
CJ7KAHUNA is offline
post #3 of 19 Old 05-10-2013, 12:49 PM
Lpat
I have SOA on my cj7 with stock springs but they are sagging badly in the front. I bought some Rubicon reverse eye springs but I never installed them because I am now planning to sell the jeep. if you want I will sell you my rubicon express reverse eye springs and cj to yj conversion shackles and new spring plates for the wider springs. I think try are the best choice for SOA because they will not sag nearly as fast as other springs.
Yeah I've got chrome....but then again I've always made it home!
Lpat is offline
post #4 of 19 Old 05-10-2013, 12:51 PM
Lpat
also 4" of yj lift will not equal 4" of cj lift I'm pretty sure. yjs came with "flat" springs stock and cjs came with curved springs stock
Lpat is offline
post #5 of 19 Old 05-10-2013, 04:41 PM Thread Starter
spottedfrog
1979 CJ5
This is my theory as well, and they have taller shackles stock as well.
My theory is that the biggest part of the YJ conversion thing is that the better ride and flex is actually a by-product of going to flatter springs and a shackle that allows them to move smoothly. Now the fronts are +2 longer also so perhaps they have the same height but the arc is more gradual (flatter) in that case the height could be the same or close??
But I can never get a straight answer. its always it varies, or it depends.
Well that's not good enough and doesn't cut the mustard.
Think about it, the ride height stock for stock is going to be a fixed constant. therefore the + lift will be a presumed constant deviation from that height.
When you change from stock YJ springs you are getting a fixed height difference +/- and any + from there will be a constant. Manufactures variances aside.
So if you switched to stock YJ springs from stock CJ, how much did your height change, and was it + or-?
Other wise nobody could clame + a specific number.
post #6 of 19 Old 05-10-2013, 04:44 PM Thread Starter
spottedfrog
1979 CJ5
Thanks for the offer, I was going to go with custom Alcans because the Rubis are + 2.5 and SOA is already at the max height I'd want on a CJ5
post #7 of 19 Old 05-10-2013, 04:49 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The best thing to do is to call BDS and ask what the difference in 3.5" lift springs is between Yj and CJ. Ten the second best thing to do is report back because apparently you're not the only one who has asked what the difference is.
Luck Favours The Prepared
Anticanman is offline
post #8 of 19 Old 05-10-2013, 06:34 PM
RedRaiderCJ7
I'm working on a similar setup. I can't attest to the specs on as that's not my style and I never measured height before I started to install. Here is a picture of my half way done bds 3.5" yj lift with Crabtree hangers and 1/2 in lift Crabtree shackles. As you can see I only have the rear done and I should mention that I also have a 1" BL already on there. Maybe this can give you some perspective though. It's still sitting on 31s.
RedRaiderCJ7 is offline
post #9 of 19 Old 05-10-2013, 06:35 PM
RedRaiderCJ7
Nevermind, I guess the forum doesn't allow my pictures anymore. They're too big? If you think that can help you inbox me your number or something and I can send you some.
post #10 of 19 Old 05-10-2013, 06:54 PM
skizriz
1978 CJ7
Here are pictures of my tie rod and drag link for comparison. Notice they are both perfectly parallel.
One is with stock CJ springs, and the other with stock YJ springs.
The CJ springs were both 4 leaf. The YJ springs are 4 in front, 5 in the rear. Capacity rates are almost the same as before.
It sits at the exact same height as it did before.
skizriz is offline
post #11 of 19 Old 05-10-2013, 07:08 PM Thread Starter
spottedfrog
1979 CJ5
skizriz,
Are you using the same length shackles with both CJ & YJ springs?
and do you think that the springs are the same height, but that the curve is more gradual in the YJ?
post #12 of 19 Old 05-10-2013, 07:09 PM
skizriz
1978 CJ7
CJ springs.
YJ springs.
skizriz is offline
post #13 of 19 Old 05-10-2013, 07:12 PM
skizriz
1978 CJ7
skizriz,
The same shackles were used in the pictures. 4" eye to eye. I just changed them yesterday to 5" eye to eye shackles.
The way I can tell what springs were on in the pictures, is by the driving lights on the front. I took them off for the frame swap, and never put them back on again.
They both sat pretty much flat. MY cj springs were only 4 leafs, so they were as soft as they could get.
The YJ springs had a lot of arch to them before I put them on. I thought they were possibly 2.5" lift springs. But once I put the weight on them, they flattened right out.
The back may have lifted up abaout an inch, but that was due to my CJ springs being bent in the rear right before I changed them.
skizriz is offline
post #14 of 19 Old 05-10-2013, 07:17 PM Thread Starter
spottedfrog
1979 CJ5
so it seems that the CJ & YJ springs are equal lift, SO YJ length shackles would be + size on a CJ.
So I might go BDS 3.5 and CJ +1/2 shackles to reach 4"
I did Email BDS but am still waiting on a reply.
post #15 of 19 Old 05-10-2013, 07:28 PM
skizriz
1978 CJ7
Exactly. Stock YJ shackles are 1" longer.
Stock cj shackles are 3" eye to eye.
The 3.5" YJ springs would be factored with 4" shackles.
So you would need 5" shackles to reach your 4" of total lift.
Correct????
I just ordered the shackle plates from Besrk. Then added my own hardware.
skizriz is offline
