4 wheel disc's which MC??? - JeepForum.com
post #1 of 14 Old 03-18-2009, 10:28 PM Thread Starter
m-dub
1977 CJ5
Howdy all,
Done a bunch of searching with mixed results. Here is my deal:
77Cj5 on 35's with stock front disc, stock (non power)MC and porp valve and Ford Explorer rear discs (early 90's style). My Porp and MC are both leaking and need replacing.
1: I have been told that a mid 70's corvette MC is the ticket ( bigger 1" bore for more volume). But wonder if anyone has done this or is there something else others have done?
2: power assist? may require some cage mods to fit ( I have a shock hoop setup that takes up some space. Is there a disc set up for this or just the stock disc/drum?
3. Go the Willwood or Tilton custom set up?
Also: Do I just replace the porp vlave with a stock unit or go with a ? I dont want to take it out and run a adjustable block only for the sake of safety ( if you loose front or rear the other still functions )
Bottom line is I just want to do it right. I have used manual brakes that rock ( mine dont) and don't mind spending money for safetys sake ( I got the kids in the rig)
Thanks for any ideas!
m-dub is offline
post #2 of 14 Old 03-20-2009, 11:42 AM Thread Starter
m-dub
1977 CJ5
Any idea's? anyone?
m-dub is offline
post #3 of 14 Old 03-20-2009, 11:56 AM
Hardy350
1978 CJ7
I have a Hydrobooster with a Corvette Masterzylinder works great...
Hardy350 is offline
post #4 of 14 Old 03-20-2009, 12:13 PM
jeepskate
Corvette MC as you've found for the manual setup. For power, you need a disc/disc combo valve which you can get from Master Power Brakes, I'd go with a dual-diaphragm GM-based booster with a GM MC like a Firebird unit or I'd go hydroboost.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #5 of 14 Old 03-20-2009, 12:55 PM
mike06X
is the corvette mc swap (for retaining manual brakes) one for a corvette w/ manual brakes? I know some early 70's corvettes were available factory 454s/4-speeds/manual brakes - is this the ticket? could you feel an improvement over the rock-hard factory cj pedal? any plunger, arm, etc modification to fit the corvette mc?
84 CJ7 - AMC360 & T727 | 35 BFG-KM2
mike06X is offline
post #6 of 14 Old 03-21-2009, 11:57 AM Thread Starter
m-dub
1977 CJ5
^^^^^my qusetion as well^^^^^^ also, I take it the porp valve has nothing to do with being Drum disc or disc disc? just more of a "more to the front and less to the rear" deal?
m-dub is offline
post #7 of 14 Old 03-21-2009, 01:04 PM
dawgates
1980 CJ7
PP valve
It's not that much the master cylinder as to the proportion valve. Hopefully you switched to a power brake booster. That will help tremendously on stopping.
Find a PP valve from a Grand Cherokee with four wheel disc and use that valve. Or you can get a adjustable PP valve from SpeedwayMotors.com . This way you can adjust the pressure done on the front brakes. I think disc's run at 2 psi and drums at 10 psi.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
post #8 of 14 Old 03-21-2009, 02:35 PM
jeepskate
For power brakes, you need a disc/disc combo valve as I stated. With the manual 'Vette MC, IIRC the metering is integrated so you don't need a downstream valve unless you want to plumb an adjustable into the rear line...I could be wrong on that one since I'm relying on memory from back in the late 80's.
post #9 of 14 Old 03-21-2009, 03:18 PM
John N
1981 CJ8
A call to Van at Vanco Brakes would answer all of your questions. He's always glad to help, even if he doesn't sell you anything. He knows his stuff about brakes and different combinations.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #10 of 14 Old 03-21-2009, 03:57 PM
dawgates
1980 CJ7
Oh come on jeepskate, you're not that old that you don't remember the 80's! Now the 60's that would be a different story!
JohnN has the right idea, a call to either Vanco or MP Brakes would solve all you braking problems.
And "OLD" I need to read all the threads for all the information, not just one or two!
dawgates is offline
post #11 of 14 Old 03-21-2009, 04:04 PM
jfwireless
1976 CJ7
I installed 4 wheel disk brakes on my 1976 CJ7. Originally my 76 CJ7 had power 4 wheel drum brakes. I got the prop valve from a YJ with front disk brakes and used a 1981 Corvette Master Cylinder as recommended by Van at Vanco. The master cylinder bolted right up to my brake booster and the lines were on the same side as the original master cylinder. Brake lines/fittings worked just fine.
At first I just added front disk brakes, that is when I got the YJ prop valve from a YJ with front disk and rear drum. I also added the Corvette master cylinder at that time because it will work with front disk, rear drums, and also 4 wheel disk brakes.
I still have the YJ prop valve after the rear brake conversion, and all works just fine. The rear disk wheel conversion really made a big difference in my CJ.
I currently have a 1990 YJ dual diaphragm brake booster and matching master cylinder to install in the CJ along with the YJ brake pedal assembly. Just have not got around to it yet.
The brakes on my CJ are like night and day compared to the original power drum brakes. No fade, no issues when wet, faster stops and my wife isn't complaining about the brakes anymore. How about that
I bought the 1981 Corvette Master Cylinder from Rockauto. Rockauto part number is D14 18M91. Looked up as a 1981 Chevrolet Corvette 5.7L V8 4BBL. At the time the cost was $54.79.
I do not know if this Corvette master cylinder will bolt up to manual brakes.
Jim
jfwireless is offline
post #12 of 14 Old 03-21-2009, 04:23 PM
jeepskate
Hehehe...at the point that I read about the conversion, I was still a year or two away from owning a Jeep. You know...lusting, writing lists, etc
post #13 of 14 Old 03-22-2009, 08:03 PM
Dad03
1975 CJ5
Jim
The Vette MC works with the 4 wheel disc? Why are you changing to the YJ MC and Booster?
Dad03 is offline
post #14 of 14 Old 03-22-2009, 09:55 PM
jfwireless
1976 CJ7
The 1990 YJ dual diaphragm brake booster provides more pressure than the single diaphragm CJ booster. Disk brakes like to have that additional pressure.
Jim
CJ7 Spacing from wheel to wheel Dlongj Jeep CJ Forum 2 05-05-2009 12:24 PM
Maximum wheel offset for a 15"x10" wheel on a CJ5? aqsport196 Jeep CJ Forum 6 04-01-2009 05:19 PM
No Wheel/No Steal System for Grant Steering wheel Ridettu02 Jeep CJ Forum 12 11-11-2008 12:44 AM
Wheel Slop. Ball Joints or Wheel Bearings? DT5150 Jeep CJ Forum 8 07-07-2008 12:37 PM
new wheel help 83 cj-7 258 Jeep CJ Forum 0 07-27-2004 05:51 PM
