4" Lift with 1" body and 35" tires?????? - JeepForum.com
post #1 of 15 Old 08-19-2006, 06:18 PM Thread Starter
RobP
Anyone had any experience with 35 x 12.5 x 15 tires on 15x10" wheels with a 4" lift and a 1" body lift????? That is what I was told I would need to do to put 35's on ???
Tire Rub?
Help.
Rob
RobP is offline
post #2 of 15 Old 08-19-2006, 06:34 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I have a YJ with 4.5 Rubicon Express XD kit plus a 2 inch body lift. I have 33s. I removed my bump stops and trimmed my rear fenders.
However, at full compression in the rear it barely touches the fender. I would think you would need to trim you fenders as well since you are talking about bigger tires and less lift.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #3 of 15 Old 08-19-2006, 07:41 PM
Blue83CJ7
1980 CJ7
That is my exact setup, but since it is not ready for the trail, I am only driving on street. Wihout 1" BL, it rubbed quite easily on the street, but after, I can't get it to rub while on road, but For anything more than easy wheeling, I think trimming and/or more lift would be better..
I am going to add 1" shackle lift to the sagging front, but this is what mine looks like for now...
www.bill-levien.net/jeep/corner.jpg
Blue83CJ7 is offline
post #4 of 15 Old 08-19-2006, 10:44 PM
K.C.Jeep
K.C.Jeep's Avatar
1983 CJ7
CLICK FREE!! That's a nice Jeep Bill!
K.C.Jeep is offline
post #5 of 15 Old 08-19-2006, 11:19 PM
BLS33
Chief of the brain police
BLS33's Avatar
I'm going to upgrade to 35's from 33's in the not to distant future , I have a 4" suspension lift, 1" shackle lift, and a 3" body lift (yeah I know thats too much BL). So I should have enough lift right? I may also put some different flares on there to create a bit more space
BLS33 is offline
post #6 of 15 Old 08-20-2006, 08:36 AM
Bard
I had an 85 with a 4" lift, 2 1/2 shackle and 2" frame lift with 36" TSL's on it for the road and trail. Only rubbed the bottom of the fender and front frame when it got very tilted on the trails. Your set should work fine. Good luck.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #7 of 15 Old 08-21-2006, 10:45 AM
jeepskate
Should be fine, but you may want to at least swap out the rear flares...the stock CJ flares will rub where a stock YJ flare will not. Also, you should run proper bump stops...the purpose of them is to keep the tires off the sheetmetal. This is about 4.5" of suspension lift (2.5" springs, 2" shackle reversal up front, temporary 1.75" shackle lift out back) plus a 1" body lift, with 35's and YJ rear flares:
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #8 of 15 Old 08-21-2006, 11:20 AM
barry1me
barry1me's Avatar
35x15x15 TSL's 4" and 1"BL now 1" shackle in front
my TSL's are mounted on 15x10's and I was about a 1/2" from the rear leaf springs, so I added 1.5" wheel spacers, and put the bushwacker fenders on to give some more clearance.
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #9 of 15 Old 08-21-2006, 12:06 PM
mxg342
mxg342's Avatar
Mine has a 4" 4WDH kit and TJ flares. No body lift and the homemade shackles give it maybe another 1/2" of lift. I clear 35's without ever thinking about rubbing.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #10 of 15 Old 08-21-2006, 12:17 PM
rivers edge
(IMO)I know that a YJ isnt a CJ but, my brother's YJ has a 4" superlift, 2" body, and 2" shackle and he could clear 37" tires with ease so -2" of lift and 2" of tire and you will be fine!
'78 CJ- 5 (O'l Green), '99 TJ on rocks (li'l man), '07 JK (rattle can)
rivers edge is offline
post #11 of 15 Old 08-21-2006, 12:44 PM
BLS33
BLS33's Avatar
whats that website that has pics of jeeps with all sorts of differnet lift and tire combo's?
you can look through and see people with the same lift as you and different sized tire, if anyone know the site please let me know, thanks.
BLS33 is offline
post #12 of 15 Old 08-23-2006, 07:12 PM Thread Starter
RobP
Thank you all for your advice. Sounds like the 35's will work if I'm not trying to climb Mt. Everest!! with the 4 or 4.5" lift 1" Body Lift. Now my new question is will my gear setup handle the 35's????
Thank you again.....This site is great for me (the part time mechanic haha)
RobP is offline
post #13 of 15 Old 08-23-2006, 07:43 PM
BLS33
BLS33's Avatar
I would definetly re-gear, what gearing depends on what tranny you have
Also you will need to upgrade to HD one peice axle shafts in the rear if you have the AMC 20 rear, regardless you need HD shafts both front and rear for 35" tires
BLS33 is offline
post #14 of 15 Old 08-24-2006, 07:47 AM
jeepskate
Technically, yes, the gearing will handle the tires no problem. The problem is that with the stock gearing and the larger tires, your engine will not be operating in it's designed power band at a given speed. The way you'll notice this is that you'll have no 'get up and go'. I had the stock 3.31's (towing package) with my 35's while I was shaking out my rig after the rebuild and drove it to work for about a week. It was fine in rush hour traffic on the way home since there was a lot of traffic and we were hardly moving, but on my way to work in light traffic, pulling away from a traffic light was intolerably slow...I could walk faster and people behind me couldn't wait to get to spot where they could get out from behind me and pass. Performance/control will also be inadequate off road. If you're doing anything more than street use and very light wheeling, like BLS33 said the 1-piece alloy (don't get the cheapies like Crown & Omix-Ada) rear shafts become a must have and you should seriously consider alloy shafts for the front as well, plus I'd upgrade the lock-outs and replace the hub bolts with studs irregardless. If you like the skinny pedal and/or heavy wheeling, then don't even bother trying to keep & beef the 30. You should also weld and consider trussing the rear.
post #15 of 15 Old 08-24-2006, 07:59 AM
PEEH
I'm running a BDS 4" and TJ flares with 35s. Looks like I could possibly run 37s with the correct bump stops.
PEEH is offline
2.5" suspension lift on 33x12.5" tires cyjeeper Jeep CJ Forum 13 03-23-2015 08:28 AM
Ugg! Rugged Ridge "stock" length shackles actually 3/8" lift 1984Laredo Jeep CJ Forum 16 12-26-2011 05:12 PM
Can anyone show me what a 4" lift and 1" body on a cj7 looks like with 35" tires yojeep79 Jeep CJ Forum 7 08-22-2009 05:56 PM
Will a 4" trailmaster lift and a 2" body allow for 35" baja claws. yojeep79 Jeep CJ Forum 13 08-19-2009 09:20 PM
3" lift and 33" tires Mike78cj7 Jeep CJ Forum 2 04-23-2008 10:45 AM
