4 inch lift on 80 CJ7 - Page 2 - JeepForum.com
post #16 of 20 Old 12-06-2002, 07:19 PM
jadams68
jadams68's Avatar
I think he meant...
4" suspension
+ 2" shackle lift
6" of lift may work for 37s, but you're going to rub on the trails...
So basically you can get a 1" Daystar body lift and maybe cut out some of the fenders and you're atleast do-able.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #17 of 20 Old 12-06-2002, 07:25 PM
rustyCJ
-shrugs, the way i read it is that he is going to add a 4" lift and has been running 37s without a lift. the whole shackle deal is someone completely diff. just curious
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #18 of 20 Old 12-07-2002, 12:41 AM Thread Starter
rednek
rednek's Avatar
clarification
I have been running a 3" body and 2" shackle. I have no rub on the street. On the trails that is a different story. I am putting the 4" suspension lift on and taking off the shackle lift. And I plan on some feneder modifications.
1980 CJ7
AMC 304 w/ Edelbrock 600cfm 4 bbl and home built snorkel
4 speed trans
3" Body lift
4" suspension lift
37 x 13 x 15 Boggers
15 x 10 Soft 5 rims
2 1/2" spacers
8000 lb Warn upright
1/4 turn hubs
Headers
CD changer and casette player w/ Orion amp and 10" bass tube, 2 - surface mount waterproof highs and 2 - 6 x 9 waterproof speakers
KC takedowns w/ homemade window mounts
Lock'd Rear
Flatfendered
Custom confederate flag paint job and DIXIE air horn
rednek is offline
post #19 of 20 Old 12-08-2002, 10:05 AM
pontiac58
1980 CJ7
Wink
I get a good laugh everytime someone says you need a CV shaft for a 4in lift on a CJ. I have been running a 4in lift with no tcase drop, no motor mount lift, with a plain jane driveshaft. No vibes here until i did my rear swaps. When i installed the 9in i picked up a few vibes around 35mph. But i just thought it was the bad pinion angle that everyone said a 9in makes. Well after looking at it and thinking about it. I relized i have a correct pinion angle and gained 2inches of driveshaft, because the 9in pinion is shorter. So the problem ended up being the tranny mount was broke. New tranny mount and no vibes. My bro in law has 6in trail master springs on his CJ (No longer made). No vibes there either and thats with 38" swampers. The whole CV shaft is way overmade. Tom Woods loves you guys that spend 350 bucks for his shafts. Heck for about 100 bucks you can get the same shaft. Go to the junk yard find a heavy shaft, go to your local truck shop and have them cut the shaft down. So 50 bucks for a used shaft and another 50 to have it cut. Mum thats 250 bucks in your pocket. So no offense to anyone but you do not need a CV shaft for a 4in lift on a CJ. You can also run the stock shafts. But make sure you double check the length if your running so kind of goofy long shackle. Also becareful here because some lift springs off center the centering pin and push the axles back or forward.
pontiac58 is offline
post #20 of 20 Old 12-09-2002, 12:06 AM Thread Starter
rednek
rednek's Avatar
thank you pontiac58
pontiac58, Thank you. That is what I had been wanting to hear. I work offshore so I won't be home for a while but all the lift equipment is in my shop and I will be trying to put it all on without extending D/S or CV shaft. Thanks again.
1980 CJ7
4 speed trans
3" Body lift
4" suspension lift
15 x 10 Soft 5 rims
2 1/2" spacers
1/4 turn hubs
Headers
Lock'd Rear
Flatfendered
rednek is offline
4 inch lift on 33s daltonw Jeep CJ Forum 6 11-13-2009 06:48 PM
1 inch body lift and 3/4 inch shackle lift? bucs1fan Jeep CJ Forum 6 09-29-2009 12:21 PM
4 inch Rough Country Lift on 28 inch tires CrazyFlippinCJ7 Jeep CJ Forum 16 03-02-2008 02:09 PM
Does anyone have any pics of a jeep with a 6 inch or more lift and 35+ inch tires? jeepcj7 Jeep CJ Forum 10 03-23-2003 08:39 AM
Is there a 6 inch lift out there, for a cj 7 1980? What is the best overall lift? jeepcj7 Jeep CJ Forum 13 01-18-2003 09:46 AM
