4 cyllinder carb trbl - JeepForum.com
post #1 of 4 Old 01-09-2002, 12:34 PM Thread Starter
86kaicj
Question 4 cyllinder carb trbl
Seems my 86 CJ7 has had carb trouble from the get-go. I have records reflecting repeated repairs and replacements over the years through the last 2 owners. I bought it last year with a sparkling new carb, but still ended up replacing the float a few months later. It fixed things... but only for a while. I've never been able to get the (automatic) choke and idle properly balanced, and things are getting worse yet again. I'm constantly flooding and leaving a trail of smoke in my wake.
Any ideas? I've heard of affordable carb mods, but only for the larger engines, and I'm not in a financial position to go all out on a FI kit. In the mean time, I'm entertaining the idea of ripping out the auto-choke in favour of the old manual cable. Help?
"Has it never been done because it's deemed impossible, or is it deemed impossible because it's never been done?" -Kai
86kaicj is offline
post #2 of 4 Old 01-10-2002, 09:46 AM
glm 87 wrangler
Post
I will do some searching for your carb on your 4cyl cj i will try to get back to you if i find some info.Good luck.Later,Gary
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 4 Old 01-10-2002, 09:59 AM
glm 87 wrangler
Post
Is your motor a AM 150 if you can give me some info on your motor would be a big help.
I do think weber makes a carb for your jeep
The problem will be the price maybe.if you do not want to spend the money on it.It runs about 346.00 bucks but it is a 2bbl upgrade.So it will give you more power.But all in all more info would be a great help.Oh by the way i dont try to push weber carbs but i have had better luck with them in a number of cars and trucks and my VW bug i had years ago.They are just a little more user friendly
than other carbs i have delt with.A manual choke may help with your problem but i had no luck with it in my jeep on the carter that i had.Well Later,Gary
post #4 of 4 Old 01-11-2002, 07:04 PM Thread Starter
86kaicj
Post
Thanks GLM
The engine is, as you guessed, the AMC 150 I-4. I found out a whole bunch of other info in my search, thanks to an awesome website:www.off-road.com/jeep/tech/.
Bore x Stroke 3.88" x 3.19"
Displacement 150ci (2.5L)
Compression Ratio 9.2:1
Horsepower (net) 105@5000
Torque (net) 132@2800
Main Bearings 5
Valve Configuration OHV
Fuel 1bbl
Don't know enough about engines to know what (if anything) helps.
Thanks for trying!
86kaicj is offline
Carb return line leaking.........too much pressure? And other carb questions. Blthomas Jeep CJ Forum 0 06-01-2009 09:04 PM
Carter Carb Help----Carb Guru's Goody1231979 Jeep CJ Forum 4 04-28-2009 06:03 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 12:34 PM
What Carb, Help! durdenclub Jeep CJ Forum 2 08-15-2004 03:50 PM
