4 cyl. CJ7's - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 4 cyl. CJ7's
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 06-24-2007, 08:53 PM   #1
79cherokee
4 cyl. CJ7's
Just for curiosity, How many you guys still run the 4 cyl in your CJ7? Either the 2.5 AMC or 2.5 GM. Mine is 84 with the 2.5 amc, 4 speed, and 3.54 gears. Are you satisfied with it? I've done engine swaps before, but I've decided to leave well enough alone this time and keep it simple and stock.
03 Liberty Sport 4x4 3.7 auto, stock
84 CJ7 2.5 4 speed , stock
79cherokee is offline   Reply With Quote Quick reply to this message
Unread 06-25-2007, 09:59 AM   #2
twmattox
I ran one with that set-up for a few years. I still think that if it were properly geared (at least 4.10 with 31" tires) it would have worked just fine. Mine was geared a little too high and suffered in heavy wind or long uphills...
twmattox is offline   Reply With Quote Quick reply to this message
Unread 06-25-2007, 10:16 AM   #3
Oily
What kind of mileage do they get? I know a lot of factors contribute, just a ball park figure.
Oily is offline   Reply With Quote Quick reply to this message
Unread 06-25-2007, 10:24 AM   #4
Redmanchew
Redmanchew's Avatar
1982 CJ7
I Just replaced my 151 GM 82'. I ran it for one year after i purchased it. It had a T-4 with a little slippy clutch in it. It woudl not pull a steady hill or on ramp very well and shifting to 4th before you topped it, forget it. I did a full tune up when i got it and replaced all the vac hoses beacuse they were completely rotted. It got a little better but on compression check it was running 110, 90, 120, 120 with spec being 150 ish if i remember.
As for gas mililage could not beat it!!!! i was running 31's with 3.54 gearing. without any speedometer correction (i was running 25mph at an indicated 21mph). I was getting a non corrected 19-20 mpg. I was figuring around 20 to 21 corrected. 9-10 gal every 200 miles indicated.
Edited: after looking at another post i was also running about 9degrees at 1100rpm on timing.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
http://main.nationalmssociety.org/si...al&fr_id=18331
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline   Reply With Quote Quick reply to this message
Unread 06-25-2007, 10:34 AM   #5
twmattox
Yup...18-21 consistently (depending on wind and speed factors). I ran this for around 4 years and have nearly 80,000 miles of mpg data to back...
Unread 06-25-2007, 08:11 PM   #6
AMC Power
I am replacing my 4cyl. with a 258 right now because of the power reasons. That AMC 150 really sucked going up hills! If it was geared lower, then I probably wouldn't have had that much of a problem. The engine really took a beating though! Mine burned a lot of oil and it had about 117,000 miles on it. I can't wait to try out this rebuilt 258!
AMC Power is offline   Reply With Quote Quick reply to this message
Unread 06-25-2007, 09:55 PM   #7
gosupes
Same reason I swapped mine. The 18-20 mpg wasn't worth the lack of power, even with 4.10's and only 30" tires at the time. A stiff headwind and you could forget reaching 60 mph. I only lost about 2 mpg with the 258 running the same 4.10's and 33" tires and no overdrive. Should be better once I get the AX15 swapped in. There are people that rave about the 2.5 and 151, I'm not one. Dependable, sure, but that's about it.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA, 4.5" lift, Woody CV shaft and Tattons in front, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, trying to keep it simple.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline   Reply With Quote Quick reply to this message
Unread 06-25-2007, 11:34 PM   #8
only in a jeep cj
I know the MBs, GPWs and early CJs had the 4 cyl as the ONLY engine, but I do believe that when the larger and heavier CJs as in the 7s and 8s, entered the picture, the power to weight ratio of the 4 just didn't cut it. AMC had to have it due to the gas crunch of the time. I once test drove a 7 with a 4 and it was like having a briggs and stratin lawn mower engine under the hood. It feel very underpowered and just weird. But like others have said, with the right gears/tire size, the gas milage makes up for the lack of power. ......man, my 258 wasn't enough for me so I'm doing a 4.6 MPFI. I couldn't break free from the front air displacement of the big rigs I was TRYING to pass. It was sad.
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 06-26-2007, 03:55 PM   #9
twmattox
Don't get me wrong, the 258 is a whole lot more fun to drive (and I get nearly 18-19mpg wit it)...
