4" BDS Lift Problem - JeepForum.com
post #1 of 22 Old 05-25-2011, 08:50 PM Thread Starter
EthanW
1979 CJ5
4" BDS Lift Problem
So, I got my 4" BDS lift in today and I was excited to get it put on. I started with the front and managed to finally get the old springs off and started with the new spring install as well as ss braided brake hoses and sway bar disconnects. I got the front springs installed only to find that the springs are too short. I am having the same issue that many people had with their Rough Country lifts in the past with the springs being so short that the shackles either bottom out or sit at a 45 degree angle rather than at a 90 degree angle like they should. I sent an email to BDS this evening, but I am not happy to be taking the springs off again plus waiting for correct springs to come in. I have not gotten the rears on yet.
Pictures of my shackles:
Left:
Right:
EthanW is offline
post #2 of 22 Old 05-25-2011, 08:59 PM
CGrugger
CGrugger's Avatar
Those just look way too much arched.
I know my stocks are flat but those pics make it look like it would add a good 6-8 inches of lift to mine.
2005 TJ X: 2" RE spacer lift, 32"x11.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is online now
post #3 of 22 Old 05-25-2011, 10:16 PM
Trapshooter
I would suggest calling BDS first thing tomorrow morning. I wouldn't wait for an email.
They are great to work with....
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #4 of 22 Old 05-25-2011, 10:21 PM
boomvader
X2 on what Trap posted!!
Give this guy a call:
Ted Yearling
BDS Suspension
support@bds-suspension.com
Phone: 517-279-2135
-boom
Boom's CJ-7 Project (Completed in 2011)
boomvader is offline
post #5 of 22 Old 05-26-2011, 04:44 AM
CJ Chet
Those shackles look like stock length. If you don't get some longer ones you'll never get full flex on the springs.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #6 of 22 Old 05-26-2011, 07:17 AM
twoleos617
what sway bar disco's did you get?
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #7 of 22 Old 05-26-2011, 08:32 AM Thread Starter
EthanW
1979 CJ5
Skyjacker from quadratec.
EthanW is offline
post #8 of 22 Old 05-26-2011, 05:23 PM Thread Starter
EthanW
1979 CJ5
Update:
I recieved a prompt reply from BDS this morning inquiring about more information about my situation, then Ted called me shortly after. I informed him of the problem. He said that it was a very uncommon problem and checked to make sure that everything was correct for my model, then said to loosten all hardware and then flex the suspension to the max and that is should settle in. I put a jack under the each front corner then jacked it up until the tire on the other side came off of the ground as well. The pictures below are what the suspension looks like now. I think that after the springs have a few miles on them and settle in, they should be fine. Any Opinions?
Right:
Left:
EthanW is offline
post #9 of 22 Old 05-30-2011, 08:22 PM
cjdogtoy
1976 CJ5
any update
cjdogtoy is offline
post #10 of 22 Old 06-05-2011, 08:24 PM Thread Starter
EthanW
1979 CJ5
I finally got everything together, and after flexing everything out, the springs seem to have settled in perfect. Seems to be very stable on the road and has a better ride than it did before. Here are before and after pictures with the 4" BDS Lift and 31x10.50-15 tires. I hope to have my hands on some 33's before too long.
EthanW is offline
post #11 of 22 Old 06-05-2011, 08:57 PM
MoC
When you stand on the front bumper and bounce do the shackles move in or out?
MoC is offline
post #12 of 22 Old 06-05-2011, 09:02 PM Thread Starter
EthanW
1979 CJ5
Out
EthanW is offline
post #13 of 22 Old 06-06-2011, 07:10 AM
KUJeeper82
They'll settle more. I've lost an inch in the past 2 months on my CJ7 with the 4" BDS kit. Extra weight seems to help. I suggest placing 80lb sand bags in front of your grill and on the rear seat for a week.
Also, these things do flex a lot, so you might want to check your rear bump stops to keep from tearing up that nice tub and fenders when you go 33"... You'll probably need 2" longer in the rear unless you go TJ flares.
2007 Jeep Grand Cherokee Overland w/ 3.0L CRD & QDII):
Installed: GDE Hot Tune,CB DPF Delete Pipe, 285/70/17 GY Duratracs, 4" SuperLift
Future Mods:
ARB Winch Bumper, Crawler Rear Bumper/Tire Carrier
1985 Jeep CJ7:
105k miles, 4.0L H.O. I6, AX-15, Dana 300, 4" BDS, Moser 1-pieces, Detroit AMC 20, Truetrac Dana 30, 4.56 regear, 33x12.50x15 BFG MTs
KUJeeper82 is offline
post #14 of 22 Old 06-06-2011, 07:24 PM Thread Starter
EthanW
1979 CJ5
Yeah, I plan on new bump stops soon. I still have a few things that I have to work out before I am back 100%. I have the front driveshaft tied to the frame right now because the exhaust is in the way due to the different angle. I have to get the exhaust modified as well as do a tie rod flip. All in all though, I am very happy with the results.
EthanW is offline
post #15 of 22 Old 06-07-2011, 03:25 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
What you mean other lifts other then RC's settle????? OMG! alert everyone......
there was a problem and you were able to contact the manufacture and got helpfull information????? i thought only RC had problems with their lift kits and everyone else was perfect...
Anyway sarcasam off.....
Looks nice, definately 33's in your future. I have HD shackles with about 3/4" in them and allmost thinking about going to 35's vs. 33's beacuse the difference is only like $10 a tire. Alread have my rear fenders trimmed for a little more room.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
4" , bds , lift , problem , shackle
Odd problem steering after install 1" body lift h2ojeep Jeep CJ Forum 4 02-27-2010 03:15 PM
1980 cj5 1" body lift problem LSUtiger Jeep CJ Forum 9 12-19-2009 09:02 AM
jeep cj 4" lift problem.HELP!! jeeplogan Jeep CJ Forum 13 03-14-2009 04:25 PM
2" Body lift problem mustangdave357 Jeep CJ Forum 12 11-13-2006 08:06 AM
Serious problem after installing a 4" lift maxmuscle Jeep CJ Forum 6 04-24-2004 08:41 AM
