4.2L runs rough at idle and dies when throttle applied - JeepForum.com
post #1 of 3 Old 10-22-2009, 02:06 PM Thread Starter
CoryT
Hi jeep guys/gals, Im the proud new owner of a 84 CJ-7!! After driving it home for 2.5 hours, and driving it to work, it decides to run like crap on me when I try to leave. It will start, run really rough at idle( like the back of the motor is bouncing 2 inches up and down), and whenever I touch the gas it will die, or if I shift into gear and it gets a load from the transmission it dies. Its got a 4.2L/400/300 for a power-train, with a (crappy from what the previous owner told me) carter carb. Carbs are not my forte, especially ones with 20 damn vacuum lines running everywhere. Any suggestions on where to look?
CoryT is offline
post #2 of 3 Old 10-22-2009, 02:18 PM
Mike Romain
The carb can just purr with a $15.00 kit in it. The kits are easy to put in and have the settings.
You may have gas filter issues, they plug up fast after the Jeep sits for a while usually, but it more sounds like a choke issue.
To see if the choke is working, when off open the air filter and be sure it is closed after giving the gas pedal a shot to allow the fast idle to set. Then watch as it warms up. you won't be able to go until that choke is fully open, autos suck that way.
These engines need a shot of gas or two or three depending on how cold it is out, then you use the key to start it with your foot off the gas. The choke and fast idle should then be on. When the rpms come up, you tap the gas pedal, then you wait for the rpm to come up again and tap again. Eventually it will be warm enough to go to curb idle and you 'may' be able to put it in gear and drive away without is chugging, they like to be really warmed up, 5 minutes + and the choke is a timer that comes off too fast usually. I went manual choke, much better in my opinion.
Mike
Mike Romain is offline
post #3 of 3 Old 10-22-2009, 03:44 PM Thread Starter
CoryT
ok thanks! I understand fuel injection no prob, but carbs are a little confusing to me. I went out after the jeep had sit for a few hours and pulled the air cleaner, the choke plate was closed, started it up without pumping the gas and it fired right up smooth as can be. After about 5 minutes it was open, and the motor revved up without problems. I didnt do anything, but the jeep runs great now....lol Before the choke plate was fully open all the time, maybe it just wasn't on last time.
oh and what is this kit you talk about? carb rebuilt kit?
CoryT is offline
Runs Rough Then Runs Perfect coolhuh Jeep CJ Forum 9 08-17-2009 01:14 PM
Dies when brakes are applied ragincajunATL Jeep CJ Forum 19 06-12-2008 09:16 AM
Runs good but dies in gear...HELP! jamier095 Jeep CJ Forum 1 02-28-2008 12:01 PM
rough idle then dies wh74415 Jeep CJ Forum 4 01-14-2008 06:20 PM
85 cj7 wont idle and runs real rough jeepin cj-5 Jeep CJ Forum 3 01-02-2004 11:06 AM
