4.2 tbi upgraded, but now i have issues. HELP! - Page 5 - JeepForum.com
post #61 of 219 Old 02-24-2013, 03:00 PM
CSP
No, actually it doesn't. Only two wires need to be connected to the distributor as already mentioned and diagrammed.
CSP is online now
post #62 of 219 Old 02-24-2013, 03:51 PM Thread Starter
motormike24
ok guys. thanks for alllll the help despite my lack of electrical expertise. i think we got it figured out. had a loose butt connector in one of the ECM wires, and now it has injector pulse and spark, but i think i have to super adjust the distributor now because when it cranks over and tries to fire it basically stops the motor dead in its tracks, as if its extremely advanced or something. might be due to having adjusted the distributor with both modules trying to feed the distributor previously. hoping so anyway. will let ya know after i re charge the battery as i ran it dead, LOL. thanks again you guys, you are a huge help.
motormike24 is offline
post #63 of 219 Old 02-24-2013, 04:20 PM
CSP
There's a connector to unplug to set initial timing. It has to be unplugged to take the computer out of the loop or you'll never see it stay at a certain setting while you try to get it set. I know where the connector is on a GM vehicle, but no idea where it might be on your setup.
CSP is online now
post #64 of 219 Old 02-24-2013, 04:38 PM
86cj74.2L
86cj74.2L's Avatar
For a mopar it is the engine coolent temp sensor that gets removed to set base timing.
GM???????
86cj74.2L is offline
post #65 of 219 Old 02-24-2013, 04:43 PM
86cj74.2L
86cj74.2L's Avatar
Google says its a tan/single wire connector
Edit: tan/black
post #66 of 219 Old 02-24-2013, 06:01 PM
gunzmcghee
Meh I have a Howell setup, what do I know.
gunzmcghee is offline
post #67 of 219 Old 02-25-2013, 10:15 AM Thread Starter
motormike24
this distributor is vacuum advance, instead of electrically advanced.... i have no such wire on my setup.
post #68 of 219 Old 02-25-2013, 10:48 AM
CSP
That wire is a part of the GM harness and you do have such a wire if you left the TBI harness intact.
The distributor was originally vacuum and mechanical advance. I sure hope you've disabled both types of advance since you're now letting the TBI computer do the timing advance for you. If not, you're in for more trouble with it running correctly.
CSP is online now
post #69 of 219 Old 02-25-2013, 10:58 AM
86cj74.2L
86cj74.2L's Avatar
Your suppose to pin the advance at zero so it doesn't change and or move. And not use the vacuum advance anymore.
Look in your electrical drawings. The wire for setting timing is their. Add it to you homemade wire harness exactly like it is in the book.
post #70 of 219 Old 02-25-2013, 11:07 AM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
If I understand the OP, he has built his own harness instead of splicing one from a donor vehicle. So, in that case, Mike will have to disconnect the wire that travels from D5 on the ECM and goes to "C" terminal on the GM 7 pin spark module. If the vacuum and centrifugal advances have not been disabled on the stock distributor then as you say," he's in for a lot of trouble to get the engine running correctly." God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #71 of 219 Old 02-25-2013, 06:08 PM Thread Starter
motormike24
ok, now i know that. i will unhook the vacuum advance, but how would i disable mechanical advance? and that might be why it runs like **** now....and btw its an 8 pin, not 7.
post #72 of 219 Old 02-25-2013, 06:35 PM
86cj74.2L
86cj74.2L's Avatar
Drill a hole through it and hammer a roll pin in.
post #73 of 219 Old 02-26-2013, 08:33 AM
CSP
I've welded the weights to the arms.
You really should look at least at the sticky posts on the binderbulletin's EFI forum. You might find other things you've missed that aren't obvious in this thread. It seems like you're missing a lot of the basics.
CSP is online now
post #74 of 219 Old 02-28-2013, 07:03 PM
Jon In Tucson
1983 CJ5
7 pin, 8 pin, they both do the same thing...
An easy way to lock the mechanical advance is to take the top plate off the distributor, remove the springs and weights, safety wire the advance arms together if you don't want to weld them. Put it back together and perform the 0 degree base timing procedure. You should be golden... God bless.
Jon In Tucson
panic." - Mike
post #75 of 219 Old 02-28-2013, 09:34 PM Thread Starter
motormike24
Jon In Tucson
so im sposed to set the base timing to 0 degrees instead of the 10 degrees it was calling for originally??
