4.2 tbi upgraded, but now i have issues. HELP! - Page 10 - JeepForum.com
post #136 of 219 Old 03-08-2013, 08:11 PM
86cj74.2L
86cj74.2L's Avatar
You will need to copy and paste
86cj74.2L is offline
post #137 of 219 Old 03-08-2013, 09:58 PM Thread Starter
motormike24
ok, this is the BLM file from when it was around 150 degrees temp but still faltered and died (then restarted). it ran for around 45 seconds max between the first startup and the re-start.
Narrow Latest
RPM \ MAP 20 30 40 50 60 70 80 90 100
400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
800 0.0 0.0 0.0 128.0 0.0 0.0 0.0 0.0 0.0
1200 0.0 151.0 130.0 0.0 0.0 0.0 0.0 0.0 0.0
1600 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
2000 0.0 130.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
2400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
2800 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
3200 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
3600 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
4000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
4400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
4800 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
5200 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
5600 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
6000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
6400 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Narrow Avg
1200 0.0 148.9 130.0 0.0 0.0 0.0 0.0 0.0 0.0
Narrow # Sapmles
400 0 0 0 0 0 0 0 0 0
800 0 0 0 1 0 0 0 0 0
1200 0 19 1 0 0 0 0 0 0
1600 0 0 0 0 0 0 0 0 0
2000 0 1 0 0 0 0 0 0 0
2400 0 0 0 0 0 0 0 0 0
2800 0 0 0 0 0 0 0 0 0
3200 0 0 0 0 0 0 0 0 0
3600 0 0 0 0 0 0 0 0 0
4000 0 0 0 0 0 0 0 0 0
4400 0 0 0 0 0 0 0 0 0
4800 0 0 0 0 0 0 0 0 0
5200 0 0 0 0 0 0 0 0 0
5600 0 0 0 0 0 0 0 0 0
6000 0 0 0 0 0 0 0 0 0
6400 0 0 0 0 0 0 0 0 0
Narrow Avg 10
1200 0.0 150.3 130.0 0.0 0.0 0.0 0.0 0.0 0.0
Narrow Std. Dev. 10
1200 0.0 0.8 0.0 0.0 0.0 0.0 0.0 0.0 0.0
2000 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Wide Latest
400 0.0 0.0 0.0 0.0 0.0 128.0 128.0 130.0 0.0
800 0.0 0.0 0.0 128.0 128.0 128.0 0.0 0.0 0.0
1200 0.0 128.0 128.0 128.0 0.0 0.0 0.0 0.0 0.0
1600 0.0 131.0 130.0 0.0 0.0 0.0 0.0 0.0 0.0
Wide Avg
1200 0.0 145.8 130.0 128.0 0.0 0.0 0.0 0.0 0.0
1600 0.0 138.1 133.7 0.0 0.0 0.0 0.0 0.0 0.0
Wide # Samples
400 0 0 0 0 0 1 4 1 0
800 0 0 0 1 3 1 0 0 0
1200 0 33 12 1 0 0 0 0 0
1600 0 99 26 0 0 0 0 0 0
Wide Avg 10
1200 0.0 148.4 130.4 128.0 0.0 0.0 0.0 0.0 0.0
1600 0.0 130.7 132.0 0.0 0.0 0.0 0.0 0.0 0.0
Wide Std. Dev. 10
1200 0.0 6.8 3.9 0.0 0.0 0.0 0.0 0.0 0.0
1600 0.0 1.4 5.3 0.0 0.0 0.0 0.0 0.0 0.0
Narrow Correction 10
400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
800 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
1200 1.000 1.174 1.016 1.000 1.000 1.000 1.000 1.000 1.000
1600 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
2000 1.000 1.016 1.000 1.000 1.000 1.000 1.000 1.000 1.000
2400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
2800 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
3200 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
3600 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
4000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
4400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
4800 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
5200 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
5600 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
6000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
6400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.000
Wide Correction 10
400 1.000 1.000 1.000 1.000 1.000 1.000 1.000 1.016 1.000
1200 1.000 1.159 1.019 1.000 1.000 1.000 1.000 1.000 1.000
1600 1.000 1.021 1.031 1.000 1.000 1.000 1.000 1.000 1.000
motormike24 is offline
post #138 of 219 Old 03-08-2013, 09:59 PM Thread Starter
motormike24
and this is the LOG file for same recording.
Time RAW:MW2 RAW:PROMIDA RAW:PROMIDB RAW:IAC RAW:CT RAW:MPH RAW:MAP RAW:RPM RAW:TPS RAW:INT RAW:O2 RAW:MALFFLG1 RAW:MALFFLG2 RAW:MALFFLG3 RAW:MWAF1 RAW:VOLT RAW:MCU2IO RAW:KNOCK_CNT RAW:BLM RAW:O2_CNT SENSOR:PROMID SENSOR:IAC SENSOR:Coolant Temp SENSOR:SPEED SENSOR:MAP SENSOR:RPM SENSOR:TPS SENSOR:INT SENSOR:O2 SENSOR:Battery Voltage SENSOR:Knock counter SENSOR:BLM SENSOR:rich / lean counter MW2:Vss Pulse Occured MW2:ESC 43B Ready for second Pwr Enrich MW2RP Occured MW2:Factory Test Mode (3.9k Ohms MW2iagnostic Mode (0 Ohms) MW2:ALDL Mode (10k Ohms) MW2:1st time Idle Flag / High Bat Voltage MW2:Idle / Cool Flag MWAF1:Clear Flood Flag / Not Closed Loop MWAF1:BLM Enable Flag MWAF1:Low Battery (IAC Inhibited) MWAF1:4-3 Downshift for TCC unlock MWAF1:Asynchronous Fuel Flag MWAF1:Old High Gear Flag MWAF1:Rich Flag MWAF1:Closed Loop Flag MCU2IO:AIR Divert Solenoid ON MCU2IO:AIR Divert Solenoid ON MCU2IO:A/C Disabled MCU2IO:TCC Locked MCU2IO:Park/Neutral MCU2IO:No High Gear MCU2IO:Not Used MCU2IO:No A/C Requested MALFFLG1:24 VSS (Vehicle Speed Sensor) MALFFLG1:23 IAT / MAT low (Air Temperature) MALFFLG1:22 TPS low (Throttle Position Sensor) MALFFLG1:21 TPS high (Throttle Position Sensor) MALFFLG1:15 CT low (Coolant Temperature) MALFFLG1:14 CT high (Coolant Temperature) MALFFLG1:13 Oxygen sensor MALFFLG1:12 Engine not running MALFFLG2:42 EST (Electronic Spark Timing) MALFFLG2:41 Not Used MALFFLG2:35 Not Used MALFFLG2:34 MAP low (Manifold Air Pressure) MALFFLG2:33 MAP high (Manifold Air Pressure) MALFFLG2:32 EGR (Exhaust Gas Recirculation) MALFFLG2:31 Governor Fail MALFFLG2:25 IAT / MAT high (Air Temperature) MALFFLG3:52 CAL Pack missing MALFFLG3:53 Not Used MALFFLG3:54 Fuel Pump Relay Faliure MALFFLG3:55 ADU error MALFFLG3:51 PROM error MALFFLG3:45 O2 rich (Oxygen sensor) MALFFLG3:44 O2 lean (Oxygen sensor) MALFFLG3:43 Knock ESC
0.6 4 3 213 11 52 0 60 50 29 138 1 1 0 130 131 146 128 226 143 78 981 11 186.0 0 32.5 1250 0.7 138 0.004 14.6 226 143 78 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
1.8 4 3 213 8 52 0 58 49 29 140 1 1 0 130 131 145 128 47 144 78 981 8 186.0 0 31.8 1225 0.7 140 0.004 14.5 47 144 78 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
3.0 4 3 213 5 52 0 57 48 29 142 1 1 0 130 131 146 128 123 145 78 981 5 186.0 0 31.4 1200 0.7 142 0.004 14.6 123 145 78 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
4.2 0 3 213 2 51 0 56 48 29 144 1 1 0 130 131 146 128 199 146 78 981 2 187.3 0 31.0 1200 0.7 144 0.004 14.6 199 146 78 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
5.4 0 3 213 0 51 0 56 49 29 146 1 1 0 130 131 146 128 19 147 78 981 0 187.3 0 31.0 1225 0.7 146 0.004 14.6 19 147 78 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
6.6 0 3 213 0 51 0 55 50 29 148 1 1 0 130 131 146 128 95 148 78 981 0 187.3 0 30.6 1250 0.7 148 0.004 14.6 95 148 78 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
7.8 0 3 213 0 51 0 55 50 29 150 5 1 0 130 131 146 128 171 149 78 981 0 187.3 0 30.6 1250 0.7 150 0.022 14.6 171 149 78 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
8.9 0 3 213 0 50 0 53 50 29 152 40 1 0 130 131 146 128 247 149 80 981 0 188.6 0 29.9 1250 0.7 152 0.177 14.6 247 149 80 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
10.1 4 3 213 0 50 0 52 52 29 153 82 1 0 130 193 146 128 67 149 96 981 0 188.6 0 29.5 1300 0.7 153 0.362 14.6 67 149 96 0 0 1 0 0 0 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
11.3 0 3 213 0 50 0 52 51 29 153 176 1 0 130 193 145 128 143 149 97 981 0 188.6 0 29.5 1275 0.7 153 0.778 14.5 143 149 97 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
12.5 0 3 213 0 50 0 51 51 29 151 186 1 0 130 193 146 128 219 149 97 981 0 188.6 0 29.2 1275 0.7 151 0.822 14.6 219 149 97 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
13.7 4 3 213 0 50 0 52 50 29 149 69 1 0 130 129 146 128 39 149 98 981 0 188.6 0 29.5 1250 0.7 149 0.305 14.6 39 149 98 0 0 1 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
14.9 4 3 213 0 49 0 52 51 29 150 15 1 0 130 131 146 128 115 149 98 981 0 190.0 0 29.5 1275 0.7 150 0.066 14.6 115 149 98 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
16.1 0 3 213 0 49 0 52 50 29 152 13 1 0 130 131 145 128 191 150 98 981 0 190.0 0 29.5 1250 0.7 152 0.057 14.5 191 150 98 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
17.3 0 3 213 0 49 0 54 53 29 153 160 1 0 130 193 145 128 11 150 101 981 0 190.0 0 30.3 1325 0.7 153 0.707 14.5 11 150 101 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
18.4 0 3 213 0 49 0 52 53 29 152 178 1 0 130 193 146 128 88 150 103 981 0 190.0 0 29.5 1325 0.7 152 0.787 14.6 88 150 103 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
19.6 0 3 213 0 49 0 51 51 29 150 165 1 0 130 193 146 128 163 150 103 981 0 190.0 0 29.2 1275 0.7 150 0.729 14.6 163 150 103 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
20.8 4 3 213 0 48 0 52 51 29 149 59 1 0 130 131 146 128 240 150 106 981 0 191.4 0 29.5 1275 0.7 149 0.261 14.6 240 150 106 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
22.0 0 3 213 0 48 0 53 51 29 150 21 1 0 130 131 146 128 59 151 106 981 0 191.4 0 29.9 1275 0.7 150 0.093 14.6 59 151 106 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
23.2 0 3 213 0 48 0 52 51 29 152 146 1 0 130 193 146 128 136 151 109 981 0 191.4 0 29.5 1275 0.7 152 0.645 14.6 136 151 109 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
24.4 0 3 213 0 48 0 50 52 29 151 182 1 0 130 193 145 128 211 151 109 981 0 191.4 0 28.8 1300 0.7 151 0.804 14.5 211 151 109 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
25.6 4 3 213 0 48 0 51 51 29 149 156 1 0 130 129 146 128 32 151 112 981 0 191.4 0 29.2 1275 0.7 149 0.690 14.6 32 151 112 0 0 1 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
26.8 4 3 213 0 47 0 54 50 29 150 39 1 0 130 131 146 128 107 151 116 981 0 192.8 0 30.3 1250 0.7 150 0.172 14.6 107 151 116 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
28.0 0 3 213 0 47 0 57 45 29 129 5 1 0 130 131 145 128 184 151 116 981 0 192.8 0 31.4 1125 0.7 129 0.022 14.5 184 151 116 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
29.2 0 3 213 0 47 0 68 40 29 128 1 1 0 130 131 145 128 4 128 116 981 0 192.8 0 35.4 1000 0.7 128 0.004 14.5 4 128 116 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
30.3 0 3 213 2 47 0 128 22 29 128 1 1 0 130 1 144 128 80 128 116 981 2 192.8 0 57.6 550 0.7 128 0.004 14.4 80 128 116 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
31.5 0 3 213 23 47 0 150 21 29 128 1 1 0 130 1 144 128 156 128 116 981 23 192.8 0 65.7 525 0.7 128 0.004 14.4 156 128 116 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
32.7 0 3 213 20 47 0 81 44 29 128 1 1 0 130 131 146 128 232 128 116 981 20 192.8 0 40.2 1100 0.7 128 0.004 14.6 232 128 116 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
33.9 4 3 213 13 47 0 57 52 29 128 1 1 0 130 131 146 128 52 128 116 981 13 192.8 0 31.4 1300 0.7 128 0.004 14.6 52 128 116 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
35.1 0 3 213 10 46 0 73 40 29 130 1 1 0 130 131 146 128 128 128 116 981 10 194.4 0 37.3 1000 0.7 130 0.004 14.6 128 128 116 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
36.3 0 3 213 8 46 0 114 25 29 128 1 1 0 130 1 137 128 204 128 116 981 8 194.4 0 52.4 625 0.7 128 0.004 13.7 204 128 116 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
37.5 0 3 213 28 46 0 189 14 29 128 1 1 0 130 1 127 128 24 128 116 981 28 194.4 0 80.1 350 0.7 128 0.004 12.7 24 128 116 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
38.1 0 3 213 34 46 0 226 8 63 981 28 194.4 0 80.1 350 0.7 128 0.004 12.7 24 128 116 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
39.3 0 3 213 71 46 0 239 0 29 128 2 1 0 130 0 125 128 0 128 0 981 71 194.4 0 98.5 0 0.7 128 0.009 12.5 0 128 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
40.5 0 3 213 60 46 0 72 60 29 128 200 1 0 130 195 145 130 147 128 1 981 60 194.4 0 36.9 1500 0.7 128 0.884 14.5 147 128 1 0 0 0 0 0 0 0 0 1 1 0 0 0 0 1 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
41.7 4 3 213 56 46 0 62 65 29 127 14 1 0 130 131 145 130 224 128 2 981 56 194.4 0 33.2 1625 0.7 127 0.062 14.5 224 128 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
42.9 4 3 213 56 45 0 68 59 29 129 3 1 0 130 131 145 130 43 128 2 981 56 196.0 0 35.4 1475 0.7 129 0.013 14.5 43 128 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
44.1 4 3 213 56 45 0 67 60 29 131 1 1 0 130 131 146 130 120 128 2 981 56 196.0 0 35.1 1500 0.7 131 0.004 14.6 120 128 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
45.3 4 3 213 56 45 0 68 59 29 133 1 1 0 130 131 146 128 196 129 2 981 56 196.0 0 35.4 1475 0.7 133 0.004 14.6 196 129 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
46.4 4 3 213 56 45 0 66 60 29 135 1 1 0 130 131 146 128 16 130 2 981 56 196.0 0 34.7 1500 0.7 135 0.004 14.6 16 130 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
47.6 4 3 213 56 44 0 64 60 29 137 1 1 0 130 131 146 128 92 131 2 981 56 197.6 0 34.0 1500 0.7 137 0.004 14.6 92 131 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
48.8 0 3 213 56 44 0 66 60 29 128 1 1 0 130 131 145 128 168 131 2 981 56 197.6 0 34.7 1500 0.7 128 0.004 14.5 168 131 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
50.0 0 3 213 56 44 0 66 60 29 130 1 1 0 130 131 146 128 244 131 2 981 56 197.6 0 34.7 1500 0.7 130 0.004 14.6 244 131 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
51.2 4 3 213 54 44 0 65 61 29 132 1 1 0 130 131 146 128 64 132 2 981 54 197.6 0 34.3 1525 0.7 132 0.004 14.6 64 132 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
52.4 0 3 213 49 44 0 64 61 29 128 1 1 0 130 131 146 128 140 132 2 981 49 197.6 0 34.0 1525 0.7 128 0.004 14.6 140 132 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
53.6 4 3 213 44 44 0 63 58 29 128 1 1 0 130 131 146 128 216 132 2 981 44 197.6 0 33.6 1450 0.7 128 0.004 14.6 216 132 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
54.8 0 3 213 40 44 0 70 52 29 129 1 1 0 130 131 146 128 36 132 2 981 40 197.6 0 36.2 1300 0.7 129 0.004 14.6 36 132 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
56.0 4 3 213 36 43 0 71 51 29 131 1 1 0 130 131 146 128 112 132 2 981 36 199.3 0 36.6 1275 0.7 131 0.004 14.6 112 132 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
57.1 0 3 213 34 43 0 84 41 29 128 1 1 0 130 131 146 128 188 128 2 981 34 199.3 0 41.4 1025 0.7 128 0.004 14.6 188 128 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
58.3 4 3 213 33 43 0 139 23 29 128 1 1 0 130 1 130 128 8 128 2 981 33 199.3 0 61.6 575 0.7 128 0.004 13.0 8 128 2 0 0 1 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
59.2 0 3 213 53 43 0 225 9 29 128 1 31 981 33 199.3 0 61.6 575 0.7 128 0.004 13.0 8 128 2 0 0 1 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
60.3 0 3 213 91 43 0 247 0 29 128 2 1 0 130 0 126 128 0 128 0 981 91 199.3 0 101.5 0 0.7 128 0.009 12.6 0 128 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
61.5 0 3 213 100 43 0 247 0 29 128 5 1 0 130 0 125 128 0 128 0 981 100 199.3 0 101.5 0 0.7 128 0.022 12.5 0 128 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
62.7 0 3 213 100 43 0 186 0 29 128 1 1 0 130 195 141 130 224 128 1 981 100 199.3 0 79.0 0 0.7 128 0.004 14.1 224 128 1 0 0 0 0 0 0 0 0 1 1 0 0 0 0 1 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
63.9 4 3 213 66 43 0 64 66 29 127 150 1 0 130 131 143 130 43 128 2 981 66 199.3 0 34.0 1650 0.7 127 0.663 14.3 43 128 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
65.1 4 3 213 66 43 0 66 64 29 128 1 1 0 130 131 144 130 120 128 2 981 66 199.3 0 34.7 1600 0.7 128 0.004 14.4 120 128 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
66.3 0 3 213 66 43 0 67 61 29 130 1 1 0 130 131 145 128 196 128 2 981 66 199.3 0 35.1 1525 0.7 130 0.004 14.5 196 128 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
67.5 4 3 213 66 42 0 69 60 29 132 1 1 0 130 131 145 128 16 129 2 981 66 201.1 0 35.8 1500 0.7 132 0.004 14.5 16 129 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
68.7 0 3 213 66 42 0 67 61 29 135 1 1 0 130 131 145 128 92 130 2 981 66 201.1 0 35.1 1525 0.7 135 0.004 14.5 92 130 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
69.9 4 3 213 66 42 0 66 64 29 137 1 1 0 130 131 145 128 168 131 2 981 66 201.1 0 34.7 1600 0.7 137 0.004 14.5 168 131 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
71.0 4 3 213 66 42 0 66 61 29 128 1 1 0 130 131 145 128 244 131 2 981 66 201.1 0 34.7 1525 0.7 128 0.004 14.5 244 131 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
72.2 4 3 213 66 42 0 69 61 29 131 1 1 0 130 131 145 128 64 131 2 981 66 201.1 0 35.8 1525 0.7 131 0.004 14.5 64 131 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
73.4 0 3 213 63 41 0 69 59 29 133 1 1 0 130 131 145 128 140 132 2 981 63 202.9 0 35.8 1475 0.7 133 0.004 14.5 140 132 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
74.6 4 3 213 58 41 0 66 60 29 135 1 1 0 130 131 145 128 216 133 2 981 58 202.9 0 34.7 1500 0.7 135 0.004 14.5 216 133 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
75.8 4 3 213 53 42 0 65 59 29 128 1 1 0 130 131 145 128 36 133 2 981 53 201.1 0 34.3 1475 0.7 128 0.004 14.5 36 133 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
77.0 4 3 213 49 42 0 63 59 29 128 1 1 0 130 131 145 128 112 133 2 981 49 201.1 0 33.6 1475 0.7 128 0.004 14.5 112 133 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
78.2 0 3 213 46 43 0 66 58 29 129 1 1 0 130 131 145 128 188 133 2 981 46 199.3 0 34.7 1450 0.7 129 0.004 14.5 188 133 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
79.4 4 3 213 44 43 0 64 59 29 128 1 1 0 130 131 145 128 8 133 2 981 44 199.3 0 34.0 1475 0.7 128 0.004 14.5 8 133 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
80.5 0 3 213 41 44 0 66 58 29 130 1 1 0 130 131 145 128 84 133 2 981 41 197.6 0 34.7 1450 0.7 130 0.004 14.5 84 133 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
81.7 4 3 213 39 45 0 66 54 29 132 1 1 0 130 131 145 128 160 134 2 981 39 196.0 0 34.7 1350 0.7 132 0.004 14.5 160 134 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
82.9 4 3 213 38 46 0 70 52 29 134 1 1 0 130 131 145 128 236 135 2 981 38 194.4 0 36.2 1300 0.7 134 0.004 14.5 236 135 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
84.1 4 3 213 37 47 0 66 55 29 136 1 1 0 130 131 145 128 57 135 2 981 37 192.8 0 34.7 1375 0.7 136 0.004 14.5 57 135 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
85.3 4 3 213 36 48 0 64 55 29 128 1 1 0 130 131 145 128 132 135 2 981 36 191.4 0 34.0 1375 0.7 128 0.004 14.5 132 135 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
86.5 0 3 213 35 48 0 69 51 29 130 1 1 0 130 131 145 128 209 135 2 981 35 191.4 0 35.8 1275 0.7 130 0.004 14.5 209 135 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
87.7 4 3 213 34 49 0 80 44 29 132 1 1 0 130 131 145 128 28 136 2 981 34 190.0 0 39.9 1100 0.7 132 0.004 14.5 28 136 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
88.9 4 3 213 33 49 0 74 49 29 134 1 1 0 130 131 145 128 105 137 2 981 33 190.0 0 37.7 1225 0.7 134 0.004 14.5 105 137 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
90.1 4 3 213 33 50 0 62 56 29 128 1 1 0 130 131 145 128 180 137 2 981 33 188.6 0 33.2 1400 0.7 128 0.004 14.5 180 137 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
91.2 4 3 213 33 50 0 65 55 29 128 1 1 0 130 131 145 128 1 137 2 981 33 188.6 0 34.3 1375 0.7 128 0.004 14.5 1 137 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
92.4 0 3 213 32 50 0 67 53 29 129 1 1 0 130 131 145 128 76 137 2 981 32 188.6 0 35.1 1325 0.7 129 0.004 14.5 76 137 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
93.6 4 3 213 32 50 0 66 53 29 131 1 1 0 130 131 145 128 153 137 2 981 32 188.6 0 34.7 1325 0.7 131 0.004 14.5 153 137 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
94.8 4 3 213 32 50 0 63 55 29 128 1 1 0 130 131 145 128 229 138 2 981 32 188.6 0 33.6 1375 0.7 128 0.004 14.5 229 138 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
96.0 4 3 213 30 50 0 64 51 29 129 1 1 0 130 131 145 128 49 138 2 981 30 188.6 0 34.0 1275 0.7 129 0.004 14.5 49 138 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
97.2 4 3 213 27 50 0 69 49 29 131 1 1 0 130 131 145 128 125 138 2 981 27 188.6 0 35.8 1225 0.7 131 0.004 14.5 125 138 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
98.4 4 3 213 24 50 0 66 50 29 133 1 1 0 130 131 145 128 201 139 2 981 24 188.6 0 34.7 1250 0.7 133 0.004 14.5 201 139 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
99.6 4 3 213 21 50 0 63 52 29 135 1 1 0 130 131 145 128 21 140 2 981 21 188.6 0 33.6 1300 0.7 135 0.004 14.5 21 140 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
100.8 4 3 213 18 50 0 62 51 29 128 1 1 0 130 131 145 128 97 140 2 981 18 188.6 0 33.2 1275 0.7 128 0.004 14.5 97 140 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
102.0 0 3 213 15 49 0 64 49 29 130 1 1 0 130 131 145 128 173 140 2 981 15 190.0 0 34.0 1225 0.7 130 0.004 14.5 173 140 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
103.1 4 3 213 13 49 0 67 45 29 132 1 1 0 130 131 145 128 249 141 2 981 13 190.0 0 35.1 1125 0.7 132 0.004 14.5 249 141 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
104.3 0 3 213 10 49 0 66 43 29 134 1 1 0 130 131 145 128 69 142 2 981 10 190.0 0 34.7 1075 0.7 134 0.004 14.5 69 142 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
105.5 0 3 213 7 49 0 68 44 29 128 1 1 0 130 131 145 128 145 128 2 981 7 190.0 0 35.4 1100 0.7 128 0.004 14.5 145 128 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
106.7 0 3 213 4 49 0 96 30 29 130 1 1 0 130 1 144 128 221 128 2 981 4 190.0 0 45.8 750 0.7 130 0.004 14.4 221 128 2 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
107.9 4 3 213 17 48 0 147 21 29 128 1 1 0 130 1 136 128 41 128 2 981 17 191.4 0 64.6 525 0.7 128 0.004 13.6 41 128 2 0 0 1 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
109.1 0 3 213 25 48 0 120 32 29 128 1 1 0 130 1 145 128 117 128 2 981 25 191.4 0 54.6 800 0.7 128 0.004 14.5 117 128 2 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
110.3 4 3 213 14 48 0 58 50 29 128 1 1 0 130 131 145 128 194 128 2 981 14 191.4 0 31.8 1250 0.7 128 0.004 14.5 194 128 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
111.5 0 3 213 10 48 0 64 44 29 130 1 1 0 130 131 145 128 13 128 2 981 10 191.4 0 34.0 1100 0.7 130 0.004 14.5 13 128 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
112.6 0 3 213 7 47 0 93 32 29 132 1 1 0 130 1 144 128 90 129 2 981 7 192.8 0 44.7 800 0.7 132 0.004 14.4 90 129 2 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
113.8 4 3 213 8 47 0 133 22 29 128 1 1 0 130 1 133 128 165 128 2 981 8 192.8 0 59.4 550 0.7 128 0.004 13.3 165 128 2 0 0 1 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
115.0 0 3 213 29 47 0 163 20 29 128 1 1 0 130 1 134 128 242 128 2 981 29 192.8 0 70.5 500 0.7 128 0.004 13.4 242 128 2 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
116.2 4 3 213 34 47 0 91 43 29 128 1 1 0 130 131 145 128 61 142 2 981 34 192.8 0 43.9 1075 0.7 128 0.004 14.5 61 142 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
117.4 0 3 213 21 47 0 54 56 29 128 1 1 0 130 131 145 128 138 142 2 981 21 192.8 0 30.3 1400 0.7 128 0.004 14.5 138 142 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
118.6 0 3 213 18 46 0 57 53 29 128 1 1 0 130 131 145 128 213 142 2 981 18 194.4 0 31.4 1325 0.7 128 0.004 14.5 213 142 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
119.8 4 3 213 15 46 0 68 46 29 129 1 1 0 130 131 145 128 34 142 2 981 15 194.4 0 35.4 1150 0.7 129 0.004 14.5 34 142 2 0 0 1 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
121.0 0 3 213 12 46 0 72 42 29 128 1 1 0 130 131 145 128 109 129 2 981 12 194.4 0 36.9 1050 0.7 128 0.004 14.5 109 129 2 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
122.2 0 3 213 10 46 0 114 25 29 128 1 1 0 130 1 140 128 186 128 2 981 10 194.4 0 52.4 625 0.7 128 0.004 14.0 186 128 2 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
123.3 0 3 213 27 45 0 174 17 29 128 1 1 0 130 1 127 128 6 128 2 981 27 196.0 0 74.6 425 0.7 128 0.004 12.7 6 128 2 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
124.5 0 3 213 33 45 0 188 17 29 128 1 1 0 130 1 130 128 82 128 2 981 33 196.0 0 79.7 425 0.7 128 0.004 13.0 82 128 2 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
125.7 0 3 213 30 45 0 73 52 29 128 16 1 0 130 195 145 128 158 142 3 981 30 196.0 0 37.3 1300 0.7 128 0.071 14.5 158 142 3 0 0 0 0 0 0 0 0 1 1 0 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1
post #139 of 219 Old 03-09-2013, 07:38 AM
jeepardy
1983 CJ7
Wow, that's almost as bad as reading hex/dec. I think what 86CJ meant was to attach the files, but jeepforum.com won't allow CSV or XLS files to be attached.
First make sure your configured for correct ECM. mine is set for 16144288
Then when datalogging, get rid of RAW data by unclicking it in the "log Data" box
I prefer to take the *.txt/csv files and import them into xcel. I took your post and tried to do that here
BLM data
and
DATA log less raw data
Hope this post works
jeepardy is offline
post #140 of 219 Old 03-09-2013, 07:50 AM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
Mike,
Great progress!
The golden numbers you're looking for on the BLM map is the 128's. I see some 142's and 158's in there which indicate a rich condition. Are you using the knock sensor from the donor or the CJ? I used the donor knock sensor and removed a block plug and used it there with a thread reducer. I understand your frustration in not finding the text files after saving. The first series of numbers relate to the date, so write them down as you save. You can also bring the BLM into Excel and convert the data into a spreadsheet, making it easier to find. Sounds as though your temp sensor is working correctly, does the temperature logged match more/less the gauge? If it does then I would think it is good. Keep plugging away at it. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #141 of 219 Old 03-09-2013, 07:53 AM
Jon In Tucson
1983 CJ5
BLM data
and
Great post! What he said.
God bless.
Jon In Tucson
panic." - Mike
post #142 of 219 Old 03-09-2013, 09:14 AM
jeepardy
1983 CJ7
Originally Posted by Jon In Tucson View Post
Mike,
Great progress!
Jon In Tucson
Alright this is where I get confused and haven't started programing yet. I thought BLM's above 128 are showing a lean condition being corrected for, and as long as this number is +/- 10% your doing good.
As to motomikes numbers, I see some problems
1. its only a 2 minute run
2. closed loop malflag
3. lots of BLM enable flags
4. knock/esc malflag
I know its on the internet, so it must be true. http://www.gnttype.org/techarea/faq/BLMINT.html
jeepardy is offline
post #143 of 219 Old 03-09-2013, 09:15 AM
CSP
Is it even into closed loop at 150 degrees? I've never looked at a BLM file unless it's up to normal operation temperature.
CSP is offline
post #144 of 219 Old 03-09-2013, 11:16 AM Thread Starter
motormike24
jon, my temp gauge reads about 10 degrees colder than what the computer is seeing, so i believe its close enough to be alright. it never exceeds 200 one either medium, so its gotta be alright. and it does not seem to ever hit closed loop, so thats interesting. and jeepardy informed me that i need an addition ESC module that i do not currently have wired into this setup. i did not see it listed by bill on binderplanet on his write up of things to use, so i wasnt aware of needing such an item. going to the yard today to grab one to wire it in, and hopefully get rid of this esc code. also, not sure what exactly is causing it, but ever since i hooked up the aldl connector and the knock sensor (btw its the factory one from the yj 4.2), now when its cold it dies every time it drops to "idle", so it has to be restarted like 6 or 7 times be4 its warm enough to keep rpms high enough to catch itself from dying completely. grrrrr. but hopefully this added module will fix something. ill post updates later and also an updated BLM log. thanks
post #145 of 219 Old 03-09-2013, 12:13 PM
86cj74.2L
86cj74.2L's Avatar
My Satty goes into closed loop as soon as it sees valid data from the O2 sensor. It's a 1 wire sensor and doesn't take too long. Well before its up to temp. Around 120 or so its CL already.
post #146 of 219 Old 03-09-2013, 12:31 PM
86cj74.2L
86cj74.2L's Avatar
It's important to find out if he is still open loop when up to operating temp.
Does he even have a O2 sensor installed.
post #147 of 219 Old 03-09-2013, 01:52 PM
thompsoj22
i see it!
this is one of those trick hologram pic's right?, if i stare at it just the right way and long enough i can see the jeep attached to a 100 mile long electronic unbillical with a main server at the other end, based upon the terrain you can flash software changes to the algorhythm base line so engine management can can control the "precise" ignition/fuel delivery of the advanced, high revving, state of the art cutting edge technology of the 258 I6. hey mike, throw a new $300 carb on it and an hour later take it out on your favorite offroad trail with cold beer and your buddies.
thompsoj22 is offline
post #148 of 219 Old 03-09-2013, 02:07 PM Thread Starter
motormike24
naw. got too much time and money wrapped up into this. he wont go carb ever again. thanks for the thought tho. and yes i do have the stock 1 wire o2 hooked up and it seems to read just fine.
post #149 of 219 Old 03-09-2013, 02:10 PM
86cj74.2L
86cj74.2L's Avatar
Didn't someone say they saw close loop fail?
post #150 of 219 Old 03-09-2013, 02:30 PM
thompsoj22
copy that
you will prevail and end up with a project to be proud of. im pretty sure what your learning will count towards a college degree. with this forum and it's members absolutely anything can have a successful outcome. how about posting a video of the end result, ie cold starts, hot starts, revving and driveability and how the installed system looks in the engine bay. id really like to see,hear the benefits of this mod. hang in there.
