4.2 to 40 head conversion - JeepForum.com
post #1 of 4 Old 06-27-2003, 05:38 PM Thread Starter
gumby
gumby's Avatar
I just read about using a 4.0 head on a 4.2 engine (258) does it work or is it myth? it sounds like a cheep and easy way to find some horsepower
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline
post #2 of 4 Old 06-27-2003, 10:19 PM
SamFromCO
SamFromCO's Avatar
The 4.0 head has a better port design than the 258. That's the main difference. I'm not sure if it changes the compression or not. You will probably have to plug some of the water passages and you have to use the 4.0 exhaust manifold.
'86 CJ7, 258 w/Mopar MPI, 4.56 gears, rear Detroit/front Truetrac, full cage, OBA, 8274, 4" lift via Alcans/Rancho, 35's on beadlocks, other stuff. Built for rocks, mud is a four letter word.
SamFromCO is offline
post #3 of 4 Old 06-28-2003, 06:14 AM
Scramblin_Man
I have done the swap to my 90 wrangler with the 258 and I am pleased with the performance gains. You can really tell a difference in the power. Plus, my MPG went from 12 to almost 16. It isnt as cheap as you think. I have almost $600 into my project. Also, there is some other fab work you must do to make eveything come together. All in all, its a good project to do to your 258.
Scramblin_Man is offline
post #4 of 4 Old 07-17-2003, 07:52 AM
MudLover
MudLover's Avatar
I'm getting ready to do this swap. What all is involved with the exhaust? I know that I have to use the manifold for a 4.0 which I was gonna do by buying a header that would go on a 4.0 in a Wrangler. Is there a direct bolt on exhaust system? I guess what I mean is, can I use the 4.0 header then use an exhaust system designed for a Wrangler and have it "cooperate" with my frame and the stuff the exhaust pipes attach to? I hope I didn't confuse anyone. Simply put, what kind of things make the exhaust easy to install?
Thanks,
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
WTF 4.0 head conversion prob!!! whit450 Jeep CJ Forum 23 01-31-2016 07:49 AM
258 Cylinder head conversion? RipLip Jeep CJ Forum 3 06-12-2009 05:29 PM
Ebay 4.0 conversion head jeepmor Jeep CJ Forum 7 08-28-2008 04:06 AM
258 4.0 head conversion 5artist5 Jeep CJ Forum 3 11-03-2006 01:30 PM
258 rebuild w/ 4.0 head conversion cduemig Jeep CJ Forum 8 08-13-2006 07:04 AM
