4.2-4.0 intake question - JeepForum.com
post #1 of 6 Old 08-15-2009, 10:42 PM Thread Starter
allornothin
i have a 84 cj with a 4.2 and a mopar efi setup.......what i plan on doing is building a setup to put a eaton m90 supercharger on this motor........i dont want to have alot of down time on the setup.......well i work for a junk yard and have tons of 4.0 intake mani's laying around.....can i use it to build my setup or am i going to have to use a 4.2 intake mani.........i searched and really didnt find anything
allornothin is offline
post #2 of 6 Old 08-16-2009, 06:01 AM
scottymac62
1979 CJ7
http://www.jeepforum.com/forum/f8/4-0-head-258-complet-4-0-swap-w-auot-trans-626210/
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 6 Old 08-16-2009, 06:42 AM Thread Starter
allornothin
didnt help
post #4 of 6 Old 08-16-2009, 06:48 AM
JavaTee
1979 CJ5
How about http://www.4wheeloffroad.com/techart...kit/index.html
Later, T.J.
'79 CJ5 258 w/MC 2100 & Team Rushed, NP435/Dana300 <--twin sticked, NT Dana 44 (w/Aussie) rear, and NT Dana 44. 3" susp lift, Currie shackles, 1" body Lift, Durabaked tub inside & out.
Military members (current or completed service) check out
JavaTee is offline
post #5 of 6 Old 08-16-2009, 07:38 AM
nicknoty
1983 CJ7
the ports match from 4.2l to 4.0l, the hi port has exactly that though the ports are still spaced right but the pins are in a different place.
if you were to put a high port on a 4.2 you would have to remove the pins.
hesco has some sealent you can you on the intake.
honestly why not a 4.0l head conversion???
83 cj7, white/pearl w/ black trim - 99'ax-15/clocked dana 300 twin sticked - 4"RC lift - HD shackles - 33X10.5 bfg mt's on micky' T 15" classic 2s - HD tierod flipped - custom bumpers with d-rings - winch - flowmaster - obd1 efi swap - 4.6L strocker with com smooth idle cam. soon to be:
rear disc brakes,front and rear tube fender flares and better sliders, 3.0L mercedes turbo diesel power
nicknoty is offline
post #6 of 6 Old 08-16-2009, 03:30 PM Thread Starter
allornothin
which pins?.....im thinking about a 4.0 head conversion.......have not read up about it too much yet but i thought i saw somewhere it bumps the compression up and i wanna stay away from that with the supercharger on it
304 Intake Manifold Question... Death_Eagle_571 Jeep CJ Forum 5 12-24-2009 06:43 AM
Intake Question - V8 cj5jeff Jeep CJ Forum 1 02-08-2009 08:55 AM
Intake Adapter Question kstopp Jeep CJ Forum 3 01-20-2009 10:14 PM
Intake Manifold Question..... thedesertnomad Jeep CJ Forum 5 05-14-2006 06:17 PM
2bbl intake question CJ Fanatic Jeep CJ Forum 2 06-22-2005 09:49 PM
