4.2 4.0 Head Conversion bolt sleeves - JeepForum.com
post #1 of 5 Old 02-26-2012, 07:49 AM Thread Starter
CadCaman
1983 CJ7
To anyone out there that needs sleeves to get your 4.0 head to fit onto your 4.2 block correctly below is a pic of what you need. You can make them but I (like most of you) do not have a lathe.
You need at least two (I can't figure out why you would need more than two).
CadCaman is offline
post #2 of 5 Old 02-26-2012, 09:23 AM
82CJ_Chemist
1982 CJ7
Thanks for the post CadCaman. I may message you in a month or two to see how your 4.0 head conversion went. I am thinking for putting that on short list, especially if i can go carb route first and add fuel injections system later when more money is piled up
Good luck with it
82CJ_Chemist is offline
post #3 of 5 Old 02-26-2012, 09:29 AM
gosupes
This is a pic from Summit, $3.99 ea. Summit and Jegs have them as Ford head bolt bushings. You can probably get away with two. I think Clifford recommended 4. I bought a set of 20 for something like $35 and used them under all the bolts, cheap insurance in my mind. Probably have the rest laying around the garage somewhere. And you probably won't be making these on your lathe unless you can heat treat as well, these are hardened. Well, you could I suppose, but at $4 a pop, it's not worth the time.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #4 of 5 Old 02-26-2012, 10:32 AM Thread Starter
CadCaman
1983 CJ7
These would have to go at the top of the head. The sleeves will go on the bottom where they meet the block for much better centering.
Or....I may be missing something
CadCaman is offline
post #5 of 5 Old 02-26-2012, 12:30 PM
gosupes
Since there was not any pics with the first post I assumed this is what you were talking about. I read about someone a long time ago that used sleeves, tho I don't remember the outcome. Should work but if it were me I would use one at each corner just to be safe.
gosupes is offline
4.0 , 4.2 , conversion , sleeve
4.2 4.0 Head Conversion CadCaman Jeep CJ Forum 11 02-23-2012 01:16 PM
Need help with bolt head size, strap bolt u-joints neals80 Jeep CJ Forum 6 04-13-2010 12:05 PM
Have You Done the 4.0 Head Conversion? frodin1 Jeep CJ Forum 32 04-05-2010 11:01 PM
4.2 to 40 head conversion gumby Jeep CJ Forum 3 07-17-2003 08:52 AM
Need help with U-joint strap and bolt to U-bolt conversion hollywood Jeep CJ Forum 1 06-22-2003 03:15 PM
