4.2 4.0 Head Conversion - JeepForum.com
post #1 of 12 Old 02-22-2012, 08:36 PM Thread Starter
CadCaman
1983 CJ7
Guys, I am in the middle of a 4.2/4.0 head conversion. I found a 7120 head and it is at the local engine shop getting the once over. I also found a Clifford intake manifold that I know will fit the new head.
So..... I am wondering what suggestions you learned folks have for me in regards to an affordable ehaust manifold/header (the donor head did not have one available) to put on (single exhaust pipe) and what would be my best bet for a carbuerator. I think I want a 390 cfm but I am wondering what type of carb I can buy that has the correct jets and stuff and is as close to a bolt on and drive as I can get. I do believe I want a 4-bbl carb but I would like an opinion or two.
BTW - I have a Weber 32/36 now and I believe it is only a 300 cfm and I think I need more.
Thanks, guys.
CadCaman is offline
post #2 of 12 Old 02-22-2012, 08:52 PM
gosupes
I have the 390 with the Clifford manifold and it ran pretty decent out of the box. Just a little minor jet adjustment is all that I have done in 5 years. I think if I played with it more (PV and secondary spring) I could squeeze more out of it. But I'm fairly happy, runs great, doesn't stumble, plugs are a nice tan color. Some of the truck avenger styles might be better suited, worth looking into. As for header/manifold, I bought one the many knock offs you see around, but back than I paid more than what I see them going for now. The basic stainless steel with the expansion joints on 1 and 6, you know the type. They have Borlas, but you will have to take a hammer to 1 or 2 tubes to clear the manifold, not what you want to do on a new $500+ header. Mine fit like a factory piece and the flange thickness was the same as the intake so no funky washer/spacer issues. No regrets on the exhaust manifold either, no leaks, no cracking, nothing. I had custom single exhaust run all the way out. Been a great setup.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is online now
post #3 of 12 Old 02-23-2012, 07:06 AM Thread Starter
CadCaman
1983 CJ7
Update: I have decided to go with an APN Header. I hear nothing but good things and a great price. I am still concerned about the choice of carb. Here's my issues with my carb choice.
1. I do not know how tell if I need different jets and if I did I would be concerned about doing it.
2. I don't know what carb will fit on my clifford intake. I know Holley and other carb suppliers have different bolt patterns.
Thanks
CadCaman is offline
post #4 of 12 Old 02-23-2012, 07:10 AM Thread Starter
CadCaman
1983 CJ7
Supes, do you mind sharing with me the carb (model #) you are using with your Clifford intake? I also want to put the twin stick on my Dana 300. Was that a pretty easy application and where did you get it? I see them in the magazines but I am wondering if you found it elsewhere.
Thanks
Jeff
CadCaman is offline
post #5 of 12 Old 02-23-2012, 07:36 AM
Matt_G
1979 CJ5
^it's a holly. they make a specific carb that produces 390 cfm. it's also a four barrel. another option would be the motocraft 2bbl. 1.23 venturi make 356 cfm and 1.33 venturi make 424 cfm. super reliable and easy to tune. but it's a 2 barrel
"This isn't mud, it's a special Jeep Wax"
Matt_G is offline
post #6 of 12 Old 02-23-2012, 07:38 AM
swatson454
1983 CJ7
I'd go with the Holley. It has ports for manifold and ported vacuum and a PCV outlet. The Weber doesn't and I don't believe the adaptor does either so you'd have to drill the manifold to accept your PCV and again if you needed a manifold vacuum source.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #7 of 12 Old 02-23-2012, 08:16 AM
titomars
1981 CJ7
The Holley part numbers are:
390cfm 4 barrel 0-8007
470cfm T/A 4 barrel 0-90470
If your running a stock cam the 390cfm is a better choice.
titomars is offline
post #8 of 12 Old 02-23-2012, 08:30 AM
kaiter
kaiter is offline
post #9 of 12 Old 02-23-2012, 08:50 AM
swatson454
1983 CJ7
If you're going to factor CFM into your decision, you'll have to convert the CFM ratings of the two barrels to match that of the four barrel for a fair test. 1.5 inch depression for the Holley. The two-barrels are rated at 2.5 inches.
For example: a Weber 38 is rated at 390 cfm at a 2.5 inch depression. It flows 302 cfm when rated the same as a Holley four-barrel.
New Pressure (1.5) divided by Old Pressure (2.5)= 'X' (.6)
Square Root of 'X' = 'Y'
'Y' (.7746) times Old Flow (390)= New Flow (302.09)
Shawn
post #10 of 12 Old 02-23-2012, 08:58 AM
gosupes
Thanks
Jeff
What the other said about the carb. Clifford makes different adapters for their manifolds. If the one you are getting has the wrong one or missing altogether, give them a call.
The twin stick is easy to fab but I got mine from eBay. I found a listing for some guy not more than 30 miles from me. I figure if I'm going to spend some money, might as well keep it local if I can.
$130 for that header, can't go too wrong. Looks like people are pretty happy with them.
post #11 of 12 Old 02-23-2012, 11:57 AM Thread Starter
CadCaman
1983 CJ7
Tito, your everywhere.
Thanks
CadCaman is offline
post #12 of 12 Old 02-23-2012, 12:16 PM Thread Starter
CadCaman
1983 CJ7
Decisions are made
Thanks everyone for all your help. Here is the direction I am going:
4.0 Head (7120) being rebuilt now
Clifford Intake
APN exhaust
Holley 0-8007 carb
BTW Tito, my fuel injection plans have changed. I picked up a 304 block not too long ago and I am going to have it rebuilt with a new cam (which will take a lot of begging this forum for opinions) and then I am going to splurge on an Edelbrock MFI system to put on it. I will plan on swapping this during the next winter. I am going with the stock exhaust manifolds so I can keep the exhaust inside the frame (if possible).
Thanks again for everything guys,
Jeff
Couple pics to show my project.
CadCaman is offline
4.0 , 4.2 , carb , exhaust
ANOTHER 4.0 Head Conversion Post captkhaos Jeep CJ Forum 4 03-08-2011 07:56 AM
4.0 liter head conversion on a '79 cj7 capejeepguy67 Jeep CJ Forum 1 08-25-2010 04:57 PM
Have You Done the 4.0 Head Conversion? frodin1 Jeep CJ Forum 32 04-05-2010 10:01 PM
258 4.0 head conversion 5artist5 Jeep CJ Forum 3 11-03-2006 01:30 PM
4.2 to 40 head conversion gumby Jeep CJ Forum 3 07-17-2003 07:52 AM
