4.11 front 4.10 rear - JeepForum.com
post #1 of 20 Old 01-16-2013, 12:44 PM Thread Starter
dburnett7764
1980 CJ7
I've got my eye on a 4.11 d44 front axle for a swap in my CJ, the rear I will be using comes out of a rodeo its a d44 geared at 4.10. I have read through some forums and most people say its "close enough", but I wanted some input here.
Is running a 4.11 in front and a 4.10 in back going to cause me problems?
Thanks.
dburnett7764 is offline
post #2 of 20 Old 01-16-2013, 01:08 PM
Coiz
1979 CJ7
It will be fine. Old Bronco's came that way from the factory.
Mike
Coiz is offline
post #3 of 20 Old 01-16-2013, 01:21 PM
foggybottombob
You can use any combination of 4.11, 4.10 and 4.09 together front or rear. As long as the ratios are within 1% of each other they work together.
foggybottombob is offline
post #4 of 20 Old 01-16-2013, 01:29 PM
thefro68
1979 CJ7
Agreed!!
Wife: "Just spend the money and do it right the first time!!"
Jeff
1979 CJ7
thefro68 is offline
post #5 of 20 Old 01-16-2013, 01:34 PM
CSP
Your difference is only 0.2% ((4.11-4.10)/4.10). Your tires can be further off than that with one having different pressure than the others.
CSP is offline
post #6 of 20 Old 01-17-2013, 03:31 PM
agear
Also I saw on the tv show on spike called Xtreme 4x4 that it's fine and they did it.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #7 of 20 Old 01-17-2013, 03:44 PM
ZeroGravity
I wouldn't take a program on spike as the absolute truth...
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #8 of 20 Old 01-17-2013, 04:17 PM
Tigerjeep79
1979 CJ7
I'm running 3:50 in the rear and 3:54 in front. No problems.
Tigerjeep79 is offline
post #9 of 20 Old 01-18-2013, 08:34 AM
yahwhy
1982 CJ7
I talked with a guy from complete offroad, he said you can be with in numerically 7 on ratios.
I am running 4:10 front, 4:11 rear with no problems.
yahwhy is offline
post #10 of 20 Old 01-18-2013, 12:32 PM
AFRd_CJ5
1976 CJ5
We run in the sand, but we intentionally stagger the gearing. I run 4.88 rears/4.56 fronts. Dad runs 5.38 rear/4.88 front.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #11 of 20 Old 01-18-2013, 03:52 PM
kidmartinek
1978 CJ7
I run 4.88 front and 4.86 rear, no problems after 13 yrs.
kidmartinek is offline
post #12 of 20 Old 01-18-2013, 03:57 PM
cheftrail
What are the benefits of this, and is it only in sand? Also, does it matter which is taller? Front, or Back?
cheftrail is offline
post #13 of 20 Old 01-19-2013, 02:41 PM
agear
Why not ?
agear is offline
post #14 of 20 Old 01-19-2013, 05:21 PM
foggybottombob
Because an auto repair program on spike TV is in the business of selling you something.
post #15 of 20 Old 01-19-2013, 06:00 PM
lucdog
lucdog's Avatar
1980 CJ5
I believe the front tires spinning faster helps with steering in sand.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
