4:10's - JeepForum.com
post #1 of 10 Old 06-06-2002, 10:45 PM Thread Starter
hollywood
Post 4:10's
Is anyone running 4:10's with 33's behind a T-5/258? Can you still do 50-55 mph at a reasonable rpm? I need to replace my 2:73's and I'm looking for advice. This is not my daily driver - it sees more dirt than street, but I'd still like it to be drivalble on the longer rides to the trail heads. Thanks
- Jeff
'83 cj
Another 7 by "CJ's Heaven"
hollywood is offline
post #2 of 10 Old 06-06-2002, 10:48 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by hollywood:
<strong>Is anyone running 4:10's with 33's behind a T-5/258? Can you still do 50-55 mph at a reasonable rpm? I need to replace my 2:73's and I'm looking for advice. This is not my daily driver - it sees more dirt than street, but I'd still like it to be drivalble on the longer rides to the trail heads. Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">I'm running 4.56's with 33's and an NV4500 - turn 2500 rpm @70 mph. This is with an AMC 360 engine.
Steve
OldJeepguy is offline
post #3 of 10 Old 06-07-2002, 09:33 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Post
<strong>Is anyone running 4:10's with 33's behind a T-5/258? Can you still do 50-55 mph at a reasonable rpm? I need to replace my 2:73's and I'm looking for advice. This is not my daily driver - it sees more dirt than street, but I'd still like it to be drivalble on the longer rides to the trail heads. Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">LOL, if it weren't for the stupid CAFE standards back then, I'm sure we would have never seen those useless 2.73's in any CJ axles
What a useless ratio for a Jeep! Anyway, I may be looking to upgrade also in the future. My '77 CJ7 below in sig, has 3.54s and I will be running 33s soon and have a 1972 AMC 360 in it.
4wheeler4CJ is offline
post #4 of 10 Old 06-09-2002, 08:38 PM
KG4PAM
Post
this a newbie question probably, but how do i tell what gear ratio i have? count the teeth and do a proportion calculation, or what? thanks
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #5 of 10 Old 06-09-2002, 09:37 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by KG4PAM:
<strong>this a newbie question probably, but how do i tell what gear ratio i have? count the teeth and do a proportion calculation, or what? thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Rotate your tire exacly one turn while counting the revolutions of the pinion - in my case for every tire rotation the pinion turns about 4.5 times since my ratio is 4.56:1
Steve
post #6 of 10 Old 06-10-2002, 01:42 AM
cj7traildriver
Post
If you do the turn method to figure the gear size you have to have both rear tires turn so if lockered or posi will work if not will need a friend to help and has to be out of gear. That way gets you in the ball park the other way is count teeth on ring gear and divide by number of teeth on pinion gear to get actualy size.
Jeep what else matters.
cj7traildriver is offline
post #7 of 10 Old 06-11-2002, 12:52 PM
4wheeler4CJ
Thumbs up
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by cj7traildriver:
<strong>If you do the turn method to figure the gear size you have to have both rear tires turn so if lockered or posi will work if not will need a friend to help and has to be out of gear. That way gets you in the ball park the other way is count teeth on ring gear and divide by number of teeth on pinion gear to get actualy size.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">What he said. If you have an "open differential" (not locked or posi), when you rotate one wheel, the other will turn opposite. You have to rotate the other side the same or do it rolling the vehicle in neutral on the ground (both wheels rotating the same).
post #8 of 10 Old 06-11-2002, 03:23 PM
Jeep Daddy
Jeep Daddy's Avatar
Post
Try these two links for info on axles.
<a href="http://www.off-road.com/jeep/tech/axle/" target="_blank">More axle stuff</a>
<a href="http://www.off-road.com/jeep/swb/articles/specgrid.htm" target="_blank">Axle stuff</a>
Just read the tag on the front axle; it should tell you. The AMC 20 is a little more tricky because it uses a code. I believe mine says B on it and that is a 3.31 ratio.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #9 of 10 Old 06-11-2002, 08:05 PM
Jeep Daddy
Jeep Daddy's Avatar
Smile
All the stuff I've read says that with 33's and T5/258 us 4.10 gears for best all around power.
post #10 of 10 Old 06-11-2002, 11:21 PM Thread Starter
hollywood
Post
Thanks Jeep Daddy, that's all I wanted to hear.
For everyone else:
On a wide track Dana 20 -
D = 2.73
B = 3.31
A = 3.54
H = 3.73
C = 4.10
Any double letter, such as "DD" means Trac-lok with that letter's ratio. This will be stamped on the flat area to the right of the diff cover.
- Jeff
'83 cj
Where to buy 4.10's?? JeepnBlake Jeep CJ Forum 5 05-04-2009 11:17 AM
4:10's with 33's dblock16 Jeep CJ Forum 8 10-09-2007 12:10 AM
4.10's or 4.56 thenubsterman Jeep CJ Forum 6 10-12-2006 08:02 PM
