4.0L swap - JeepForum.com
post #1 of 9 Old 05-22-2011, 05:03 AM Thread Starter
hotrodzgarage
I know, I had to come up with some different washers the intakes aren't the same spacings. I will watch for the and add the other gasket if needed.Thx
Have You Ever wheeled with the Devil by the pale moonlight?
hotrodzgarage is offline
post #2 of 9 Old 05-22-2011, 05:04 AM
gojeepin
1983 CJ7
Originally Posted by hotrodzgarage View Post
Nope just used the stock 95 4.0L exhaust/intake gasket. The pump bracket still uses the two bolts on the water pump and the two on the block has plenty of strength still no movement at all.
I did that at first but I developed an intake leak. The flanges on my intake and exhaust are different thicknesses. The single gasket couldn't seal them both.
Edit: is it just me or did this thread get inverted somehow? This should have been post #8.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 9 Old 05-22-2011, 06:12 PM Thread Starter
hotrodzgarage
4.0L swap
4.0L swap
I just did a 4.0l swap in my wifes 1982 CJ7. I started at about 9am saturday morning had it running at 7pm that night. Hooked up the exhaust and timed it this morning. This runs so much better then the 251k 4.2L that was in there. Here are some pics.
post #4 of 9 Old 05-22-2011, 06:18 PM
gojeepin
1983 CJ7
That's an interesting way to do the power steering pump bracket...
Did you use both the intake and exhaust gaskets when you mounted the manifolds?
Which Weber are you running?
gojeepin is offline
post #5 of 9 Old 05-22-2011, 06:23 PM Thread Starter
hotrodzgarage
post #6 of 9 Old 05-22-2011, 06:39 PM
KUJeeper82
KUJeeper82's Avatar
Why'd you keep the carb? Fuel Injection >> carb...
2007 Jeep Grand Cherokee Overland w/ 3.0L CRD & QDII):
Installed: GDE Hot Tune,CB DPF Delete Pipe, 285/70/17 GY Duratracs, 4" SuperLift
Future Mods:
ARB Winch Bumper, Crawler Rear Bumper/Tire Carrier
1985 Jeep CJ7:
105k miles, 4.0L H.O. I6, AX-15, Dana 300, 4" BDS, Moser 1-pieces, Detroit AMC 20, Truetrac Dana 30, 4.56 regear, 33x12.50x15 BFG MTs
KUJeeper82 is offline
post #7 of 9 Old 05-22-2011, 06:59 PM Thread Starter
hotrodzgarage
I know the fuel injection would have been better, but my budget and time restraints meant keeping the weber carb. this is my wife DD and so I only had the weekend to do it. I have the FI intake and brackets so we will do a FI swap when time and money allows.
post #8 of 9 Old 05-22-2011, 08:54 PM
gojeepin
1983 CJ7
Well, here's one of the threads that got mangled and thrown back in time.
gojeepin is offline
post #9 of 9 Old 05-22-2011, 09:30 PM Thread Starter
hotrodzgarage
I saw that how wierd
4.0 , 4.2 , cj7 , swap
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
Pros and cons of 360 swap versus 304 swap SilverRubiSC Jeep CJ Forum 19 10-12-2009 11:36 PM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 07:31 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
I need a little help from all with SBC swap Ezredcj Jeep CJ Forum 3 12-23-2004 08:30 AM
