4.0L into 4.2L ?? - JeepForum.com
post #1 of 3 Old 01-15-2002, 10:46 PM Thread Starter
clint_black_jeep
Post 4.0L into 4.2L ??
I'm thinking of swapping a late-model 4.0 into my tired 258-powered ride... Any of you guys ever tried this at home? Successfully? Any tips/advice would be appreciated. This would help me pass any unforseeable emissions tests, improve mpg and cold starts, & maybe boost the hp a little.
Thanks-
'85 CJ-7, bone stock exc. 2" shackles & Skyjackers. Engine is 258 (for now). Nutter bypass.
"Just because you're not paranoid doesn't mean they ain't out to get you"
clint_black_jeep is offline
post #2 of 3 Old 01-16-2002, 12:19 AM Thread Starter
clint_black_jeep
Post
Sorry, guys, that shoud have been under engines...
post #3 of 3 Old 01-17-2002, 08:26 PM
hamyscj
Post
I am in the process of doing this right now. However, I cheated alittle because I had the mopar MPI kit on my 4.2. I had all the wiring and intake already set up. There are a few things you need to know. First, plan on using the 4.0 accessories. ie power steering, alt, A/C, etc. The 4.2 accessories will not fit. Esp the P/S. The motor mounts and bell housing to block bolts are a perfect match. The only thing I had to do was to use a 7/16 bolt on one hole of the left mount into the block. For some reason it was tapped different. Unless you buy a bellhousing with the sensor mount on it, you will need to fab a bracket for the crank sensor. You will need to get a bronze pilot bushing for the trans of the CJ machined down to 1 inch OD in order to fit into the crank of the 4.0. There are probably some things that I am missing so if you have questions, feel free to email me. Hamy.
One Way Up Racing
Romans 10:9
hamyscj is offline
