4.0l into 1985 cj7 - JeepForum.com
post #1 of 8 Old 04-11-2005, 10:11 AM Thread Starter
sude thug cj7
4.0l into 1985 cj7
I am swapping in a 4.0,5 speed, and transfer case from a cherokeeand was wondering if anyone else has done this and how well it worked for them. I also plan to use my stock axles for now, someday I will be doing a 4 link and use tj lift springs on it.
sude thug cj7 is offline
post #2 of 8 Old 04-11-2005, 12:49 PM
mxg342
mxg342's Avatar
Make sure the transfer case drop is on the same side!!!
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #3 of 8 Old 04-11-2005, 09:34 PM
jeepskate
Ummm...yeah...somebody didn't think this through/do their research...
jeepskate is offline
post #4 of 8 Old 04-12-2005, 10:21 AM
75SV1
The Dana 300 is suppose to mate up to the AX-15 with a clocking ring. It will also mate up to the NV3550 if you redrill the tailhousing. I am in the process of that one. If you use a clocking ring on a NV3550, then Advanced Adpaters sells a kit with a longer input shaft. There about a 1/2 difference in output shafts for the NV3550 and AX-15. I hope he's not using a BA-10/5.
Tom
75SV1 is offline
post #5 of 8 Old 04-12-2005, 11:06 AM
Sprungover
http://www.cjoffroad.com/forums/forum.asp?FORUM_ID=24
Check out this site. It is by far the best resource for this information.
Sprungover is offline
post #6 of 8 Old 04-15-2005, 07:54 PM Thread Starter
sude thug cj7
Okay I now see the differential issue,so I got a set of axles with 411 gears and a complete drivetrain with computer and harness thanks for the help.
post #7 of 8 Old 04-15-2005, 08:08 PM
jeepskate
I hope you're not saying that you bought a set of Wrangler axles to go with the drivetrain. If so, you just wasted your money...
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
post #8 of 8 Old 04-16-2005, 08:19 AM Thread Starter
sude thug cj7
I got 3/4 ton axles from a dodge I think its a 97 or 98
1985 cj T5 transmission Scottie Jeep CJ Forum 0 11-05-2009 09:38 AM
New 1985 CJ7 redman1567 Jeep CJ Forum 24 03-18-2009 02:23 PM
Need help with 1985 CJ7 Restore blackcj71999 Jeep CJ Forum 3 01-07-2008 07:19 AM
1985 Cj7 BeatAChevy289 Jeep CJ Forum 7 06-28-2007 10:57 AM
1985 Cj7 Shenck Jeep CJ Forum 2 10-27-2005 04:40 AM
