4.0L HO head swap w/ MPFI - Page 2 - JeepForum.com
post #16 of 56 Old 09-13-2013, 11:40 AM Thread Starter
tripster_sta
1979 CJ5
Wow that's a lot of info. Thanks Matt. I have a ton of research to do before I make up my mind.
Come to California they said....
Sent from toilet at work
tripster_sta is offline
post #17 of 56 Old 09-13-2013, 12:09 PM
Gigemags05
1980 CJ7
I used the hesco harness when I swapped a 4.0 into my cj. I've been very pleased. It was about $500.
Gigemags05 is offline
post #18 of 56 Old 09-13-2013, 12:10 PM
gmakra
I would call Bernie at Hesco and see if they have the old MPI kit that is CARB compliant.
gmakra is offline
post #19 of 56 Old 09-13-2013, 12:10 PM
SLO_Ken
FWIW, I'm going through an engine swap in my CJ in California right now. Here's a link to the thread... http://www.jeepforum.com/forum/f8/ca...-swap-1530716/
I haven't got to the referee yet, but I'll document that as well.
So far it seems pretty straightforward as far as what is required, based on the BAR information Matt provided earlier.
Also, the Mopar MPFI system for 258's is CARB compliant. http://arb.ca.gov/msprog/aftermkt/de...eo/D-265-7.pdf
http://www.summitracing.com/parts/dc...10ae/overview/
SLO_Ken is offline
post #20 of 56 Old 09-13-2013, 12:29 PM Thread Starter
tripster_sta
1979 CJ5
I see that the air resources board only approved it for '81 to '83 and Mopar only had the kits for those years models too. So do you know if that will work in my 79?
post #21 of 56 Old 09-13-2013, 12:32 PM Thread Starter
tripster_sta
1979 CJ5
Will do! I want to be mpfi and carb compliant.
post #22 of 56 Old 09-13-2013, 12:46 PM Thread Starter
tripster_sta
1979 CJ5
The hesco 50 state mpi kit is $2,680. That's a little to rich for my blood.
Next and hopefully my last question.
What year and model can I pull a mpi junkyard kit for my 258?
Btw thanks for everyone's input, I'm on here for a good reason. You guys give excellent advice and in a timely manner.
post #23 of 56 Old 09-13-2013, 12:53 PM
SLO_Ken
I am not familiar with the differences between your '79 and the later '81-up engines, other than the addition of the computer controlled carb in the early '80s. It may be that the '81-up had an O2 sensor bung cast into the exhaust manifold, and the earlier engines didn't have that.
If that's the case, and Mopar wanted this to be a true "bolt-on" system, then they did not apply for CARB certification on older models where the O2 bung would need to be welded into the exhaust.
So, to answer your question, it should work on your '79 with the added step of welding an O2 sensor bung into your exhaust close to the manifold.
SLO_Ken is offline
post #24 of 56 Old 09-13-2013, 12:54 PM
CSP
Originally Posted by Matt1981CJ7 View Post
Seriously though, it's odd to me that so many guys Nutter their engines to get rid of the troublesome computer, then turn around and stick another computer on it with FI.
It's not the computer that's troublesome with the BBD feedback carb. It's all the crap it's supposed to control and/or the sensors that feed it.
What is it that contols your Tundra?
While that may be all that it takes to make it physically work, if the CARB cerfitication is only for 81-83 then it will not be emissions legal on a '79.
CSP is online now
post #25 of 56 Old 09-13-2013, 01:01 PM
SLO_Ken
In California, legally, any changes you make to the engine that do not have CARB certification will need to be inspected by a smog referee.
That said, you'd probably want to look for a '91-'95 Jeep Wrangler or Cherokee with the 4.0 engine. This will be an OBDI system that the Hesco and Mopar systems are based on. You can use just the intake (with all the associated sensors, wiring, and computer), the head and both manifolds, or the entire engine.
SLO_Ken is offline
post #26 of 56 Old 09-13-2013, 01:07 PM
SLO_Ken
True, until he takes it to a smog referee who will inspect it and, more than likely, give him the required documentation and "seal of approval."
The CARB Certification system exists so that every engine modification does not have to be individually inspected for approval. However, that inspection program still exists for those modifications that are outside-the-box. I think that since this is a minor modification to allow a pre-qualified system to be fully functional on the existing engine, it should be pretty straightforward...
should...
tripster, while you are still in the research phase, you may want to get a hold of a smog referee in the San Diego area and see exactly what would be required for any of your proposed scenarios. Since you are active military, there may be legal exceptions that you can take advantage of.
SLO_Ken is offline
post #27 of 56 Old 09-13-2013, 01:09 PM Thread Starter
tripster_sta
1979 CJ5
Ok thanks Ken. I'll go that route using my 258 block, and then let the smog nazis have their fun.
After all is said and done I think I'll be pretty legal and happy with the results, but not my pockets
I skimmed your thread, looks daunting but doable, so I will probably be refrencing it a **** ton during my build.
post #28 of 56 Old 09-13-2013, 02:26 PM
SLO_Ken
Please note that I am doing an OBDII swap from a '98. The OBDII has a few more sensors than the OBDI, and the check engine light (required in CA) does not connect straight to the ECM, so the gauge cluster from the donor is required...
The reasons I chose to go with the OBDII are twofold:
1) It was far easier to find parts for the newer OBDII system.
2) The diagnostic capabilities provided by OBDII are so much better than OBDI.
SLO_Ken is offline
post #29 of 56 Old 09-13-2013, 02:31 PM Thread Starter
tripster_sta
1979 CJ5
Ok roger that thanks for your input. Making tons of notes!
post #30 of 56 Old 12-02-2013, 08:24 PM
W7NB
I did the 4.0 HO swap (From a 91) in my CJ. I bought a wrecked Cherokee for $550 bucks and sold the parts I didn't need for $500, so an engine and tranny for $50 seems like a pretty good deal. I bought the Hesco wiring harness for ~ $500 which made the install pretty much plug and play. Since it's a newer motor and I installed it wit all the factory emission stuff it should pass the test in California.
°lllll° Am I broke yet??
1985 CJ7 With HO 4.0 Conversion
2013 JK
W7NB is offline
