4.0L HO head swap w/ MPFI - JeepForum.com
post #1 of 56 Old 09-12-2013, 07:57 PM Thread Starter
tripster_sta
1979 CJ5
I'm looking to do this to my 79 258 after I get back from deployment. I am only in the research phase right now, and I am reading everything this forum has to offer but.....
There are so many threads to go over and it just confuses me more.
So if anyone can help me out I'm looking for a thread that goes through the complete setup. From what parts to pull from a junkyard or buy new, what to look for, and of course the installation. Basically breaking it down barney style for this not so skilled, beer driven, at home, auto mechanic.
I apologize if you came here for a build thread, but give me about 7 months and it will be.
Sent from toilet at work
tripster_sta is offline
post #2 of 56 Old 09-13-2013, 06:40 AM
gmakra
Here is my thoughts on this. If you have the money get the Hesco kit it has everything you need to do the install. Its very simple and it can be done in a weekend.
http://www.hesco.us/products/21873/j...t#.UjMGQT-ga5Q
If you go the junkyard route you can get the stuff cheaper however the parts are becoming harder to find and it takes time and patience since you need to make different parts to work.
gmakra is offline
post #3 of 56 Old 09-13-2013, 07:38 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
$2450!?!? Holy bend over Batman!!
Matt
Matt1981CJ7 is offline
post #4 of 56 Old 09-13-2013, 07:48 AM Thread Starter
tripster_sta
1979 CJ5
$2450??? Wow. The only reason for this is because the wif won't let me drop in a 350 SBC so this is the next best/cheaper* thing.
post #5 of 56 Old 09-13-2013, 08:41 AM
titomars
1981 CJ7
Matt
Yeah really. If you notice it is not CARB compliant. so most of us Californians can't use it. For 2,500.00 bucks I'd expect a CARB sticker.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #6 of 56 Old 09-13-2013, 08:43 AM
Matt1981CJ7
1981 CJ7
Me too.
That price makes the Howell kit seem almost reasonable by comparison.
Matt
post #7 of 56 Old 09-13-2013, 09:10 AM
gmakra
While the price is high it does have several advantages over the Howell kit. 1 it is multi port fuel injection and it controls timing and is programmable. This is huge in starting, HP, mileage!
Hesco has trouble finding computers for thier kits so they went with the Acell programmable computer.
The Howell kit is a glorified carb and dose not control timing it also has to have a problematic adapter that is prone to leaks and that drives alot of people nuts. My personal experience with the Howell kit is a carb is actually better.
You can go junkyard but you will spend a lot of time figuring out how to make it work. Different model years require different wiring and thats why use see so much variation in write ups.
gmakra is offline
post #8 of 56 Old 09-13-2013, 09:17 AM
aggiejon
1979 CJ7
Can't help you on carb nonsense for Kommifornia, but from someone who performed the junkyard version of the swap for around $500, I can help you with what I did.
Search the yj forum for a user named cevans. He is whose swap I used. My swap took about six months as time and lunch money allowed. I bought some stuff and swapped old stuff and parted stuff. So the cost was very reasonable, but not fast.
Personally, I am not a fan of the hesco kit.and before I get lambasted, allow me to explain why...you need a part. Our jeeps are stepchild produced enough from the factory - amc this, Chevy and ford that. I carry a parts cheat sheet with me because I have parts from various years and manufacturers of components on my swap. My parts guy rolls his eyes when I walk in.
But you are likely to be able to find on the shelf or get quickly any of those parts at a parts house in your town 7 days a week. There is only one hesco. And as I learned with a cnc machine that I own, which has proprietary developed systems, if they go under, good luck finding parts!
If you go the junkyard route, I can help you out. It was scary, especially hooking up all the sensors and clipping wires off the engine harness. But I did it, and it was surprisingly easy and straightforward. I downloaded off google the wiring diagrams and bulkhead connector pinouts, put them on 11x17 paper, and just sat down with a beer and good light, and wire clippers.
I also did not use the CPS relocation kit. I drilled my bell housing, and built a bracket, thanks to a diagram provided by Marty86CJ. Could have pooped my britches when the thing cranked and ran like a top the first time I hit the key.
Best mod I've ever did!
Now if you are planning to stay in Cali, well, all bets are off on that!
aggiejon is offline
post #9 of 56 Old 09-13-2013, 09:30 AM
Matt1981CJ7
1981 CJ7
I follow these threads only because I worry that emissions will eventually hit my county, and I'll be forced to use the Howell kit to comply.
That said, the whole FI thing goes against the reason I love my CJ. To me, a CJ represents the ultimate utility vehicle that the average joe mechanic can fix with a simple set of tools. Plugging a CJ into a computer to diagnose a problem just rubs me the wrong way.
Of course, I'm an old fart who doesn't have any problems getting a carb to work for me. I can still do long division without a calculator, too.
Matt
post #10 of 56 Old 09-13-2013, 09:56 AM
gmakra
Matt I know ya and all your faults such as being a Broncos fan, an architect who still uses a Tee Square and if you had your way instant messaging would involve stone tablets and a trebushet. (look it up if you dont know what it is)
However since you run a 360 a Howell kit would work on an eight much better than it does on an I-6.
gmakra is offline
post #11 of 56 Old 09-13-2013, 10:53 AM
Matt1981CJ7
1981 CJ7
Hardy, har, har....
If it weren't for us old farts, you young bucks wouldn't even exist. Remember that.
Seriously though, it's odd to me that so many guys Nutter their engines to get rid of the troublesome computer, then turn around and stick another computer on it with FI.
Anyway, sorry for the highjack. Carry on.
Matt
post #12 of 56 Old 09-13-2013, 10:57 AM Thread Starter
tripster_sta
1979 CJ5
So what yall are saying is the head swap and mpfi are not CARB compliant?
I'm running the carter bbd I rebuilt. So I'm pretty familiar with that setup, but I have none of the emmisions equip hookuped.
And it's being a PITA to find components ie. smog/air pump and bracketry.
I need the smog cert for a base decal when I get back from the sandbox, so I figured I would go ahead and do the 4.0 swap and mpfi. This way I wouldn't have any problems.
post #13 of 56 Old 09-13-2013, 11:03 AM
Matt1981CJ7
1981 CJ7
That's correct. You will not pass emissions in Cali with the MPFI.
Matt
post #14 of 56 Old 09-13-2013, 11:10 AM Thread Starter
tripster_sta
1979 CJ5
Well ****, guess I'll do it anyway and drive to MCAS Yuma and get a sticker or convince the wife a SBC is is worth it.
post #15 of 56 Old 09-13-2013, 11:26 AM
Matt1981CJ7
1981 CJ7
You probably will not pass with an SBC, either, but others will know more than I do.
Cali has CJ owners by the short hairs....
Engine Change Guidelines
OVERVIEW
Engine changes continue to present problems and challenges to car owners and technicians. Here are some tips to keep you and your customers on the straight and narrow.
Our recommendation is to rebuild and reinstall the original engine, transmission, and emission control configuration.
When rebuilding an engine, it must be rebuilt to the original equipment specifications. However, if you do decide to change the engine, these guidelines must be observed to ensure that the vehicle will be eligible for smog certification or registration.
Remember, these are guidelines for performing engine changes – not certification procedures. All exhaust emission controlled vehicles with engine changes must be inspected by an official referee station and must have a Bureau of Automotive Repair (BAR) Vehicle Identification Label affixed to the doorpost.
Remember also, state and federal anti–tampering laws generally prohibit any modification to the vehicle's original emission control system configuration as certified by the manufacturer. And, Section 3362.1 of the California Code of Regulations prohibits any engine change that degrades the effectiveness of a vehicle's emission control system.
CALIFORNIA CERTIFICATION
A federal Environmental Protection Agency (EPA) certified (federal or 49–state) engine cannot be used in a vehicle that was originally certified for California.
CERTIFICATION STANDARDS
Make sure the engine and emission control configuration on exhaust – controlled vehicles are certified to the year of the vehicle or newer, and to the same or a more stringent new vehicle certification standard.
CLASSIFICATION
Don't mix engine and vehicle classifications which will degrade the emissions certification standards. For example, a heavy–duty engine cannot be installed in a light–duty exhaust–controlled chassis even if they have the same displacement. Non–emissions controlled power plants such as industrial or off–road–use–only engines may not be placed in any exhaust–controlled vehicle.
COMPUTER CONTROLS
If a computer–controlled engine is installed in a non–computerized vehicle, the "CHECK ENGINE" light, the Original Equipment Manufacturer (OEM) diagnostic link, and all sensors, switches, and wiring harnesses needed to make the system fully functional must also be installed.
EMISSION CONTROL CONFIGURATION
Mixing and matching emission control system components could cause problems and is generally not allowed. Engine and emission control systems must be in an engine–chassis configuration certified by the California Air Resources Board (ARB) or U.S. Environmental Protection Agency (EPA). The engine must meet or exceed the requirements for the year and class of vehicle in which it is installed.
EMISSION WARRANTY
Voiding the vehicle manufacturer's emission warranty is not allowed.
ENGINE MODIFICATIONS
No internal or external engine modifications (cams, pistons, intakes, etc.) may be performed unless the parts are ARB–exempted or EPA–certified for use in the installed engine. Use the database on this site to search for aftermarket parts covered by ARB Executive Orders.
ORIGINAL EQUIPMENT
The installed engine and host chassis must retain all of their original emission control equipment. Diesel–to–gasoline conversions must have all gasoline engine and chassis emission control systems installed (such as fillpipe restrictor, catalytic converter and evaporative emission system).
SMOG INSPECTION
These vehicles must pass a complete smog inspection (visual, functional, and tailpipe).
Good luck,
Matt
