4.0 swap/VSS wiring - JeepForum.com
post #1 of 6 Old 04-21-2012, 08:05 AM Thread Starter
ymurf
1979 CJ7
4.0 swap/VSS wiring
I put a 94 4.0 from a YJ in my 78 CJ7 with the AX15 and a Dana 300. I bought a 91 YJ Speed sensor and it has a two wire hook up.The wiring for the Speed sensor from the 94 4.0 has three wires. I bought the 3 to 2 wire conversion plug from Hesco..Which two out of the three do I hook up?
ymurf is offline
post #2 of 6 Old 04-21-2012, 09:16 AM
1986cj
I have copied this from cjoffroad, never tired it but guys say it works. The Early 2 wire VSS is a simple mechanical switch, it makes and breaks a set of contacts internally using magnets and a reed switch. One wire is from the PCM which has a 5 volt reference internally, the other is the sensor return. When the 5 volts drops to ground, the PCM senses a trigger.
The later 3 wire VSS uses a Hall effects switch to make and break the connection between the sensor return wire and the ground wire. The 3rd wire is a 5-8 volt power supply to operate the hall effect sensor.
The 3 wire sensor colors are usually:
Wt/Bk = 5-8v supply
Wt/Or = Sensor return (signal to PCM)
Bk/LB = Common sensor Ground
With the 2 wire sensors, just connect the 2 wires to the Bk/LB and Wt/Or wires from the harness, you can disregard the Wt/Bk = 5-8v supply wire, it's not needed! It doesn't even matter which wire you connect to which pin on the 2 wire VSS, (but if the colors match, connect them!)
Hope this helps!
1986cj is offline
post #3 of 6 Old 04-21-2012, 12:54 PM Thread Starter
ymurf
1979 CJ7
Wt/Bk = 5-8v supply
Hope this helps!
Thats better than anything else I have found..Mine has an orange,A white with orange stripe and a black with blue stripe.So I am guessing I would disregard the orange wire?? Anyone else agree?
ymurf is offline
post #4 of 6 Old 04-21-2012, 01:06 PM
1986cj
If I remerber right may have been from Marty So Cal, but not real sure. He hangs out over on priate and is real good with mpfi. The way I understand it is "you can disregard the Wt/Bk = 5-8v supply wire, it's not needed!"
Take a volt meter and see witch one has 5-8v and dont use it.
1986cj is offline
post #5 of 6 Old 04-21-2012, 01:11 PM Thread Starter
ymurf
1979 CJ7
I made a post over there this morning but no response.
ymurf is offline
post #6 of 6 Old 08-03-2012, 04:04 PM
Jak_Flash
Is the 2 wire hookup from the 91 vss considered a 2 pole vss? I'm in need of one for my 5.7tbi swap.
Jak_Flash is offline
4.0 swap wiring help rockzilla Jeep CJ Forum 12 07-28-2011 12:13 AM
4.0L Swap Wiring...Help! 81jeeper Jeep CJ Forum 4 06-06-2010 01:08 PM
258 to 360 swap. Help with wiring. jaybird106 Jeep CJ Forum 4 12-18-2008 09:45 AM
Wiring 4.3 swap Redmanchew Jeep CJ Forum 8 02-27-2007 03:18 PM
4.0 swap wiring help gary68 Jeep CJ Forum 1 12-09-2006 08:30 PM
