4.0 swap speedometer not working - JeepForum.com
post #1 of 8 Old 04-07-2013, 07:14 AM Thread Starter
Gigemags05
1980 CJ7
Engine is running great, but the speedometer isn't working.
I used a new vss for a 91 yj, and bought an adaptor so the threads will match. I am using Hesco's harness.
Any ideas on why it might not be working?
Does anyone have pictures of how the vss should fit onto the speedometer cable?
Also, when installing, I pulled the small gear out. I put it back in but is it possible it isn't seated right? I figured it'd only go in one way with the teeth how they are.
Gigemags05 is offline
post #2 of 8 Old 04-07-2013, 08:53 AM
frhrwa
Fish'n Fool
frhrwa's Avatar
sounds like the gear in the tranny or the cable .. most likely the gear..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #3 of 8 Old 04-07-2013, 09:01 AM Thread Starter
Gigemags05
1980 CJ7
Is there a specific way it has to go into the tranny? I'm sure that's the problem since I removed it. Any trick to it?
post #4 of 8 Old 04-07-2013, 11:32 AM
frhrwa
Fish'n Fool
frhrwa's Avatar
how would you like a JEEP FSM manual on a DVD that covers '81-'87.. but the tranny and speedo connection should be the same and most of the info will match up.. I can mail you a copy if you pm me name and address.. wayne (it helps a lot, sorry its not the '80 version)..
frhrwa is offline
post #5 of 8 Old 04-07-2013, 12:41 PM
titomars
1981 CJ7
If you are running the original trans yes it has to indexed correctly in the trans housing. The speedo gear sleeve (adapter) has lines and numbers marked around it's face. To line up and mesh the gear by its tooth count.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #6 of 8 Old 04-07-2013, 12:50 PM Thread Starter
Gigemags05
1980 CJ7
Thank you very much for the offer. I have an fsm for the cj, and when the 4.2 was in it, the speedometer worked great. But since I had to use a new vss and an adaptor for the 4.0 it isn't working now.
post #7 of 8 Old 04-07-2013, 12:52 PM Thread Starter
Gigemags05
1980 CJ7
Ok, so there will be markings on the speedo gear I pulled out? I'm sure I put it back in the wrong way.
post #8 of 8 Old 04-07-2013, 08:10 PM Thread Starter
Gigemags05
1980 CJ7
There weren't any marks, but I was able toget the gear in correctly and the speedometer now works.
