4.0 swap into 82 cj8 advice - JeepForum.com
post #1 of 5 Old 11-29-2012, 08:25 PM Thread Starter
gingermesiah
1982 CJ8
I have read so many swamp threads I think i'll drown. I understand the process of the install and all. So my question is, If I have a fully running 97xj with 117k 4.0 manual. My cj8 is and 82 4.2 (fried) 300 transfercase and I think a 32rh auto transmission(swaped in by po). Can I swap over the engine, transfercase, transmission and axles without having to worry about rotating the transfercase? I realize the xj's axles are not any better, so either way would be fine for a dailey driver? Or should I go with a 95xj manual with 150k for half the price?
gingermesiah is offline
post #2 of 5 Old 11-30-2012, 12:26 AM
jeepwhore
Could it be done? Sure. But why? The XJ manual trans will bolt to the D300 quite easily. Then you could keep your axles and avoid the fab work of converting the coil sprung XJ D30 to leafs and/or using the inferior NP231 tcase instead of the D300.
As for which 4L to use, the 95 and prior are easier to wire....and when it comes to electrical I like to KISS!
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #3 of 5 Old 11-30-2012, 07:57 AM Thread Starter
gingermesiah
1982 CJ8
thank you, most the xj's with manual that I'm looking at are around 150,000, should I have the head reworked before reinstall? There are a few xj/grands out there with bad transmissions but motors around 120,000, I would have to find a seperate tranmission. Which means I would have to find a ecu to match the year and type of transmission, right? Are all the obd 1 harnesses the same or do they change per transmission type/yr? Is there a better manual transmission that will bolt up than the ax15 for a around town jeep? I believe I currently have a 32rh automatic transmission and a D300 transfer case, if that makes a difference? Is the 300 or the 242 better for normal driving and some very minor off roading?
post #4 of 5 Old 11-30-2012, 10:12 AM
jeepwhore
I've seen many 4L's run past the 215,000 mile mark. If the engine you plan to swap in has been well maintained I wouldn't worry about it. As far as I know the harnesses are the same regardless of transmission type. Depending on what a Jeep was equipped with, there may be some wires not used in the harness (I think even 4 bangers use the same harness, but only use 2/3 of the injector wiring).....but don't quote me on it.
As for transmissions, I'm partial to a manual and have an AX15 sitting here waiting to go in some day. If you decide thats what you will use try and get one from '94 and up as they have the external clutch slave. There are other options like the NV3550 but it seems the AX15 is cheaper and easier to come by.
And I'd take a gear driven t-case (D300) over a chain drive (NP242, 231 etc.) any day of the week regardless of intended use.....but that's just me.
:-D
post #5 of 5 Old 11-30-2012, 07:40 PM Thread Starter
gingermesiah
1982 CJ8
Thanks the the advice, think I'm going to go look at a 95 xj tomorrow. Should be able to get a good deal
4.0 , axles , cj , swap , xj
