4.0 swap: fuel line connections - Page 2 - JeepForum.com
post #16 of 19 Old 03-21-2013, 11:45 AM Thread Starter
Gigemags05
1980 CJ7
I've got a hard line that runs from the tank all the way to the engine bay. From there, there is flexible his that connects it to the engine. I was going to reuse the hard line and attach fuel injection rated hoses where flex line was used.
Where the line attaches to the fuel rail on the engine I am going to get the quick connectors.
Is this process wrong?
Gigemags05 is offline
post #17 of 19 Old 03-21-2013, 12:07 PM
CSP
SLO Ken,
I wouldn't assume that the 4.0 rail is 5/16" or 3/8". I've seen those connectors in metric sizes as well. A set of calipers would determine it one way or the other.
The 4.0 fuel rail only has one bead like this fitting has:
I'm assuming that by double bead you mean this type that Ford fuel lines and lots of air conditioning lines use that require the round disconnect tool.
CSP is offline
post #18 of 19 Old 03-21-2013, 12:27 PM
SLO_Ken
I'll put a set of calipers on mine when I get home from work tonight.
SLO_Ken is offline
post #19 of 19 Old 03-21-2013, 12:35 PM Thread Starter
Gigemags05
1980 CJ7
I just put a set on mine.
One is 5/16 and the other is 1/4. I'm pretty sure the bigger one is the inlet, and smaller is return.
***edited because I accidentally typed the wrong measurements****
Napa has the 5/16 quick connect but not the 1/4.
