4.0 swap alternator wiring - JeepForum.com
post #1 of 33 Old 03-17-2013, 07:08 PM Thread Starter
Gigemags05
1980 CJ7
Im using the hesco wiring harness.
Anyone familiar with how to wire the 4.0 alternator?
I've tried logging into their forum but my membership still hasn't been activated.
There is one blue wire and one brown wire coming from the PCM that do not have labels and I can't figure out where else they'd go. Do they go to the field terminals on the alternator? If so, which is which?
Also, is there a ground anywhere?
Y'all have helped a ton the past few days, I really appreciate it.
Gigemags05 is offline
post #2 of 33 Old 03-17-2013, 07:17 PM
SLO_Ken
Here's a pinout diagram for a 97-99 pcm. Maybe it'll help?
SLO_Ken is offline
post #3 of 33 Old 03-17-2013, 09:34 PM Thread Starter
Gigemags05
1980 CJ7
Thanks for the pin out. I'm not sure if it'll help, but I'll study on it some.
post #4 of 33 Old 03-18-2013, 01:02 AM
wrongway92407
wrongway92407's Avatar
The Hesco harness was made to use with there MPI. I just pulled out my alt to day but haven't gotten to the point to figure out the wiring, but will take a look tomorrow.
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #5 of 33 Old 03-18-2013, 09:57 AM Thread Starter
Gigemags05
1980 CJ7
Ok cool. If you get a chance, let me know what you find out.
post #6 of 33 Old 03-18-2013, 02:28 PM Thread Starter
Gigemags05
1980 CJ7
I just spoke with Bennie at hesco. He told me the blue wire goes to one of the field terminals and the other field terminal needs 12 volts. Does anyone know which field terminal needs the 12 volts?
Also, the brown wire is for the neutral safety switch. Does anyone know where that is on a 1980 cj7? How do I hook this wire up to that??
Just when I thought I was getting a handle on this stuff...
post #7 of 33 Old 03-18-2013, 03:00 PM Thread Starter
Gigemags05
1980 CJ7
I have a tf999 transmission btw.
post #8 of 33 Old 03-18-2013, 08:26 PM Thread Starter
Gigemags05
1980 CJ7
Anyone have any idea where this wire for the neutral safety switch should go?
I've been looking through the fsm but can't find anything about where the wire would go.
Would this wire connect directly to the switch? If so, is the switch located on the steering column? Or does the wire connect to somewhere on the transmission?
post #9 of 33 Old 03-18-2013, 08:48 PM
SLO_Ken
That wire needs to be grounded for the starter relay to work. The neutral safety switch provides that ground when the transmission is in "Park" or "Neutral". I suspect the switch is near the base of the steering column under the dash, but I'm not familiar with auto CJ's.
SLO_Ken is offline
post #10 of 33 Old 03-18-2013, 08:58 PM Thread Starter
Gigemags05
1980 CJ7
So for it to work properly, I need to connect it to the switch? I'm seeing some things that say its on the tranny and others saying its in the steering column.
post #11 of 33 Old 03-18-2013, 09:49 PM
SLO_Ken
Yup. If the wire is not connected, the starter will not work. The wire should go to the center pin on the NSS.
Here's a pic
and a thread...
http://www.jeepforum.com/forum/f8/84...crank-1393132/
Or you can just ground that wire, then the starter will work regardless of the gear selector position.
SLO_Ken is offline
post #12 of 33 Old 03-18-2013, 10:04 PM Thread Starter
Gigemags05
1980 CJ7
Thanks! I just went out and checked and I found the nss on the transmission.
Next question: the switch has a connector attached to it already. I don't want to pull the connector because it has the back up lights attached to it.
But I do want to attach the wire from the harness. Can I just splice it in to the middle wire? What's the best method for this? Seems to be in a relatively unprotected place.
Or, will I be able to pull just the middle wire from the switch and replace it with the new one?
post #13 of 33 Old 03-18-2013, 10:19 PM
SLO_Ken
Yeah, I'd splice into the existing wire. I don't know if there is a "best" method. Use your best judgement.
SLO_Ken is offline
post #14 of 33 Old 03-18-2013, 10:39 PM Thread Starter
Gigemags05
1980 CJ7
Alright, awesome. Thank you very much.
Anyone have any insight on which terminal is which on the alternator?
post #15 of 33 Old 03-18-2013, 11:50 PM
86cj74.2L
86cj74.2L's Avatar
In the PCM pin out look for the two wires labeled generator field - and generator field source + those are your field wires.
86cj74.2L is offline
