4.0 swap - Page 4 - JeepForum.com
post #46 of 66 Old 04-16-2014, 07:55 PM Thread Starter
bgi3
1983 CJ7
ok as yall know i got her going and she runs good for a litlle bit then the motor starts skipping. like its not getting gas. i went to the parts house and got some seafoam and a better fuel filter and going to try and get it put on friday hopefully it helps.
24 hours in a day. 24 beers in a case ... coincidence?
When in doubt? GAS IT!!!!!
Parachute For Sale! Only used once. Never opened. Small stain.....
1984 CJ7, 4.0 FI, 31" BFG A/T,
bgi3 is offline
post #47 of 66 Old 04-16-2014, 08:02 PM
ThisGuyUKnow
Originally Posted by bgi3 View Post
ok after drive her a lil bit i seen that all my gauges work except for my temp. gauge. is there a way i can wire the factory gauge up with the sending unit from the 4.0. or shoud i buy an sending unit for the cj. drill and tap a hole in the thermostat houseing
You need to drill and tap the head to ad the CJ style temp sending unit. Or you can run to the Pick and pull and find a 91-95 head and swap it out for that 97 head. The earlier head has the coolant passage already drilled and taped for the sending unit.
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline
post #48 of 66 Old 04-16-2014, 08:11 PM Thread Starter
bgi3
1983 CJ7
i like to do a little fab work but drilling and taping the head is a little over my comfort zone id hate to put it in the wrong spot. and really dont want to jerk the head off and replace it. is there an opion were i can slpice a hose with a piece of tubing and put the sending unit there or maybe drill a hole in the thermo housing and weld a nut on it to insert the sending unit.
bgi3 is offline
post #49 of 66 Old 04-16-2014, 08:18 PM
ThisGuyUKnow
Well, You could theoretically put it in the coolant hoses I guess. The only issue with that is that you would not get any coolant readings until the engine got to operating temperature and the Tstat opened. You want that to read off the coolant that is in the engine.
If you really wanted to avoid drilling the head or putting on a new head maybe you could get creative with one of the coolant drain plugs on the side of the block? They are much larger than the sending unit but maybe you can rig up an adapter?
post #50 of 66 Old 04-16-2014, 08:24 PM Thread Starter
bgi3
1983 CJ7
you mean like the freeze plugs in the side of the block? and if im not misstaken i didnt put a thermo in when i change the tstat gasket. ive never ran one in any of my cars/trucks.
bgi3 is offline
post #51 of 66 Old 04-16-2014, 08:28 PM
ThisGuyUKnow
No I do not mean the freeze plugs the block has one (maybe two) block drain plugs in it.
http://jeephorizons.com/tech/radiator/rad3.jpg
If you do not install a thermostat your jeep will never be able to get up to operating temperature. I personally would install one but if it works for you then I keep it that way.
post #52 of 66 Old 04-16-2014, 08:36 PM Thread Starter
bgi3
1983 CJ7
i didnt even know those were there. does a temp sending unit just screw in or gotta drill and tap to fit. it get pretty hot 170/180 just takes a little longer to get there.
bgi3 is offline
post #53 of 66 Old 04-16-2014, 08:40 PM
ThisGuyUKnow
The Sending unit screws into the head. It is much smaller than the drain plug so I dont know how you would make it work but Im sure you can get creative.
post #54 of 66 Old 04-16-2014, 08:43 PM Thread Starter
bgi3
1983 CJ7
i will definitely look in to that thank man big help.
bgi3 is offline
post #55 of 66 Old 05-12-2014, 11:41 AM Thread Starter
bgi3
1983 CJ7
How am I suppose to get this out. I can't find a tool anywhere to get it out.
bgi3 is offline
post #56 of 66 Old 05-12-2014, 12:05 PM
Mike Romain
A socket wrench fits it I think...
Mike
Mike Romain is offline
post #57 of 66 Old 05-12-2014, 12:06 PM
Gigemags05
1980 CJ7
Will a 3/8" ratchet with no socket on the end fit in there? That is how I usually get those things out.
*Edit* looks like Mike beat me to it.
Gigemags05 is offline
post #58 of 66 Old 05-12-2014, 12:07 PM
CSP
I can't tell anything in reference to the size, but that square is the same size as a 3/8 or 1/2" drive ratchet/breaker bar without a socket on it.
CSP is offline
post #59 of 66 Old 05-12-2014, 09:16 PM
ThisGuyUKnow
Yep either a 3/8 or half in drive will fit it.
post #60 of 66 Old 05-13-2014, 12:04 AM Thread Starter
bgi3
1983 CJ7
Nope 3/8 was to big 1/4 was to small I had to go to a buddy's shop and barrow a specialty socket. 5/16 square head. Who knew? Never seen one before.
bgi3 is offline
