4.0 swap - Page 3 - JeepForum.com
post #31 of 66 Old 01-16-2014, 04:08 PM
SLO_Ken
I notice you left out the dust shield between the block and the bell housing. Was that intentional?
California 4.0 OBDII Engine Swap
http://www.jeepforum.com/forum/f8/california-4-0-obdii-swap-1530716/
SLO_Ken is offline
post #32 of 66 Old 01-16-2014, 04:22 PM Thread Starter
bgi3
1983 CJ7
I noticed that after I had put everything in and look around the shop to them and I've seem to have miss placed them. I guess i look around a lil harder i do need to do them on.
24 hours in a day. 24 beers in a case ... coincidence?
When in doubt? GAS IT!!!!!
Parachute For Sale! Only used once. Never opened. Small stain.....
1984 CJ7, 4.0 FI, 31" BFG A/T,
bgi3 is offline
post #33 of 66 Old 02-22-2014, 01:19 AM Thread Starter
bgi3
1983 CJ7
while Im still working on my motor swap I used the factory Cj sit brackets. I cut the Xj sit bracket and welded them on the CJ brackets. After getting them bolted in I don't have much room under the steering wheel whit a 13 1/4 in steering wheel. im thinking tilt steering. what all involved with that.
bgi3 is offline
post #34 of 66 Old 03-03-2014, 11:44 PM Thread Starter
bgi3
1983 CJ7
Originally Posted by SLO_Ken View Post
Yep, that really is it. The 5 wires are:
1) batt power from under the hood to the CJ fuse box
2) switched power from ignition switch to XJ harness (hot in "run" and "start")
3) switched power from ignition switch to XJ starter relay (hot in "start" only)
4) XJ harness grounds to CJ ground
5) [optional] switched power from ignition switch to XJ harness (for emissions equipment)
You can hook up the engine and wiring without any of the emissions equipment, and it will run, but there will constantly be DTC's (diagnostic trouble codes) set in your computer. At the very least, I'd recommend installing the evap canister...
I also recommend downloading and becoming familiar with the Factory Service Manual.
ok i got steps 1,3,4 i need step two you think you could help me out with color code, wires you use or possible pic of where you spliced in the two harnesses. im lost.
bgi3 is offline
post #35 of 66 Old 03-04-2014, 07:07 AM
ThisGuyUKnow
Are you working off of a good wiring diagram for the 97 harness you are using? I have done several 91-95 harnesses but never an OBDII. If you link or upload the wiring diagram, you can get your answers real quick.
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline
post #36 of 66 Old 03-04-2014, 09:50 AM
SLO_Ken
On the CJ side, step 2 is the large gauge (14?) red/white that used to feed power to your Ignition module on the drivers fender.
On the XJ side, step 2 is the blue/white that feeds into the under hood fuse box. There's actually about 3 or 4 of these that are all spliced together at the PDC. Circuit F12 in the FSM.
http://www.jeepforum.com/forum/f8/ca.../#post15509821
http://www.jeepforum.com/forum/f12/4...l#post15871270
SLO_Ken is offline
post #37 of 66 Old 03-04-2014, 10:05 AM
SLO_Ken
On the XJ side, step 2 is the blue/white that feeds into the under hood fuse box. There's actually about 2 or 3 of these that are all spliced together at the PDC. Circuit F12 in the FSM.
Also, if you want the radiator fan relay in the PDC to control anything, you need to hook up #5. It's the same Red/White feed from the CJ. It goes to the white wire on the XJ harness, circuit F20 in the FSM.
SLO_Ken is offline
post #38 of 66 Old 03-04-2014, 04:22 PM Thread Starter
bgi3
1983 CJ7
Got it run that's the only thing I was missed was the red/white ignition to the blue/white ignition. I raked my brain all day yesterday trying to figure it out. You don't know how big of a thanks I owe you guys for the help.
bgi3 is offline
post #39 of 66 Old 03-06-2014, 12:05 PM Thread Starter
bgi3
1983 CJ7
some how i have missed placed my obdII diagnosis plug. does anyone has a pic of the plug where it plugs in to the wiring harness? so i know where to plug it when i get to the junk yard to get one.
bgi3 is offline
post #40 of 66 Old 03-28-2014, 10:57 AM Thread Starter
bgi3
1983 CJ7
I've been working on this thing for going on two years and finally got to do the frost test drive yesterday. Thanx guys. You were a big help.
bgi3 is offline
post #41 of 66 Old 03-28-2014, 11:02 AM Thread Starter
bgi3
1983 CJ7
I'd post a video but I can't figure out how thru my phone
bgi3 is offline
post #42 of 66 Old 03-28-2014, 11:37 AM
ThisGuyUKnow
Congrats dude! I remember my first tub with the 4.0 injection, what a difference!
post #43 of 66 Old 03-28-2014, 11:40 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Upload the video to Youtube, then link to it here.
Matt
Matt1981CJ7 is online now
post #44 of 66 Old 04-04-2014, 12:36 AM Thread Starter
bgi3
1983 CJ7
Drove her down to the river. Shhhh don't tell anybody haven't tagged or insured her yet.
bgi3 is offline
post #45 of 66 Old 04-07-2014, 02:15 AM Thread Starter
bgi3
1983 CJ7
ok after drive her a lil bit i seen that all my gauges work except for my temp. gauge. is there a way i can wire the factory gauge up with the sending unit from the 4.0. or shoud i buy an sending unit for the cj. drill and tap a hole in the thermostat houseing
bgi3 is offline
