4.0 swap - Page 2 - JeepForum.com
post #16 of 66 Old 09-30-2013, 10:01 PM Thread Starter
bgi3
1983 CJ7
Got started tonight.
24 hours in a day. 24 beers in a case ... coincidence?
When in doubt? GAS IT!!!!!
Parachute For Sale! Only used once. Never opened. Small stain.....
1984 CJ7, 4.0 FI, 31" BFG A/T,
bgi3 is offline
post #17 of 66 Old 10-05-2013, 10:37 PM Thread Starter
bgi3
1983 CJ7
Originally Posted by SLO_Ken View Post
I'm wrapping up the same swap. Here's a link to my thread...
http://www.jeepforum.com/forum/f8/ca...-swap-1530716/
I found that the physical differences between the 92-95 OBDI engines and the 96-99 OBDII engines are pretty much negligible. The only significant differences are that the computers are not interchangeable, and there is a second O2 sensor downstream of the catalytic converter. Also, the wiring is a bit different. If you want/need to run a check engine light, you need the gauge cluster from the 96-99, since there is not a CEL lead from the computer.
If you are on a budget, you can modify your current bellhousing and make a simple bracket for your CPS instead of using the Hesco ($$$) relocation kit.
The benefits of the 96-99 OBDII system (at least for me) are:
1) They seem to be much more available where I'm at.
2) The improved diagnostic trouble codes are way more helpful.
So far, I'm a little over a grand into my swap (not including costs I've recovered by selling old parts). All I have left to do is get an exhaust welded up, then take it to the smog referee to be inspected.
I hope this helps. Have fun!
Ok i got a few questions i live in SC. and we dont have smog inspection. So i was think i wouldnt need any of the emissions (pradon my french but) crap from the cherokee, right? And i was reading about the five wires to fire. i might be reading to much in to this but i find it hard to believe that i only have to splice five wire to get the whole cherokee wiring harness, EMC to power up and work properly? again this is the first time diving into something this challenging or confusing?
bgi3 is offline
post #18 of 66 Old 10-05-2013, 11:07 PM
SLO_Ken
Yep, that really is it. The 5 wires are:
1) batt power from under the hood to the CJ fuse box
2) switched power from ignition switch to XJ harness (hot in "run" and "start")
3) switched power from ignition switch to XJ starter relay (hot in "start" only)
4) XJ harness grounds to CJ ground
5) [optional] switched power from ignition switch to XJ harness (for emissions equipment)
You can hook up the engine and wiring without any of the emissions equipment, and it will run, but there will constantly be DTC's (diagnostic trouble codes) set in your computer. At the very least, I'd recommend installing the evap canister...
I also recommend downloading and becoming familiar with the Factory Service Manual.
SLO_Ken is offline
post #19 of 66 Old 10-05-2013, 11:40 PM Thread Starter
bgi3
1983 CJ7
Dang after will that hard work of changing the engines out and trying to wrap my head around the idea of all of the spider web of a harness and its that easy. MAN you guys here are life saver cause i was lost.... cheers to you..... I guess the next part will he wiring it up and the hard part thinning out the harness and figuring out were to put it all. i think if its that easy to wire up theres alot of the harness i dont need? And one more thing about the VSS did you ever find an adaptor and im guess it goes were the speedo cable is suppose to go? and i will do on the serves manual. im taking that this will help me out alot.
bgi3 is offline
post #20 of 66 Old 10-06-2013, 01:34 PM
SLO_Ken
The XJ engine harness does not get thinned out too much. The "5 wires" are where the XJ and CJ harnesses get joined together. You will keep the dozens of wires from the XJ ECM to all the sensors and such. About the only thing that got stripped out of my XJ engine harness was the cruise control and A/C wiring. Of course, I had to keep all my emissions equipment and run wires under the dash for a check engine light and OBDII data link.
You will be able to significantly thin out the CJ harness. You'll keep the CJ wiring for headlights, horn, and gauges, the wires going down to the transmission/t-case for your reverse lights and 4x4 indicator, and the wires required for the "5 wires", but that's about it. All the wiring for your CJ ignition module, computer (if you still have it) and alternator can go.
On the link I provided to the service manual, you want the 99 XJ FSM. XJ's were pretty much unchanged from '96-'99. Section 8W is all wiring diagrams.
SLO_Ken is offline
post #21 of 66 Old 10-06-2013, 05:27 PM Thread Starter
bgi3
1983 CJ7
OK i think i can handle that. you wouldnt have a picture of your engine compartment so i can get a idea on where to mount all the elec. and emissions, would you. i down loaded the FSM for the 95 XJ but ill go back and get the one for the 99 in the morning.
bgi3 is offline
post #22 of 66 Old 10-09-2013, 01:11 PM Thread Starter
bgi3
1983 CJ7
Im looking at the different kind of fuel pumps. I'm look at a Mr. gasket part # 42s. Its a 42gph pump. anyone every use this pump? or got any feed back on it.
bgi3 is offline
post #23 of 66 Old 10-09-2013, 02:05 PM
SLO_Ken
The stock injectors on the 4.0 will only use ~25gph total. However, the '96-up fuel injection system is designed to for ~50psi fuel pressure. Make sure your new pump can provide the necessary volume at the necessary pressure. I'm using an Airtex E2000 in mine.
It looks like that Mr. Gasket 42S is meant for a carbureted system, and likely only puts out ~2-3.5psi.
SLO_Ken is offline
post #24 of 66 Old 10-09-2013, 03:19 PM Thread Starter
bgi3
1983 CJ7
Alright will do. I think I seen one of those on the website I was looking on.
bgi3 is offline
post #25 of 66 Old 10-18-2013, 10:30 AM Thread Starter
bgi3
1983 CJ7
OK I got an E2000 pump and got a fuel filter/regulator for a 2004 WJ but what is third fitting for?
bgi3 is offline
post #26 of 66 Old 10-18-2013, 11:08 AM
SLO_Ken
The third fitting is a return to the fuel tank from the regulator. The two male fittings are the inlet and outlet. The female fitting is the tank return. Inlet and return are on the same end.
SLO_Ken is offline
post #27 of 66 Old 10-21-2013, 05:37 AM Thread Starter
bgi3
1983 CJ7
So can I go to the parts store and buy the return line so it'll have the male fit or do I go to the salvage yard or can I make one
bgi3 is offline
post #28 of 66 Old 10-21-2013, 11:08 AM
SLO_Ken
You can browse on the Dorman website for the correct fitting. http://www.dormanproducts.com/c-386-...spx?pagenum=12
I got mine from the parts store.
SLO_Ken is offline
post #29 of 66 Old 01-16-2014, 01:39 PM Thread Starter
bgi3
1983 CJ7
got the bellhousing drilled and the cps in place. then set the motor and trans in place. Got the grill and radiator ready to sit in and noticed that the bottom outlet of the radiator was a lose and when I got a closer look the whole thing pulled out of the radiator. good think it and old radiator so I can fix it.
bgi3 is offline
post #30 of 66 Old 01-16-2014, 02:00 PM Thread Starter
bgi3
1983 CJ7
Got get the stuff to fix the radiator then we'll be back in business. Hopefully everything else will go smoothly. notice the radiator in the right pic is the one from the donor. just make sure it wont fit....
bgi3 is offline
