4.0 swap - JeepForum.com
post #1 of 66 Old 09-21-2013, 06:50 AM Thread Starter
bgi3
1983 CJ7
4.0 swap
I'm thinking of doing a 4.0 swap from a 97 cherokee. I'm aware that I need a crank position sensor/damper kit. I'm gonna on a budget. What the cheapest why to do this.
24 hours in a day. 24 beers in a case ... coincidence?
When in doubt? GAS IT!!!!!
Parachute For Sale! Only used once. Never opened. Small stain.....
1984 CJ7, 4.0 FI, 31" BFG A/T,
bgi3 is offline
post #2 of 66 Old 09-21-2013, 06:56 AM Thread Starter
bgi3
1983 CJ7
Or would it be easier/cheaper to pull the fuel injection off and put it on my 4.2
bgi3 is offline
post #3 of 66 Old 09-22-2013, 01:35 PM
aggiejon
1979 CJ7
My understanding is that the obdii 96+ are difficult to make the swap onto a 258. I had a 99 4.0 and wanted to use it. However the more I researched, my mind changed to stick with an obdi 92-95
aggiejon is offline
post #4 of 66 Old 09-22-2013, 03:42 PM
SLO_Ken
I'm wrapping up the same swap. Here's a link to my thread...
http://www.jeepforum.com/forum/f8/ca...-swap-1530716/
I found that the physical differences between the 92-95 OBDI engines and the 96-99 OBDII engines are pretty much negligible. The only significant differences are that the computers are not interchangeable, and there is a second O2 sensor downstream of the catalytic converter. Also, the wiring is a bit different. If you want/need to run a check engine light, you need the gauge cluster from the 96-99, since there is not a CEL lead from the computer.
If you are on a budget, you can modify your current bellhousing and make a simple bracket for your CPS instead of using the Hesco ($$$) relocation kit.
The benefits of the 96-99 OBDII system (at least for me) are:
1) They seem to be much more available where I'm at.
2) The improved diagnostic trouble codes are way more helpful.
So far, I'm a little over a grand into my swap (not including costs I've recovered by selling old parts). All I have left to do is get an exhaust welded up, then take it to the smog referee to be inspected.
I hope this helps. Have fun!
SLO_Ken is offline
post #5 of 66 Old 09-22-2013, 09:45 PM Thread Starter
bgi3
1983 CJ7
Awesome..... thanks. I bought a 97 XY from a guy that was gonna scrape it cause the tranny went out for 425$. I think imma buy the hasco cps cause the XJ is a auto. And I would have to get a flywheel for a man. XJ. And they are rare around here
bgi3 is offline
post #6 of 66 Old 09-23-2013, 10:00 AM
SLO_Ken
My engine was also from an automatic. I got a brand new flywheel off eBay for $63 shipped. Far less expensive than the Hesco CPS relocation kit.
EDIT: looks like they're up to $66. http://www.ebay.com/itm/LUK-LFW193-F...a99f28&vxp=mtr
SLO_Ken is offline
post #7 of 66 Old 09-23-2013, 12:43 PM Thread Starter
bgi3
1983 CJ7
Great.... I can do that. How did you measure the bell housing for drilling.
bgi3 is offline
post #8 of 66 Old 09-23-2013, 01:32 PM
SLO_Ken
I followed directions/dimensions given here...
http://www.jeepforum.com/forum/f8/of...ml#post8274428
and here...
http://s551.photobucket.com/user/Mar...?sort=2&page=1
SLO_Ken is offline
post #9 of 66 Old 09-23-2013, 06:11 PM Thread Starter
bgi3
1983 CJ7
Thanks.... you saved me a good bit of time and money.
bgi3 is offline
post #10 of 66 Old 09-28-2013, 01:55 AM Thread Starter
bgi3
1983 CJ7
edit its a 96 cherokee..... and im using my factory T4 transmission....does this make a difference?
bgi3 is offline
post #11 of 66 Old 09-28-2013, 07:23 AM
ThisGuyUKnow
if you are going through the trouble to put in a 4.0 why not use a nv3550 or ax15.
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline
post #12 of 66 Old 09-28-2013, 03:20 PM Thread Starter
bgi3
1983 CJ7
Cause I wasn't planning on doing the swap til this Cherokee fell in my lap and I just had the t4 rebuilt
bgi3 is offline
post #13 of 66 Old 09-29-2013, 05:21 PM
SLO_Ken
Shouldn't make a difference. I used a t5, which has the same case/pattern as your t4.
California 4.0 OBDII Engine Swap
http://www.jeepforum.com/forum/f8/california-4-0-obdii-swap-1530716/
SLO_Ken is offline
post #14 of 66 Old 09-29-2013, 05:23 PM
CSP
There's nothing different about the '96 an 97 engines.
CSP is offline
post #15 of 66 Old 09-29-2013, 06:33 PM Thread Starter
bgi3
1983 CJ7
i didnt see this. thanks guys been alot of help. imma start jerking everything apart tomorrow and get ready for the swap. ill let yall know if i got anymore questions. thanks again.
bgi3 is offline
