4.0 to a Stroker Rebuild??? - JeepForum.com
post #1 of 4 Old 09-19-2011, 06:41 AM Thread Starter
poppatello
I've seen a couple 4.0 Renix motors and 4.2's on cragis list advertise as great stroker rebuilds. Just wondering if it can be done and about how much am I looking to do it? I would do as much work as I could but want a great job so I would assume the machine shop would install the crank and cam. Has anyone done this and liked the outcome???
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 4 Old 09-19-2011, 06:56 AM
JeepnBlake
I was quoted 1500-1800 to do mine.
That is me bringing in my engine, the crank (needs 10mm machined off the nose), and bringing in my new pistons and cam. I would also be getting the engine hot tanked, block bored out, and reassembled to drop in.
Piston sets (KB944) are $415 + shipping right now at summit
Cams are $200+
plus you're looking at the parts that get replaced in a rebuild freeze plugs, seals, gaskets etc.
So you'll be in the $2200-2500 range when all is said and done on the conservative side.
Some folks just pull the crank and rods and throw in the 4.2 stuff, which is done pretty cheaply it seems.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #3 of 4 Old 09-19-2011, 07:19 AM Thread Starter
poppatello
Well I don't mind doing it the correct way if it takes a bit longer. My jeep is running now and it has the 4 banger in it so getting more inches is very appealing to me @ the moment. LOL Is the machine shop installing all those items for you for 1800 bucks? Crank, pistons, freeze plugs seals and such? Are you going with the 4.6 build specs or using your own???
Paved Roads
post #4 of 4 Old 09-19-2011, 07:38 AM Thread Starter
poppatello
Here is the specs I was eyeballing...
~ Jeep 4.2L 3.895" stroke crank
~ Jeep 4.2L 5.875" rods
~ Keith-Black Silvolite UEM-2229 +0.030" bore pistons
~ Increase piston dish volume to 30cc
8.8:1 CR
~ Crane #750501 192/204 degree camshaft
~ Ported HO 1.91"/1.50" cylinder head
~ Mill block deck 0.035"
~ Mopar Performance 0.043" head gasket
~ 0.058" quench height
~ 2.25" exhaust
~ Ford 24lb/hr injectors with stock 39psi FPR for '87-'95 engines, stock injectors with stock 49psi FPR for '96 and later engines
~ 231hp @ 4400rpm, 327lbft @ 2000rpm
Paved Roads
Stroker? 1HANDGRENADE Jeep CJ Forum 1 11-12-2010 09:24 AM
Carter BBD rebuild: Does it matter which rebuild kit I use? Ken4444 Jeep CJ Forum 2 06-14-2010 11:01 AM
383 STROKER Help! Bobby9821 Jeep CJ Forum 15 08-26-2009 06:30 PM
rebuild 4.2 or go with 4.6 stroker lastcj Jeep CJ Forum 16 03-22-2009 11:16 AM
i need some info on engine rebuild/stroker bulljeeper Jeep CJ Forum 6 08-27-2007 10:46 PM
