4.0 Head Swap need help ASAP - JeepForum.com
post #1 of 9 Old 07-19-2007, 08:16 PM Thread Starter
Jeff5886
1983 CJ5
I am going to do the 4.0 head swap on my 83 CJ5 but need these questions answered...
1. Will the head from an 87 Fuel Injected 4.0 Jeep Cherokee work?
2. Will I need the Intake manifolds or the push rods?
Thanks
Jeff
Jeff5886 is offline
post #2 of 9 Old 07-19-2007, 08:28 PM
jadams68
jadams68's Avatar
An 87 head is not the High Output head you're looking for. Instead of going by year, go by casting# 0630 or 7120 heads only.
You can use your existing CJ intake manifold.
You'll need 4.0L pushrods.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 9 Old 07-22-2007, 06:24 PM Thread Starter
Jeff5886
1983 CJ5
It seems every time I find a good used head something is missing. The latest one I have found doesn't have rocker arms. What makes up a complete head? Can someone give me a checklist of what is needed for a complete head.
Jeff5886 is offline
post #4 of 9 Old 07-22-2007, 08:05 PM
jadams68
jadams68's Avatar
Rocker arms and pushrods are separate. The head will just come with the valve springs.
jadams68 is offline
post #5 of 9 Old 07-22-2007, 09:52 PM Thread Starter
Jeff5886
1983 CJ5
So if I pickup a 4.0 head, what else will I need to make the swap to my 4.2? (Besides valve cover and exhaust manifold)
Also, I have been doing some research and some people are saying I can use the rockers and pushrods from the 258. Any input?
Jeff5886 is offline
post #6 of 9 Old 07-23-2007, 06:37 AM
Fatman
Fatman's Avatar
2008 CJ7
You'll need to fill the water jackets in the new head, power steering brackets, gasket set, ....
you can use the 258 rockers and bridges but if you use the pushrods you will need to shim the rockers. I think it works out to .030 but don't remember exactly.
Thread Links:
Fatman is offline
post #7 of 9 Old 07-23-2007, 06:49 AM
jadams68
jadams68's Avatar
http://www.bustedjeep.com/projects/rebuild.asp
jadams68 is offline
post #8 of 9 Old 07-23-2007, 11:41 AM
John Brereton
I'm in the process of doing this now. Some write ups say you'll need to grind away some of the power steering bracket. Once I get my head on I'll know for sure.
What's left of a '79 CJ5
3 - 4" total lift
4.88 gears in a Dana 30 and off center ff Dana 44 with disc brakes
258 with TFI /T18 /D18 drive train with Saturn O.D.
33 x 12 DC Mud Country Radials
John Brereton is offline
post #9 of 9 Old 07-23-2007, 12:51 PM
jadams68
jadams68's Avatar
John, that depends if you use a header or a cherokee exhaust manifold. You may get lucky as I used a header and had to do a little fab work.
jadams68 is offline
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 06:04 AM
help with 4.0 head swap!! turbophein Jeep CJ Forum 17 02-11-2008 01:38 PM
4.0 head swap jdb_us1 Jeep CJ Forum 2 06-05-2006 06:37 PM
1 more 4.0 head swap ??? yttims Jeep CJ Forum 22 05-16-2005 07:11 AM
4.0L head swap 83 cj-7 258 Jeep CJ Forum 19 03-08-2005 08:33 PM
