4.0 Head Swap on 4.2L 258 - Page 3 - JeepForum.com
post #31 of 68 Old 05-01-2011, 03:25 PM Thread Starter
WillyC24
1980 CJ7
Nearing the end of the work on the 4.0L head conversion and full 4.2 rebuild, and now have a few questions on the valve cover breather vs. PCV valve configuration.
My engine shop says the manual calls for two breathers, while I normally see a PCV valve on the front. Any advice here? I've attached a picture of my engine (you'll see the two breathers installed):
WillyC24 is offline
post #32 of 68 Old 05-02-2011, 12:01 AM
gosupes
Get them from the stealership. One is restricted flow, goes from vacuum source to cover. The other is just a basic elbow, goes from the cover to a filtered air source like the air cleaner assy.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #33 of 68 Old 05-02-2011, 05:12 AM
razor2264
1979 CJ5
Hey Willy,
I'm using the Clifford set up similar to yours. I have a question regarding the weber 38 with that setup. What idle jets did you end up using? Also did you have any problems with coolant leaking inside your Clifford intake? Mine has a slow leak, but it still runs. Might want to take the carb off and check. Currently there is a month long wait for the replacement.
razor2264 is offline
post #34 of 68 Old 05-02-2011, 10:28 AM Thread Starter
WillyC24
1980 CJ7
Thanks, Razor. I'll check into that.
Gosupes - in summary, you're saying no PCV valve. Does the true breather go on the rear hole, and the elbow on the front?
WillyC24 is offline
post #35 of 68 Old 05-02-2011, 11:51 AM
razor2264
1979 CJ5
Do you know which idle jets you are using with your setup?
Thanks!
post #36 of 68 Old 05-06-2011, 10:34 AM Thread Starter
WillyC24
1980 CJ7
Razor - sorry, I don't know what jets I'm using, other than I bought the Redline Weber 38/38, which is supposed to have been fitted with the proper jets before shipment.
Also, further confusion on the PCV vs. breather conversation -- my instructions from Clifford on the Weber carb say NOT to use a PCV and to use breathers on both holes. Yet still, everywhere else I read that I should use a PCV.
In other news, I had my rebuild dyno'd and she's topping out at 200HP and 237 lb-ft of torque. See the full PDF report here.
WillyC24 is offline
post #37 of 68 Old 07-04-2011, 10:26 PM
243
1978 FSJ Cherokee
I found this thread while searching Google for 4.0 head articles, it caught my eye because I know a lot of people have asked about *real* hp and tq numbers following the 4.0 head swap. I have had visions of a 4.0 head, Offy intake and Borla header even though I have never fired up my engine...it is truly a disease
WillyC24
Do you have the engine back in the CJ?
What cam and exhaust did you use?
Dave's 78 Build
243 is offline
post #38 of 68 Old 07-06-2011, 11:20 AM
243
1978 FSJ Cherokee
WillyC24 was on line in early June, hopefully he will jump back in to provide an update.
Dave's 78 Build
243 is offline
post #39 of 68 Old 07-06-2011, 12:05 PM
80cj
80cj's Avatar
1980 CJ5
Originally Posted by foggybottombob View Post
I got one from clearwater also but I will say that I could not tell any difference in seat of the pants power difference. I got a very noticeable power increase from putting in the HEI distributor.
I read about similar results on another thread a while ago. Makes me wonder. I was on the verge of doing a head swap but decided to hold off. A lot of times people do other upgrades when they do a 4.0 head swap so it makes me wonder where the performance increase claims actually come from. I still run a stock 258 and like you, noticed a nice increase in throttle response when I installed a DUI dizzy.
80cj is offline
post #40 of 68 Old 07-06-2011, 08:22 PM
gosupes
Doesn't matter, they are both basically the same but one is restricted. I think I have the restricted one in the front, the hose routing work better for me that way.
gosupes is offline
post #41 of 68 Old 07-07-2011, 07:43 AM
bkeese
1949 CJ3A
Maybe I'm the only one on the planet that had this issue, here goes. I installed the Felpro head gasket that the machine shop provided me. When I first fired it up, I filled my oil pan with $20 worth of antifreeze. Upon removal I noticed (after not before) that the new gasket had an overlap between the water and oil passage. I bought a new gasket and all was well. I know the original 258 head gasket did not have this but the one in the gasket set did. I don't remember if the gasket was a 258 or 4.0. Moral of the story check your head gasket.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #42 of 68 Old 07-07-2011, 09:00 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
For some of the pricing I seen in this thread, You could easily do a 4.6 low buck stroker and end up in the 250 hp & 300+ tq range
LT1CJ7 is offline
post #43 of 68 Old 07-10-2011, 08:22 AM Thread Starter
WillyC24
1980 CJ7
Howdy all, sorry for the delay - I've been on the road a bit. I have the engine on the frame now, but the CJ still looks like a moon rover. So, no "real world" tests yet. I'll update as soon as possible!
WillyC24 is offline
post #44 of 68 Old 07-27-2011, 08:23 AM
Hippie05
1987 YJ Wrangler
Newbie here and I have to say this is the best conversation I've found on the topic. Lots of great information from ya'll.
I just bought a friends jeep (87YJ) and he was getting ready to perform this mod. I didn't want to rush into it, but the engine was smoking so bad that I just went ahead and dove right in. I have the old head off and I'm glad I went ahead with the mod as there was coolant in the 4th and mild rust between between 3,4, and 5th cylinders and while the valve train didn't look bad I suspect the seals were leaking pretty bad too.
But anyway, can anyone tell me if there is a way to identify which 4.0L head I have? I can't ask my friend b/c he's in Afghanistan.
Hippie05 is offline
post #45 of 68 Old 07-27-2011, 10:10 AM
foggybottombob
There is a number cast into the surface of the head. The 91-95 heads were 7120. That is what I used.
foggybottombob is offline
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
How can I tell if the PO did the 4.0 head swap? danheit Jeep CJ Forum 4 05-26-2010 11:43 AM
4.0 Head Swap j33pman Jeep CJ Forum 8 02-05-2009 03:07 PM
Head swap ?s motojoe Jeep CJ Forum 2 04-09-2007 03:28 PM
4.2L to a 4.0L head swap? Vinnyl32 Jeep CJ Forum 2 07-28-2005 07:02 AM
