4.0 fuel pump issue - Page 2 - JeepForum.com
post #16 of 23 Old 04-16-2013, 03:22 PM Thread Starter
Gigemags05
1980 CJ7
It's a 25 amp fuse.
Maybe I can unhook the pump and see if it still blows the fuse?
Gigemags05 is offline
post #17 of 23 Old 04-16-2013, 03:27 PM Thread Starter
Gigemags05
1980 CJ7
I am wondering how the pump could've gone dry, though. I installed it exactly where most people do, on the cross member very close to the tank.
post #18 of 23 Old 04-16-2013, 04:17 PM
aggiejon
1979 CJ7
Make double sure the pos and neg ring terminals are not touching each other. Or tthat the pos is not ouching the frame or other metal.
Could be a weak or improperly wired relay. Is the relay on a socket or just spade terminal?
Anything else on the circuit?
aggiejon is offline
post #19 of 23 Old 04-16-2013, 04:28 PM Thread Starter
Gigemags05
1980 CJ7
Ok. I'm positive (no pun intended) that the terminals are correct and not touching anything they aren't supposed to.
I'm not sure about the relays. I've never messed with them. There are only two. Pretty sure they are the socket type.
post #20 of 23 Old 04-16-2013, 06:11 PM
CSP
It's doubtful that it's the relay, but it's easy to check. Disconnect the power wire to the pump and use a test light between the power wire and ground. This will tell you if the short is in the relay or (not likely) the positive wire between the relay and the pump. If the light comes on and the fuse doesn't blow the relay is fine and the pump is where the short is.
How do you know that the pump went dry? This is the first time you mentioned that it went dry.
CSP is offline
post #21 of 23 Old 04-16-2013, 06:54 PM Thread Starter
Gigemags05
1980 CJ7
Fixed!
Me, being the idiot I am, didn't secure the wiring as tightly as I should.
The fuel pump wire sagged and touched the muffler, melting it.
Easy fix, but I feel stupid.
The pump never went dry, it was just brought up as a possibility.
Thanks all for the help!!!
post #22 of 23 Old 04-16-2013, 07:07 PM
CSP
Keep at it, you're getting there with it!
CSP is offline
post #23 of 23 Old 04-16-2013, 07:16 PM Thread Starter
Gigemags05
1980 CJ7
Live and learn I guess.
I've come a long ways since I bought this thing.
But I have a whole lot more to go
