4.0 fuel pump issue - JeepForum.com
post #1 of 23 Old 04-15-2013, 02:10 PM Thread Starter
Gigemags05
1980 CJ7
I swapped a 92 4.0 into my cj a few weeks ago. I used an e2000 fuel pump.
Everything g was going great until yesterday. While I was driving, I noticed it sputtering like it wasn't getting fuel (I do have plenty of gas). Then after a mile or so it died.
I got under and inspected the fuel pump and noticed that the ground wire had come off of the post on the pump. I replaced it and tightened it thinking its solve the issue but now the jeep won't start at all. When I turn the key to on, I do not hear the pump come on at all.
Any idea what this could be? The pump is brand new and was working fine until yesterday.
Gigemags05 is offline
post #2 of 23 Old 04-15-2013, 02:53 PM
CSP
Is the pump getting power? The loose wire could have popped a fuse.
CSP is offline
post #3 of 23 Old 04-15-2013, 03:19 PM Thread Starter
Gigemags05
1980 CJ7
I will check. I don't know where a fuse is for the fuel pump though. The hesco harness only came with two relays and one big fuse. Everything else is still getting power.
post #4 of 23 Old 04-15-2013, 04:16 PM Thread Starter
Gigemags05
1980 CJ7
Surely the ground wire coming loose wouldn't burn the pump up would it?
It was working great for a couple of weeks.
post #5 of 23 Old 04-15-2013, 11:21 PM Thread Starter
Gigemags05
1980 CJ7
Anyone got any ideas?
post #6 of 23 Old 04-15-2013, 11:49 PM
SLO_Ken
Two things I would check first...
1) does the fuel pump still function? If you put 12V straight from the battery to the pump, does it spin?
2) is the fuel pump relay still good? I had the fuel pump relay on my Howell system just up and die for no apparent reason.
If both of these are still functioning, then I'd start investigating the wiring.
SLO_Ken is offline
post #7 of 23 Old 04-16-2013, 12:51 AM
BagusJeep
1981 CJ7
The cheapest and best tool in my box is a 12V test lamp, with long leads. I made it from a $5 inspection lamp. It is better than a voltmeter as it only lights up when you have real power which can propel something, whereas a voltmeter will show only potential difference.
You need to get under there and find the voltage. Hook one end to the battery negative and have a search.
If you do not have voltage at the pump, look back and find the fuel pump relay. My guess is that you have a relay which is not working.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 23 Old 04-16-2013, 05:46 AM
aggiejon
1979 CJ7
I would swap out the fuel pump relay. That would be my first suspect. I highly doubt loss of ground would do anything to the fuel pump.
aggiejon is offline
post #9 of 23 Old 04-16-2013, 07:29 AM
CSP
Have you tested for power? Have you checked the relay to see if it's getting power?
What have you done other than ask for more internet guesses?
CSP is offline
post #10 of 23 Old 04-16-2013, 07:50 AM Thread Starter
Gigemags05
1980 CJ7
I've not been home to check yet.
I've gotten some good advice and will follow up
On those leads as soon as I can.
I apologize for not being an automotive expert. I've learned a ton from this forum, but I'm still a rookie and things that are very basic to some are still foreign to me.
I asked the question to get ideas on what to check. If it bothers you, please pass on the thread and read a different one.
post #11 of 23 Old 04-16-2013, 08:06 AM
CSP
The detail that you haven't been able to check anything yet is an important one to leave out. Not knowing that makes it look like you weren't willing to try anything that's been suggested so far.
CSP is offline
post #12 of 23 Old 04-16-2013, 09:06 AM
PERK
an easy way to check the relay or run the fuel pump to prime is to pull the relay and jump # 30 and #87. pump will run constant if it has power.
PERK is offline
post #13 of 23 Old 04-16-2013, 12:53 PM Thread Starter
Gigemags05
1980 CJ7
I checked the fuse on the harness and it was shot. So I replaced it, tried to start the jeep and it blew the fuse again.
post #14 of 23 Old 04-16-2013, 01:01 PM Thread Starter
Gigemags05
1980 CJ7
The fuse blows as soon as the key goes to the on position.
I didn't have time to check the relays, as I was just home for lunch. Would a bad relay blow the fuse?
This harness only has the one fuse and two relays.
post #15 of 23 Old 04-16-2013, 02:41 PM
SLO_Ken
Sounds like a short somewhere. How big is the fuse?
I don't know if a bad relay could blow the fuse, but a bad fuel pump definitely could.
These pumps are lubricated/cooled by the fuel flowing through them. If your pump went dry at any time, it could have damaged/seized the bearings or pump head, causing very high current draw.
SLO_Ken is offline
