360 not wanting to start when warm - JeepForum.com
post #1 of 10 Old 12-01-2009, 09:15 PM Thread Starter
79cj7stone
1979 CJ7
I have a 360 in my jeep. It usually starts fine the first time but if you let it idle for like 10 minutes, cut it off, and try to start it again it goes " whomp.....whomp.....whomp...then it will fire or start to turn over easily or it will keep going whomp. I just changes my alternator because me last one went out and was squealing and not charging. Anyways the longer you let it cool the more turns you will get, when trying to satrt, before it starts to go whomp..whomp..whomp again! Ask me any questions you need to kno about my jeep and i can tell you. Thanks
79cj7stone is offline
post #2 of 10 Old 12-01-2009, 09:29 PM
kw89425
high in time
kw89425 is offline
post #3 of 10 Old 12-01-2009, 09:33 PM Thread Starter
79cj7stone
1979 CJ7
well my neighbor just did the timing like 2 months ago. ( he's a exBFG goodwrench mechanic) and its fine. so idk but thanks.
post #4 of 10 Old 12-01-2009, 09:50 PM
kw89425
well i dont guess there is any chance the distributer has moved since like 2 months ago? what you have described sounds like its high in time maybe the chain has stretched
kw89425 is offline
post #5 of 10 Old 12-01-2009, 10:02 PM Thread Starter
79cj7stone
1979 CJ7
i still dont think so because my motor was rubuilt like 2 and half months ago but it maybe rhat. how do u check that? do you think it could be a ground issue?
post #6 of 10 Old 12-02-2009, 05:01 AM
kw89425
well it could be the starter draging when its hot do you have inframe headers?
kw89425 is offline
post #7 of 10 Old 12-02-2009, 08:05 AM
Mike Romain
Do you have the gas filter in right side up? It sits level and the center outlet goes to the carb and the 'top' outlet goes to the return line so when you shut it down hot, the vapor created in the line blows back to the tank off the top of the filter rather than vaporlocking the gas line.
Mike
Mike Romain is offline
post #8 of 10 Old 12-02-2009, 09:05 PM Thread Starter
79cj7stone
1979 CJ7
i have fenderwell headers.
mike- the gas filter? where is that and how would i check to see if it is installed wrong?
post #9 of 10 Old 12-02-2009, 09:26 PM
jpd1899
1978 CJ7
Fuel filter location
The fuel filter should be right before the carb. Trace your fuel line from the fuel pump. I have a 258 so the configuration may be a little different. Mine looks like a small barrell with one port on the fuel pump side and 2 facing the carb. Mine is 2 different sizes so don't make my mistake and assume they are the same when buying fuel line.
I posted a pic- The filter is in the lower left hand corner. It may not be turned exacty right so orient it like Mike suggested (flat with return line on top)
jpd1899 is offline
post #10 of 10 Old 12-03-2009, 08:59 PM Thread Starter
79cj7stone
1979 CJ7
haha yeah I knew what that was! haha i went blank for a sec.haha I go and check that tomorrow and check my grounds and i will post back. thanks yall!
1977 CJ-7! Wanting to mod, were to start? GoldenEagleGa Jeep CJ Forum 0 02-04-2009 07:29 AM
CJ2A engine won't start when warm Aircatcher Jeep CJ Forum 8 10-13-2008 07:40 PM
TJ guy wanting a CJ need opinions where to start chumly75 Jeep CJ Forum 5 06-10-2008 12:41 PM
Won't start when warm desertnavy Jeep CJ Forum 11 08-30-2005 08:16 PM
CJ is hard to start when warm???? ttimber Jeep CJ Forum 16 06-16-2005 09:55 PM
