360 in my scrambler - JeepForum.com
post #1 of 6 Old 09-09-2004, 08:10 PM Thread Starter
jones24442
360 in my scrambler
How do I find out what year a 360 is? I have two in my garage right now, going with a 700r4 and a np 208 transfer case. I need the engine year to get the right adapter. Where is the block manufacture number located? Thanks, Alan.
jones24442 is offline
post #2 of 6 Old 09-09-2004, 08:37 PM
slickwillie
slickwillie's Avatar
Looking from the top, where the bellhousing bolts to the motor, there is a number stamped on the ridge, towards the drivers side. A parts store or machine shop should be able to look it up & tell you the year. They will probably only be able to tell you a range of years. Mine is an '88-90.
HTH
1983 CJ7 AMC 360, T-5, Dana 300, Dana 30, AMC 20
Warn XD9000i, RE hand throttle, 1" body lift, OBA
slickwillie is offline
post #3 of 6 Old 09-09-2004, 08:39 PM
John N
1981 CJ8
Assuming this is an AMC 360. They have been built from 1972 to 1991. The bellhousing pattern is the same on all. Older AMC's had differences. If it has '360' or '5.9' cast into the side of the block, your safe.
John N is offline
post #4 of 6 Old 09-09-2004, 08:59 PM Thread Starter
jones24442
OK, The number on both blocks is 3195528. Advance Adapters sets their torque converters as pre and post 1978. I did find out that early models had stud rockers on the heads, and late models had bolt downs. I figure worst case scenario, order one, doesn't fit, send it back for the other one. I do have a friend with a very complete machine shop out here, we should be able to make somethng work. Thanks for the quick responses, Alan.
post #5 of 6 Old 09-10-2004, 06:43 PM
John N
1981 CJ8
That's the same number I have on the block in my garage...mine is a 1972.
John N is offline
post #6 of 6 Old 09-11-2004, 02:11 AM
fuzz401
1978 CJ7
the early blocks have only the cam plug on the back the newer blocks have 3 plugs on the back
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
what to do with my scrambler daltonw Jeep CJ Forum 6 09-16-2009 05:26 AM
SCRAMBLER: Should I buy this MINT Scrambler QUICK RESPONSE NEEDED! jatepper Jeep CJ Forum 42 07-06-2009 10:16 AM
Tell me what you think of this scrambler... xulcuz Jeep CJ Forum 1 04-10-2009 02:58 AM
SCRAMBLER PEOPE - HELP PLEASE ->A Scrambler and Towing SomerJeep Jeep CJ Forum 6 06-09-2006 05:49 PM
Got my Scrambler CJeep Jeep CJ Forum 6 08-20-2005 05:12 PM
