360 Head Gasket Install Questions - JeepForum.com
post #1 of 9 Old 05-28-2013, 03:59 PM Thread Starter
asoude1
I'm rebuilding my 360 and have a couple of questions about the installation of the heads. I'm using Fel-pro head gaskets. One side is a composite material (blue) and the other side is metal. I plan to spray the metal side with copper sealant. Am i correct in assuming that the metal sides face the block and the blue sides face the heads? Also, I am planning on re-using the head bolts. I have cleaned them really well and i know the torque sequence. However, what should i put on the bolts? Should I just dip the threads in oil before installing them? Do I need to use anti-seize? Let me know if all of this seems ok. Any help would be appreciated.
asoude1 is offline
post #2 of 9 Old 05-28-2013, 07:31 PM
davbytrace
1979 CJ7
Follow the instructions in the package for the head gaskets. They only go on one way. Spray both sides of the gasket with two coats of copper spray, and spray the bolts with a coat of copper spray.
davbytrace is offline
post #3 of 9 Old 05-28-2013, 07:41 PM
SCSEAJAYSEVEN
1978 CJ7
EVERY bolt, EVERY nut, EVERY screw, used on a Jeep, whether it be on the engine, glove compartment, or tailpipe, should have ANTI SEIZE. That bottle of anti seize will go a long way, and you will be happy you used it.
SCSEAJAYSEVEN is offline
post #4 of 9 Old 05-28-2013, 08:54 PM Thread Starter
asoude1
Will anti-seize mess up the torque reading?
asoude1 is offline
post #5 of 9 Old 05-28-2013, 10:04 PM
SCSEAJAYSEVEN
1978 CJ7
No, I don't think anti seize will alter your torque wrench readings.
TORQUE WRENCH? I have a lot of different types of torque wrenches, but most of the time I torque the bolts using the COLOR CODE method.
What is that, you ask? Just torque the bolts down until you get red in the face and can't pull anymore, and just give it one more little tug!
Works for me!
post #6 of 9 Old 05-29-2013, 08:33 PM
crazyeye
1979 CJ7
Using any type of lube like nickel aka anti seize . Moly lube are cooper lube will all cuts down on your friction . And torque values change when you use that stuff
crazyeye is offline
post #7 of 9 Old 05-30-2013, 04:28 AM
TKFireman
1980 CJ7
My felpro head gaskets went on dry because that's what my machinist told me to do. The gaskets should be labeled left, right, up, down head, block or something to that effect to let you know which way they go on. The head bolt holes on the AMC V8s are all blind, meaning that they do not go into a water jacket or anywhere else requiring sealant, but like everyone else said, they need lube on the threads and under the head of the bolt. Mine where lubed with motor oil when installed, then torqued to spec in three steps but I'm sure someone will say that is wrong.
"If your gonna be dumb, you gotta be tough"
TKFireman is offline
post #8 of 9 Old 05-30-2013, 05:39 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by TKFireman View Post
The head bolt holes on the AMC V8s are all blind, meaning that they do not go into a water jacket or anywhere else requiring sealant...
Not exactly correct.
Bolt #7 (bottom row driver's side, second bolt from the front) goes thru the water jacket, and it requires thread sealant.
I used the stuff on the left of this pic.
Matt
Matt1981CJ7 is offline
post #9 of 9 Old 05-30-2013, 08:33 AM Thread Starter
asoude1
I plan to put copper spray on both sides of the gaskets and use the thread sealant that Matt shows on all of the bolts. I also plan to rub a little oil on the bottom of the bolt heads. I should be able to bolt the heads down tomorrow.
asoude1 is offline
