360 or 350 - Page 3 - JeepForum.com
post #31 of 41 Old 07-08-2013, 10:54 AM
AFRd_CJ5
1976 CJ5
Originally Posted by 82JeepCJ7 View Post
Because they are lazy.. #1 reason. They don't want to take the time to properly research rebuilding a AMC motor and have the attitude of "I'll just take the easy way out and put a dime a dozen 350 in it"
The only thing worse is an old 30s-40s Ford truck at a car show with a GM 350 in it... the person who built it needs to be slapped
I went the SBC route because there's no way I could make the power I wanted to make using an AMC, and make it affordable/reliable.
There are other reasons people use a SBC..........
With that said though, I'm all for staying with a good 360-401 in a situation like this.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #32 of 41 Old 07-08-2013, 07:19 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
Lazy is a very harsh term don't you think?
I did the research and decided against it for a number of reasons.
Lazy was not one of them.
I do agree with you on the old fords having chevy engines, that ain't rite!
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #33 of 41 Old 08-15-2013, 09:38 PM Thread Starter
DanTheMan01
1978 CJ7
Alright guys I have decided to go with the AMC 360. I have found one out of a 76. It's is almost complete just needs a distributer, carb, and manifold. What are the challenges ahead? I have a lot of new parts on my 304 like a distributer and a FlowKooler water pump. Will any of the parts I need exchange from the 304 to the 360? Any suggestions on a reasonably priced carb? Some pics below.
DanTheMan01 is offline
post #34 of 41 Old 08-15-2013, 11:33 PM
roboto65
1976 CJ5
They should all fit no problem water pump and distributor.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #35 of 41 Old 08-16-2013, 12:56 AM
LeePrather
1978 CJ5
A) keep your 304 motor mounts (you can't use the original 360 mounts)
B) you need a 360 flywheel (difference in balance)
Everything else is interchangeable. The engines are the exact same size in outer diameters, the difference is all on the inside. It's a really easy swap.
Recommended timing of 10 degrees on a stock 360.
Also, because of oiling deficiencies, you will find that most people recommend starting your build around a brand new oil pump.
LeePrather is offline
post #36 of 41 Old 08-16-2013, 06:11 AM
CJ7ROB
I'd put in all new gaskets & seals too while your at it. Head gaskets, intake gasket, oil pan,rear main..etc. Felpro or Mr. Gasket kits pretty much cover it all.
CJ7ROB is offline
post #37 of 41 Old 08-16-2013, 06:37 AM
iluvcowjuice
1979 CJ7
I have a stock 360 intake manifold and carb I pulled off of a running 360 if you're interested
iluvcowjuice is offline
post #38 of 41 Old 08-16-2013, 07:08 AM
LeePrather
1978 CJ5
X2...timing cover, water pump...you can get the entire gasket kit for about $80 and the intake gasket is metal and costs about $30
post #39 of 41 Old 08-16-2013, 08:01 AM
jdarg
Originally Posted by Dngrs1 View Post
There are so many variants of the Chevy 350 made that you could, in theory, end up with one that has less HP than your 304
That's simply not true. Even the lowly LM1 in its worst incarnation makes a bit more power than a '78 304. And its easier/cheaper to get to say the 250HP level than it is the 304.
If you aren't averse to spending 1.5-2x the money for the same power level you can get with the SBC platform, go with an AMC motor. There's really no "better" or "worse", but SBC's are cheaper to build - all day long.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #40 of 41 Old 08-16-2013, 09:23 AM Thread Starter
DanTheMan01
1978 CJ7
Yeah I'm interested! Not sure how much an intake would cost to ship though. Is it a 2 barrel? That's what I am looking for. The 360 I am going to buy comes with a 4 barrel intake, but I have read that a 2 barrel will put out more torque. PM me and we can talk a little more about it.
post #41 of 41 Old 08-16-2013, 02:21 PM
jp360cj
1977 CJ7
Intakes are interchangeable between the 304 & 360, but I don't know if the factory intakes are the exact same.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
