360 or 350 - JeepForum.com
post #1 of 41 Old 07-03-2013, 01:05 PM Thread Starter
DanTheMan01
1978 CJ7
360 or 350
I have a 78 CJ7 with a 304. I really like the 304 and I love the sound of it, but I just don't think I can get the power out of it that I want. I want to buy an AMC 360 or a Chevy 350 that I can have rebuilt. I already have the Turbo 400 tranny so the 350 would be easy, but I kind of want to stay with the AMC brand. What do you guys think?
Any comments are appreciated.
Here is a pic just because I know you guys like them.
DanTheMan01 is offline
post #2 of 41 Old 07-03-2013, 03:21 PM
82JeepCJ7
1982 CJ7
To go with a GM motor, you would have to swap in a different transmission. The Turbo 400 in there now has a AMC bellhousing pattern. I would build a AMC 360 and drop in there. Nothing to change. Put a HEI ignition system on it, a good carb (I run a Quadrajet) and wheel it. Too much stuff has to be changed to put a chebby motor in there.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 41 Old 07-03-2013, 03:23 PM
justinwatts8282
a 360 will be much easyer to complete with your current set up i agree
justinwatts8282 is offline
post #4 of 41 Old 07-03-2013, 05:33 PM
jp360cj
1977 CJ7
To go with the 350, you'll need a new transmission which means a new tcase and a centered rear axle. You might could cut the bell off a GM TH400 and graft it to yours. That may not be an option, just trying to think outside the box.
Rebuilding an AMC360 isn't cheap, so I would try to find a running one in decent shape. its a direct bolt in from the 304.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #5 of 41 Old 07-04-2013, 09:53 AM Thread Starter
DanTheMan01
1978 CJ7
Huh... I just assumed at a Turbo 400 bolted right up to a 350. I agree the 360 is probably a better option. Thanks guys. Now I just have to find one...
post #6 of 41 Old 07-04-2013, 02:14 PM
CSP
A Turbo 400 with the Chevy bolt pattern and bellhousing shape will bolt up to the 350. The one you have has the AMC bellhousing shape and bolt pattern. All TH400s are not the same.
You can take the tailhousing and output shaft from an AMC TH400 and swap them into a Chevy TH400 and keep your existing transfer case and axles. This does require complete disassembly of both transmissions though.
CSP is offline
post #7 of 41 Old 07-04-2013, 02:32 PM
cjsteven
1981 CJ7
I d go for the 360. I replaced my tired 360 for a new 350 and it just doesnt feel the same. On paper the 350 is beter but my heart doesn t agree. My other cj still has a 360 and that s the one I like to drive the most.
cjsteven is offline
post #8 of 41 Old 07-04-2013, 02:45 PM
Dngrs1
1979 CJ7
I would look for a 401. There are so many variants of the Chevy 350 made that you could, in theory, end up with one that has less HP than your 304. If you can't find a 401 then I agree with the 360.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #9 of 41 Old 07-04-2013, 04:00 PM
REDnBLUES
1977 CJ7
Why not just rebuild the 304 and add heads, intake, headers and be done. It would likely be cheaper and easier for sure.
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #10 of 41 Old 07-04-2013, 04:13 PM
swatson454
1983 CJ7
Originally Posted by Dngrs1 View Post
...There are so many variants of the Chevy 350 made that you could, in theory, end up with one that has less HP than your 304...
If you find one, plug the rest of the spark plug wires in.
Just some cocktail-induced humor
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #11 of 41 Old 07-04-2013, 05:56 PM
mtndew1
1976 CJ7
It's not worth rebuilding a 304, I know I did it. Yes you can get ok power out of it but not even close to a 360/401 for the same price. Buy a 360 or a 401 if you are going to rebuild one and be done with it.
If you are going to go with the 350 I have a tailshaft from an th400 (amc) style you can have if you pay shipping from AZ. I rebuilt mine but put in an aftermarket tail shaft to link it up to a Dana 300.
1976 Jeep CJ7 - Build in progress
mtndew1 is offline
post #12 of 41 Old 07-04-2013, 06:00 PM
Neuner-9R
Nice pic. Is that desert tan?
Neuner-9R is offline
post #13 of 41 Old 07-05-2013, 01:23 AM
REDnBLUES
1977 CJ7
I'll agree that the 360-401 will put out more power - I also rebuilt my 304 several years ago. But you still have to find a decent 360 or 401 to start. You have to factor that expense in too. If you have a buddy willing to give it to you then your okay but everone these days seems to think they and the 401 are forged from gold or something.
post #14 of 41 Old 07-05-2013, 06:49 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
Make a list of all three projects, Total the price of each and then you can weigh your options.
I wanted to go AMC, but there are not many to be had in my neck of the woods.
Hope that helps!
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #15 of 41 Old 07-07-2013, 09:38 AM Thread Starter
DanTheMan01
1978 CJ7
That is a crappy Auto Zone Bedliner the PO put on. I do kind of like the color but he did a poor job putting it on.
