360 2 barrel skipping when cold! - JeepForum.com
post #1 of 3 Old 10-09-2002, 05:52 PM Thread Starter
Big Bill 33
I have swapped a 360 v8 in my 85 cj7.It has a remanufactured motorcraft 2150 2 barrel with electric choke.In the mornings it cranks fine,but when I take off down the road it skips,misses and runs rough, until it starts to warm up then it quits.After it warms up it runs fine.Motor just has been built,new everything. New coil,distr,wires and plugs.
Bill Green
Big Bill 33 is offline
post #2 of 3 Old 10-11-2002, 10:28 AM
NC74CJ
NC74CJ's Avatar
Yep, thats what carbeurators do. To a certain extent, this will always happen, but you can adjust the fast idle/choke to compensate for the extra fuel needed on a cold engine. Good Luck
Bill
A stroke bolder, a pinch better.
NC74CJ is offline
post #3 of 3 Old 10-12-2002, 12:26 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Not so, a sound motor with a properly adjusted carb should start and run when cold. Off the top of my head, it sounds like choke problems. Check to see if it is compleatly closed when cold. It should snap when flicked open with your finger. Start the rig, does the pull off open the plate? Should be about 3/16ths of an inch(check your specs) between the horn and the plate. Is the choke idle set to specs? A low idle when cold can cause a stumble.
jeepdaddy2000 is offline
2 barrel or 4 barrel on 304 SonicR1 Jeep CJ Forum 16 01-27-2010 03:24 PM
258 1 barrel to 2 barrel plate pwright1962 Jeep CJ Forum 4 06-23-2009 08:39 AM
360 ? 4 barrel or 2 barrel oteps Jeep CJ Forum 15 05-04-2009 07:32 PM
2 Barrel Carb vs 4 Barrel Carb on a V8 tahoe wheelers Jeep CJ Forum 9 08-04-2008 09:12 PM
Carter 1 barrel BRIAN ROBBINS Jeep CJ Forum 3 06-23-2004 10:13 AM
