35in Tire, axel what??? - JeepForum.com
post #1 of 4 Old 06-27-2003, 12:33 AM Thread Starter
Incredable
what kind of axels would you guyz recomend if i wanted to put 35's on my 81 CJ-7 with an I-6
Incredable is offline
post #2 of 4 Old 06-27-2003, 08:54 AM
rustyCJ
the stock "axles" if upgraded properly will work fine. stick new 1-piece shafts in the AMC20, the D30 front is decent but you might brake some u-joints, if you upgrade to the warn shafts up front(or have dutchman or someone make a set)with the larger u-joints it will hold up fine.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #3 of 4 Old 06-27-2003, 08:32 PM
pontiac58
1980 CJ7
For 35's i would stick with the 20 and just stitch weld the tubes and install some superior one piece gears. A truss wouldnt hurt either.
The front, i would just ditch that 30, have a waggy 44 cut down 4 inches, use ford hubs to get the bolt pattern and you will be set. The d30 r&p gets tooo smalls for me in the taller gears. And with 35's you are probably going to be looking into the 4:56 to 4:88 gears.
pontiac58 is offline
post #4 of 4 Old 07-15-2003, 04:13 PM
ace2222
I would also get the superior one piece rear end and the front super 30 kit you can get these for a pretty good price..
amc 20 -- $235
dana 30 with arb -$750
thats one heck of a deal for two pretty good axles once that is completed!!!
ace2222 is offline
35in tires with a 4 in slyjacker lift?? shelbycj5 Jeep CJ Forum 3 09-28-2007 04:12 PM
what size is this axel nut? tony dz Jeep CJ Forum 3 09-22-2007 07:57 PM
How do you know what axel you have XJ OnTheBeach88 Jeep CJ Forum 1 05-20-2007 12:44 PM
do i need a 1 peice axel coloradocj-7 Jeep CJ Forum 5 11-29-2004 07:10 PM
What Axel Do I Have? GrandRubicon155 Jeep CJ Forum 3 05-02-2003 02:59 PM
