#1 | |
350/SBC wiring problem
Some how my wiring on my cj is a mess. For some reason I'm having problems with the starter, selinoid, alternator, ignition wiring. Everything was fine then I was heading to work and the sumabeech died out of nowhere. I'm running the stock wiring with some mild rewiring done by my buddy. I'm running a one wire alternator hook-up and a chevrolet style starter with the selinoid on it. Anyone here running an SBC with the stock Jeep wiring (with obvious modding) and have any words of wizdom for me? How is yours wired?
Where's John? He's the guy who knows all the wiring. Got a good diagram?
1980 Cj-7 1979 350 with mild goodies T-176 4spd. 33x12.50 Micky Thompson Baja belted. (Complete frame off comming soon!) SOLD 1999 Cherokee classic Rusty's 4.5 AAL 33x12.5 Maxxis Bighorn mudders. 2005 Toyota Tundra spectra blue 4x4 double cab Hers 1999 Wrangler aka "the beast" 4cyl automatic |
#2 |
Problem number one:
mild rewiring done by my buddy I only have a few wires hooked up to my 350. 1. Started 2. Alt to battery 3. Cap & Rotor I had to replace all my wiring because the dumb a$$ previous owner used TELEPHONE WIRE. Did it start after stalling? Do your lights flicker when driving - if so bad grounds I would go back and check all wiring and make sure everything is done right. Only wire I could see causing this problem is the one to the cap/rotor maybe. Might be an exposed wire that is shorting out. Check your fuse. Wiring is the biggest pain in the butt. Thing to do in the future: 1. Soldier all connections 2. loom all wires 3. where your soldier used shrink wrap material. Once done you will never have to worry about a short again: I went yellow loom crazy, and I have not had a problem since. ![]()
Rob99 Fan Club Member#00 Beware users with very thin skin: ------------------------------------------ gschretter |
#3 |
check the wires going to the distrubutor...Maybe one poped off..Sorry I cant be much help with the wireing on the swap..I run a full msd ignition..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] |
#4 |
[QUOTE=gschretter]Problem number one:
mild rewiring done by my buddy I only have a few wires hooked up to my 350. 1. Started 2. Alt to battery 3. Cap & Rotor I had to replace all my wiring because the dumb a$$ previous owner used TELEPHONE WIRE. Did it start after stalling? Do your lights flicker when driving - if so bad grounds I would go back and check all wiring and make sure everything is done right. Only wire I could see causing this problem is the one to the cap/rotor maybe. Might be an exposed wire that is shorting out. Check your fuse. Wiring is the biggest pain in the butt. Thing to do in the future: 1. Soldier all connections 2. loom all wires 3. where your soldier used shrink wrap material. Once done you will never have to worry about a short again: I went yellow loom crazy, and I have not had a problem since.[QUOTE=gschretter] The wiring was done by my dad's budy actually and he is pretty good with just about anything but I think we might have screwed up on this but I'm not blaming him. So you only have three wires running in the engine bay? Starter, alternator, and distributer? Stupid question but one wire alternator? The problem with mine lies within the starter selinoid/battery/alternator hookup. I have one wire from the alternator to the selinoid, the postive cable from the battery to the selinoid, and I think two other wires going to the starter selinoid from the wiring harness. I know this probly doesn't make much sence but I hope it helps you help me ![]()
#5 |
i would have to check but the wire going to the selinoid from the alt. doesnt sound right..I think mine goes straight to the battery
#6 |
alternator to the selinoid = change it to have the alt cable hook up the the battery.
I use a Optima battery (DUAL POST BATTERY) and use the top post to go to the starter and the side post to hook up the Altentator. I have two wires going to the starter. 1. Battery to starter 2. Wire from steering column to Solinoid. Chevy came with allot of the wiring going to the starter because it was a easy place to hook all the wires together for the battery. When I was talking about wires I was thinking + feeds that were cricital. I forgot stuff like electric chock I am off next week, I will see if I can send you some pics. Email me what pictures you want to see Schretter.Works@gmail.com
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
