350 SBC Engine Swap - Fan Shroud Needed? - JeepForum.com
post #1 of 5 Old 01-29-2005, 06:56 AM Thread Starter
nickdz
nickdz's Avatar
For those who have completed a 350 engine swap, are you using fan shrouds? If so, why (other than the boiler plate statement that V8's need one)? Did you have any problems without having one?
I did my swap about a year ago (Feb. 2004) and swaped out my 151 for a 350. The radiator is a V8 conversion radiator from rigid steel and I am running a flex-fan and 180 degree thermostat.
I did not install a fan shroud with the engine swap. I figured I would keep a close eye on the temp gauge (aftermarket) to see how she ran. I spent half the summer of 2004 in Houston, TX and the other half in Virginia with no major problems. The temp gauge indicated ~190 degrees while hitting 195 under the most extreme conditions.
After going through my Satruday morning routine of coffee and checking out this forum, the topic of installing/not installing a shroud came back to mind.
Just curious, but can anyone who has completed this engine swap pipe in
1980 CJ7
- 151 "Iron Duke"/SR4 converted to Chevy 350/SM465
- Moser One-Piece Rear Axles
- Locked All Around
- Mastercraft Seats
- Durabak Interior and Exterior
- KargoMaster Cage
- Way too many minor repairs/upgrades to list (emphasis on "repairs")
nickdz is offline
post #2 of 5 Old 01-29-2005, 10:46 AM
jstltreat
I have done several sbc conversions and you shouldnt have any trouble at all with no shroud. I just made an upper fan shroud out of coil stock to keep hands out of the fan. You dont have to do it but its just a safety thing.
[URL=http://www.jeepaholics.com/rides/view.asp?id=2390
jstltreat is offline
post #3 of 5 Old 01-29-2005, 11:19 AM
TireFryerSS
Well my new toy (CJ5) has a 350 with a large cam and no fan shroud...soo far I havent seen temp's over 180...I believe this is because there is a 180* thermostat in the engine...we've been having weather in the 70's, which probably contributes to the cool engine temp. but I guess this summer will be the real test...as you probably know, Az summer's are long and hot.
TireFryerSS is offline
post #4 of 5 Old 01-29-2005, 01:36 PM
dawgates
1980 CJ7
Being from Arizona and now in Las Vegas. I know how HOT the sumers can be out West.
First how close is the fan to the radiator. It should be no more then a inch, two max. If you go further then that I would suggest a shroud. Tha fan will pull to much air from the inside of the engine compartment and not enough through the radiator. The shroud will keep this from happening. Also a 190 degree thermostat is a good idea (new cars use 195 degrees and higher(for emissions)) This will give the coolant in the radiator longer to cool down.
This is just and idea. I know two people that have been crazy enough to do this.
Use Tooling coolant in your radiator instead of water and antifreeze. You have to have a completely dry system (NO water) before you do project. Tool bits get very hot when cutting into metal. to keep them sharp and working properly you have a coolant running over your work. Beleive it or not it does work. It actually keeps the temp. of the engine cooler then regular water and antifreeze mixer.
Down side, you can't buy the coolant at an auto parts store, so if you break down you better have some extra tooling coolant with you.
dawgates is offline
post #5 of 5 Old 01-30-2005, 07:39 AM Thread Starter
nickdz
nickdz's Avatar
Thanks for the resonses. It looks like I'm good-to-go with my current setup. I wasn't too concerned, but I just wanted to double check with some other members.
jstltreat,
Do you have any pics of your safety fan shroud? That's not a bad idea and I would really like to see what the end result looks like.
dawgates,
Good call on the 190. Especially as it is freakin cold this time of year and my jeep is not axactly air-tight. That 190 would help out with the heat.
1980 CJ7
- Locked All Around
- Mastercraft Seats
- KargoMaster Cage
nickdz is offline
CJ7 304 Engine blown- swap ideas needed BuzzBee Jeep CJ Forum 30 12-15-2009 09:31 PM
86 CJ fan shroud needed spoonkilr Jeep CJ Forum 4 03-24-2009 11:26 AM
Information Needed: Fan Shroud Measurements nickdz Jeep CJ Forum 1 06-22-2006 04:32 AM
Which fan shroud will work with 350 SBC swap? nickdz Jeep CJ Forum 1 05-15-2006 07:28 PM
4.2 engine w/V-8 radiator, need a shroud fromme Jeep CJ Forum 2 10-20-2004 03:54 PM
