33x12.5 on Stock CJ? - Page 2 - JeepForum.com
post #16 of 19 Old 05-09-2003, 11:23 AM
Jeep Daddy
Jeep Daddy's Avatar
I guess you could say that CJ's are money pits. Get rid of it now if you don't think you can stand the drain. Or, slow down. You could buy the rims and tires and go cheap for now on the lift. Rims and tires will cost about $1000. Then you could get a shackle lift and body lift for about $175 if you shop around. This might affect the steering though. Shackle lifts can cause your Caster to be way off and make it difficult or impossible to keep straight on the road. Personally, I'd save my ducketts, like I already did, and get the rims, tires as a package, and the 4" lift kit all at once. Then you can regear the axles one at a time or choose not to regear for a while.
I have no vibrations at all. Lowering the xfer case eases the driveline angles and the DPA aids in steering geometery. The rear springs also come with a 4 degree wedge to help keep driveline angles correct. HTH
Look me up when you're in town. PM me and I'll give you my phone number.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #17 of 19 Old 05-09-2003, 11:47 AM
Chad Churchill
yeah..
But what ever you do don't lower your transer case!
go to a custom drive shaft or just go get some CV joints.. Lowering the case will case you to have less ground hight and you will high center lol unless your on 38'' tires...
yeah I would say go with a 4'' and maybe a 1'' body, but if you wanna keep your power dont go to 35's unless your ganna put gears/lockers and do a upgrade on your engine... haha and that is aroung $5,000 for all of that, so stick with the saving up, unless u just have to have it now..
'84 AMC CJ7.. 4" rancho 9000 9 way+ 1'' Tow Shacks+ 1'' BD, 9,000 warn winch, 33''BFG mudd, T176,Danna 300 with Twin shifter,44 front,20rear,4.56 with locks, 258beefed, w. fuel injected!,MSD,new white paint, all new intr., and two onbord airs. Member of TMTC, member of offroadministry, and go 4x4ing all over the U.S.A.!!!
'98 TJ... 4" Teraflex with rancho 9000 9 ways. 33" all's with solid Axles and 4.56 with locks.. Hunter green and ready to go..
Chad Churchill is offline
post #18 of 19 Old 05-14-2003, 11:50 AM
Yellow Fever
Yellow Fever's Avatar
Thanks for everyone's advise. I'm going to take my time and do things right.
Yellow Fever
95 YJ - 4 Banger
Pro Comp 4" (What a mistake)
BFG 33 A/T with Black Rock Crawler
4:56 Gear
85 CJ7 - 6 Cyl
Currently being Restored
Yellow Fever is offline
post #19 of 19 Old 05-14-2003, 03:27 PM
MR.CJ-7
You could put a set of TJ flares on it and cut the fenders to open up the wheel wells. I did this to mine and now I think it looks so much better.
Just my $.02
Former CJ'er
MR.CJ-7 is offline
OPINIONS - Pro Comp Radial Mud Terrain Tire - 33x12.5 R15 certifiablejeep Jeep CJ Forum 27 05-19-2009 09:05 AM
33x12.5x15 on 8" or 10"wide wheel pic request Taking2long Jeep CJ Forum 22 05-11-2009 04:36 PM
33x12.5 tires... 8" or 10" wheel width? jetskibob1 Jeep CJ Forum 6 02-18-2009 04:08 PM
Pictures of 33x12.50's on CJ7 w/ 2" Body Lift?? volfan Jeep CJ Forum 7 06-09-2008 11:39 AM
Getting 33x12.50s... questions Mastermind Jeep CJ Forum 5 07-31-2003 11:02 PM
