33's and a 2 inch lift on a cj5 possible? - JeepForum.com
post #1 of 5 Old 10-07-2002, 03:16 PM Thread Starter
DaveFL
DaveFL's Avatar
National Tire informed me that I can run 33"s on my 2 inch lift. This is on an 81 Cj5.
Now to the best of my knowledge I thought I would need 3"-4" to run 33"s I had planned on going with 32"s.
Now if indeed I can run 33's would I need to regear at all? any other problems I need to look at?
Wouldnt mind running 33"s but don't have the money to regear I am running the stock dana 30 and amc 20.
Also will be a while before I upgrade my engine, right now Im running the 151 Iron Duke, not sure if that makes a difference as well.
Thanks for any info.
DaveFL is offline
post #2 of 5 Old 10-07-2002, 06:49 PM
werewolf7111
yeah you can ( physically speaking) but you will eventually develop problems
and FYI- one of my CJs( 85) had a 151 in it- I sincerely hope and pray I had the "unique" one because if yours has as much power as mine did, you can count yourself lucky if it has the power to pull those tires downhill with a good tailwind. LOL
seriously, i think you will be better satisfied with a stronger engine but I'm sure i just had a lemon
joe MSME, PE
werewolf7111 is offline
post #3 of 5 Old 10-07-2002, 08:35 PM
80cj
80cj's Avatar
1980 CJ5
A 2 inch lift is OK if you're not going to wheel it hard. There really isn't enough clearance for 33" tires if you get into terrain requiring lots of articulation. I 've always thought that a 2 1/2 inch suspension lift and 1 inch body lift might be the way to go. That way you have tolerable drive line angles. Maybe other forum members can comment on this. If you have a 258 then 3.31 gears were the lowest you could get in 81 unless some one changed the gears. 4.10's with 33's and a 258 seem to be a popular combination. Having power brakes would be nice.
80cj is offline
post #4 of 5 Old 10-08-2002, 08:25 AM Thread Starter
DaveFL
DaveFL's Avatar
Well I think Im gonna stick with 32s and a 2" lift. I think thats the best option.
Im hoping that the 4 banger will turn the 32"s.
Id like to go 3.5 and 33"s but just cant afford to regear or a 3.5" BDS lift with everything else Im doing.
Let me know if you think the 4 banger 151 won't turn those tires. I might have to rethink my options. Will post some questions in the engine forum as well.
DaveFL is offline
post #5 of 5 Old 10-08-2002, 09:47 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
That engine will turn the tires .. that's not a problem .. the problem is how fast that engine can turn the tires
If you don't mind slicin' and dicin' your body, you can squeeze the 33" tires into place and have full flex without rubbing. Your other option is to drop your bumpstops to stop flex before it makes contact ..
Your axles should handle the added weight of the tires, but you might wish to use the lightest rims you can find .. stay away from the steelies - they have the strength, but they also weigh more than aluminum. The aluminum ones can break, but it takes a huge amount of torture to break them ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
1 inch body lift and 3/4 inch shackle lift? bucs1fan Jeep CJ Forum 6 09-29-2009 12:21 PM
Lift for 33's seagrave Jeep CJ Forum 9 02-19-2009 08:57 AM
4 inch Rough Country Lift on 28 inch tires CrazyFlippinCJ7 Jeep CJ Forum 16 03-02-2008 02:09 PM
Anybody just running a 2.5 lift with 33's? TexasCJ7 Jeep CJ Forum 10 02-19-2007 01:31 PM
Does anyone have any pics of a jeep with a 6 inch or more lift and 35+ inch tires? jeepcj7 Jeep CJ Forum 10 03-23-2003 08:39 AM
